11-07-2018, 15:04 | #301 (permalink) | |
Banned Join Date: Mar 2011
Member: 1539068 Status: Offline Thanks Meter: 74 | Quote:
11-13-2018, 19:22 | #303 (permalink) |
Junior Member Join Date: Mar 2012 Location: New Delhi, India Age: 41
Member: 1733961 Status: Offline Thanks Meter: 4 | Quote: Regards, Rajesh |
11-14-2018, 11:00 | #304 (permalink) | |
Product Supporter Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Quote:
Procedure for its correct use: 1. We have to disconnect the xiaomi from the Internet, be it wifi, 3g and 4G. 2. We enable debug usb, we accept the rsa key and check the box to trust this computer, this will come out when we connect the usb cable to the xiaomi. 3. Open the tool as administrator and we will give you the unlock box of micloud. Tool link: CuT URLs Thank you does not cost anything, thank you very much. | |
The Following User Says Thank You to Franky_36 For This Useful Post: |
11-14-2018, 13:41 | #306 (permalink) |
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Hi, check if you can disable the wifi, if you do not turn off the phone you enter the recovery and factory reset, when you restart the phone the message or the micloud account lock will have disappeared and now follow these steps: Procedure for its correct use: 1. We have to disconnect the xiaomi from the Internet, be it wifi, 3g and 4G. 2. We enable debug usb, we accept the rsa key and check the box to trust this computer, this will come out when we connect the usb cable to the xiaomi. 3. Open the tool as administrator and we will give you the unlock box of micloud. Tool link: CuT URLs Thank you does not cost anything, thank you very much. |
The Following 2 Users Say Thank You to Franky_36 For This Useful Post: |
11-17-2018, 10:38 | #308 (permalink) |
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Hi, check if you can disable the wifi, if you do not turn off the phone you enter the recovery and factory reset, when you restart the phone the message or the micloud account lock will have disappeared and now follow these steps: Procedure for its correct use: 1. We have to disconnect the xiaomi from the Internet, be it wifi, 3g and 4G. 2. We enable debug usb, we accept the rsa key and check the box to trust this computer, this will come out when we connect the usb cable to the xiaomi. 3. Open the tool as administrator and we will give you the unlock box of micloud. Tool link: CuT URLs Being a new xiaomi with miui 10 may fail the modified firmware or in the worst case according to my tests that I have done that corrupts the boot, for now this is the best method and it works 100%. Thank you does not cost anything, thank you very much. |
11-17-2018, 15:45 | #309 (permalink) | |
Freak Poster Join Date: Mar 2018
Member: 2823049 Status: Offline Thanks Meter: 14 | Quote:
i can not understand your process can you please tell me clearly or any video you have . thanks in advanced. | |
11-17-2018, 15:51 | #310 (permalink) |
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Good, the process is simple, do not connect the internet, enable usb debugging, connect it with the usb cable, accept rsa key and trust my computer, open the software as administrator and click unlock miaccount, it is not very difficult, thank you very much. |
11-18-2018, 11:18 | #312 (permalink) | |
CuT URLs | |
11-18-2018, 13:32 | #314 (permalink) |
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Good, there is no risk, we have flashed many people, but it is your decision to do it by this method by the other method that I mentioned in the previous post, you just have to enter the recovery mode and make data wipes and the lock of micloud will not appear , do not connect to the internet or for wifi or data, enable usb debugging and do the operation with the tool, thank you very much. |
