10-09-2018, 23:42 | #257 (permalink) | |
Product Supporter Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Quote:
CuT URLs | |
10-10-2018, 06:23 | #259 (permalink) |
Freak Poster Join Date: Jan 2017 Location: Poland
Member: 2675528 Status: Offline Thanks Meter: 81 | And can You get me instruction what i need to do with this firmware? i need to flash it, and that's all ? or i need to do hard reset and flash sth more? Thx for reply bro |
10-10-2018, 07:35 | #260 (permalink) | |
1. Open miracle box and see the indications of the screen capture, we put the xiaomi in edl mode. 2. We go to the tab above where you put my accoun lock on the left and we go to the right side and look for the model of the xiaomi, we put the xiaomi in edl mode, scan port and start button. 3. If the others have not worked or given us error, we take the xiaomi in edl mode, scan port, we go to the tab read / format flash, read partitions, once read we look for a partition called persist.img and select it and delete it, in the case of relock you re-write or flash the partition persist.img or before connecting it to the internet we select the box my prevent relock. I hope I have helped you, thank you. | |
10-10-2018, 08:25 | #261 (permalink) |
Member: 2675528 Status: Offline Thanks Meter: 81 | But i have miracle box 2.58 and it doesnt have prevent lock. I tried use it before i write there. When i delete persist.img i dont have working sensors, but after flash, sensor working, but relock appears... is your firmware have working sensors and no relock? Wysłane z mojego SM-G965F przy użyciu Tapatalka |
10-10-2018, 16:28 | #264 (permalink) |
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Good, the firmware is 100% tested, I do not know how you do things, it can not be that I do not have problems and you do, something does not block or something fails, use professional tools, what I said does not give me any problems , I have explained how to do it and you will have done what you wanted, I can not do anything. Thank you. |
10-10-2018, 16:31 | #266 (permalink) |
Member: 2675528 Status: Offline Thanks Meter: 81 | I flash it with xiaomiflash. Program said success but the phone hang on this logo. I flashed original firmware and everything works fine, but still locked. Wysłane z mojego SM-G965F przy użyciu Tapatalka |
10-11-2018, 14:09 | #268 (permalink) |
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Good to all those who have problems to remove the micloud account from xiaomi, new tool they have put both on the web and in the easy-firmware forum, I leave you link, put the xiaomi in recovery or sideload mode and press the remove button my account, thanks. CuT URLs |
10-11-2018, 15:51 | #270 (permalink) |
Junior Member Join Date: Jun 2009 Location: Kazakhstan Lisakovsk
Member: 1055161 Status: Offline Thanks Meter: 1 | Quote: |
