Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Xiaomi
Old 10-09-2018, 20:54   #256 (permalink)
Member: 2675528
Thanks Meter: 54
Hi. I have note 4x (mido). Do you have modified firmware for this device?
Thanks for reply
Old 10-09-2018, 23:42   #257 (permalink)
Member: 2665389
Thanks Meter: 168
Thanks for reply
Hi, here I leave the modified firmware link, you have professional tools, such as mrt, bst, etc ?, thanks.
CuT URLs
Old 10-10-2018, 05:34   #258 (permalink)
Member: 2675528
Thanks Meter: 54
I have octoplus frp and some cracked box like miracle, uat, uni.
Wysłane z mojego SM-G965F przy użyciu Tapatalka
Old 10-10-2018, 06:23   #259 (permalink)
Member: 2675528
Thanks Meter: 54
And can You get me instruction what i need to do with this firmware? i need to flash it, and that's all ? or i need to do hard reset and flash sth more?
Thx for reply bro
Old 10-10-2018, 07:35   #260 (permalink)
Member: 2665389
Thanks Meter: 168
Thx for reply bro
Good morning, taking miracle theoretically, it makes us a little easier task, options or ways of doing it:
1. Open miracle box and see the indications of the screen capture, we put the xiaomi in edl mode.
2. We go to the tab above where you put my accoun lock on the left and we go to the right side and look for the model of the xiaomi, we put the xiaomi in edl mode, scan port and start button.
3. If the others have not worked or given us error, we take the xiaomi in edl mode, scan port, we go to the tab read / format flash, read partitions, once read we look for a partition called persist.img and select it and delete it, in the case of relock you re-write or flash the partition persist.img or before connecting it to the internet we select the box my prevent relock.
I hope I have helped you, thank you.
Old 10-10-2018, 08:25   #261 (permalink)
Member: 2675528
Thanks Meter: 54
But i have miracle box 2.58 and it doesnt have prevent lock. I tried use it before i write there. When i delete persist.img i dont have working sensors, but after flash, sensor working, but relock appears... is your firmware have working sensors and no relock?
Old 10-10-2018, 09:41   #262 (permalink)
Member: 2675528
Thanks Meter: 54
Bro, your firmware not working. Hanging on this logo more than 30 minutes :/
Old 10-10-2018, 16:01   #263 (permalink)
Member: 1964660
Thanks Meter: 27
please share note 5 pro fixed firmware here or in pm.THX!!
Old 10-10-2018, 16:28   #264 (permalink)
Member: 2665389
Thanks Meter: 168
Good, the firmware is 100% tested, I do not know how you do things, it can not be that I do not have problems and you do, something does not block or something fails, use professional tools, what I said does not give me any problems , I have explained how to do it and you will have done what you wanted, I can not do anything. Thank you.
Old 10-10-2018, 16:29   #265 (permalink)
Member: 2665389
Thanks Meter: 168
Hi, the first thing you have to check if you have antirolback ?, thanks.
Old 10-10-2018, 16:31   #266 (permalink)
Member: 2675528
Thanks Meter: 54
I flash it with xiaomiflash. Program said success but the phone hang on this logo. I flashed original firmware and everything works fine, but still locked.
Old 10-10-2018, 17:54   #267 (permalink)
Member: 2665389
Thanks Meter: 168
Good, I have explained three ways to do it and you have done what you wanted, I do not understand the truth, thanks and closed topic.
Old 10-11-2018, 14:09   #268 (permalink)
Member: 2665389
Thanks Meter: 168
Good to all those who have problems to remove the micloud account from xiaomi, new tool they have put both on the web and in the easy-firmware forum, I leave you link, put the xiaomi in recovery or sideload mode and press the remove button my account, thanks.
CuT URLs
Old 10-11-2018, 14:24   #269 (permalink)
Member: 2675528
Thanks Meter: 54
Can you send a link with some threads about this tool? I can not find it in the easy firmware forum
Old 10-11-2018, 15:51   #270 (permalink)
Member: 1055161
Originally Posted by Franky_36 View Post
New modified xiaomi firmware:
MI 4A (ROLEX): MI 4A &_40;ROLEX&_41;.7z - 1558386397
REDMI 6 PRO (******) INDIAN GLOBAL :REDMI 6 PRO &_40;******&_41; INDIAN GLOBAL.7z - 1912060822
REDMI 6 (CEREUS): REDMI 6 &_40;CEREUS&_41;.7z - 1678114762
REDMI 5 PLUS (VINCE): REDMI 5 PLUS &_40;VINCE&_41;.7z - 1720609386
MiMax Prime 128GB (HELIUM):MiMax Prime 128GB &_40;HELIUM&_41;.7z - 1240403570
MiMax Prime 64GB (HELIUM): MiMax Prime 64GB &_40;HELIUM&_41;.7z - 1240406253
MiMax 32GB (HYDROGEN): MiMax 32GB &_40;HYDROGEN&_41;.7z - 1284847516
MI 5S PLUS (NATRIUM): MI 5S PLUS &_40;NATRIUM&_41;.7z - 1393578332
MI NOTE 5 (GEMINI): MI NOTE 5 &_40;GEMINI&_41;.7z - 1408039922
MI NOTE 2 (SCORPIO): MI NOTE 2 &_40;SCORPIO&_41;.7z - 1449077922
MI MAX 2 (OXYGEN): MI MAX 2 &_40;OXYGEN&_41;.7z - 1786451357
MI 5S (CAPRICORN): MI 5S &_40;CAPRICORN&_41;.7z - 1333379438
REDMI NOTE 5A PRIME (UGG): REDMI NOTE 5A PRIME &_40;UGG&_41;.7z - 1669837785
REDMI NOTE 5 (WHYRED): REDMI NOTE 5 &_40;WHYRED&_41;.7z - 2195651462
REDMI NOTE 5A (UGGULITE): REDMI NOTE 5A &_40;UGGLITE&_41;.7z - 1634111967
MI NOTE 3 (JASON):MI NOTE 3 &_40;JASON&_41;.7z - 1891629070
S2-Y2 (YSL): S2-Y2 &_40;YSL&_41;.7z - 1850601361
REDMI 6A (CACTUS): REDMI 6A &_40;CACTUS&_41;.7z - 1795766892
POCOF1 (BERYLLIUM ): POCOF1 &_40;BERYLLIUM&_41;.7z - 2121343648
MI 8 (DIPPER): MI 8 &_40;DIPPER&_41;.7z - 1962982640
MI MIX 2 (CHIRON): MI MIX 2 &_40;CHIRON&_41;.7z - 1757888462
MI 6 (SAGIT): MI 6 &_40;SAGIT&_41;.7z - 1734434332
REDMI 4X (SANTONI): REDMI 4X &_40;SANTONI&_41;.7z - 1595477805
REDMI NOTE 5 PRO (WHYRED): REDMI NOTE 5 PRO &_40;WHYRED&_41;.7z - 2170987124
Redmi 5 (ROSY):Redmi 5 &_40;ROSY&_41;.7z - 1784446895
MI MIX (LITHIUM): MI MIX &_40;LITHIUM&_41;.7z - 1388504150
MI MIX 2S (POLARIS): MI MIX 2S &_40;POLARIS&_41;.7z - 2020081319
Good, remember before connecting internet or data, once the micloud account is removed, from the phone do a factory reset, keep in mind they are files under test and there may be a failure, with the xiaomi that I have tried to reach the workshop, they work 100%, always edl mode and if possible avoid the miflash software for the errors it gives when flashing, any questions or problems comment, thank you very much.
Redmi 4A Rolex need firmware please?
Page generated in 0.18958 seconds with 7 queries
