Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Xiaomi
Old 11-07-2018, 15:04   #301 (permalink)
Member: 1539068
Thanks Meter: 74
Originally Posted by Franky_36 View Post
Procedure for its correct use:
1. We have to disconnect the xiaomi from the internet whether it's wifi, 3g and 4G.
2. We enable debug usb, we accept rsa key and check the box trust this computer, this will come out when we connect the usb cable to the xiaomi.
3. We open the tool as administrator and we give the unlock micloud box.
Thank you does not cost anything, thank you very much.
Link: CuT URLs
phone is asking for huawei id at start up.. is there any firmware to remove huawei id from p20 standard edition eml-tl00..??
Old 11-07-2018, 15:34   #302 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Hi, this is the forum section of xiaomi no huawei, thanks.
Old 11-13-2018, 19:22   #303 (permalink)
Member: 1733961
Thanks Meter: 4
New modified xiaomi firmware:
MI 4A (ROLEX): MI 4A &_40;ROLEX&_41;.7z - 1558386397
REDMI 6 PRO (******) INDIAN GLOBAL :REDMI 6 PRO &_40;******&_41; INDIAN GLOBAL.7z - 1912060822
REDMI 6 (CEREUS): REDMI 6 &_40;CEREUS&_41;.7z - 1678114762
REDMI 5 PLUS (VINCE): REDMI 5 PLUS &_40;VINCE&_41;.7z - 1720609386
MiMax Prime 128GB (HELIUM):MiMax Prime 128GB &_40;HELIUM&_41;.7z - 1240403570
MiMax Prime 64GB (HELIUM): MiMax Prime 64GB &_40;HELIUM&_41;.7z - 1240406253
MiMax 32GB (HYDROGEN): MiMax 32GB &_40;HYDROGEN&_41;.7z - 1284847516
MI 5S PLUS (NATRIUM): MI 5S PLUS &_40;NATRIUM&_41;.7z - 1393578332
MI NOTE 5 (GEMINI): MI NOTE 5 &_40;GEMINI&_41;.7z - 1408039922
MI NOTE 2 (SCORPIO): MI NOTE 2 &_40;SCORPIO&_41;.7z - 1449077922
MI MAX 2 (OXYGEN): MI MAX 2 &_40;OXYGEN&_41;.7z - 1786451357
MI 5S (CAPRICORN): MI 5S &_40;CAPRICORN&_41;.7z - 1333379438
REDMI NOTE 5A PRIME (UGG): REDMI NOTE 5A PRIME &_40;UGG&_41;.7z - 1669837785
REDMI NOTE 5 (WHYRED): REDMI NOTE 5 &_40;WHYRED&_41;.7z - 2195651462
REDMI NOTE 5A (UGGULITE): REDMI NOTE 5A &_40;UGGLITE&_41;.7z - 1634111967
MI NOTE 3 (JASON):MI NOTE 3 &_40;JASON&_41;.7z - 1891629070
S2-Y2 (YSL): S2-Y2 &_40;YSL&_41;.7z - 1850601361
REDMI 6A (CACTUS): REDMI 6A &_40;CACTUS&_41;.7z - 1795766892
POCOF1 (BERYLLIUM ): POCOF1 &_40;BERYLLIUM&_41;.7z - 2121343648
MI 8 (DIPPER): MI 8 &_40;DIPPER&_41;.7z - 1962982640
MI MIX 2 (CHIRON): MI MIX 2 &_40;CHIRON&_41;.7z - 1757888462
MI 6 (SAGIT): MI 6 &_40;SAGIT&_41;.7z - 1734434332
REDMI 4X (SANTONI): REDMI 4X &_40;SANTONI&_41;.7z - 1595477805
REDMI NOTE 5 PRO (WHYRED): REDMI NOTE 5 PRO &_40;WHYRED&_41;.7z - 2170987124
Redmi 5 (ROSY):Redmi 5 &_40;ROSY&_41;.7z - 1784446895
MI MIX (LITHIUM): MI MIX &_40;LITHIUM&_41;.7z - 1388504150
MI MIX 2S (POLARIS): MI MIX 2S &_40;POLARIS&_41;.7z - 2020081319
Good, remember before connecting internet or data, once the micloud account is removed, from the phone do a factory reset, keep in mind they are files under test and there may be a failure, with the xiaomi that I have tried to reach the workshop, they work 100%, always edl mode and if possible avoid the miflash software for the errors it gives when flashing, any questions or problems comment, thank you very much.
Sir, I have Redmi 6 Pro for Mi-Account locked and please renew the modified link for the same as the link is dead right now.
Regards,
Rajesh
Old 11-14-2018, 11:00   #304 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Regards,
Rajesh
Hi, check if you can disable the wifi, if you do not turn off the phone you enter the recovery and factory reset, when you restart the phone the message or the micloud account lock will have disappeared and now follow these steps:
1. We have to disconnect the xiaomi from the Internet, be it wifi, 3g and 4G.
2. We enable debug usb, we accept the rsa key and check the box to trust this computer, this will come out when we connect the usb cable to the xiaomi.
3. Open the tool as administrator and we will give you the unlock box of micloud.
Tool link: CuT URLs
The Following User Says Thank You to Franky_36 For This Useful Post:
Old 11-14-2018, 13:12   #305 (permalink)
Member: 2788157
Thanks Meter: 12
REDMI 5 PLUS (VINCE): REDMI 5 PLUS mi cloud remove ant 4
Old 11-14-2018, 13:41   #306 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Tool link: CuT URLs
The Following 2 Users Say Thank You to Franky_36 For This Useful Post:
Old 11-17-2018, 09:24   #307 (permalink)
Member: 1399256
Sonork: 100.1537352
Thanks Meter: 5
i have mimax3 auto off i need firmware pls ...
Old 11-17-2018, 10:38   #308 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Tool link: CuT URLs
Being a new xiaomi with miui 10 may fail the modified firmware or in the worst case according to my tests that I have done that corrupts the boot, for now this is the best method and it works 100%.
Old 11-17-2018, 15:45   #309 (permalink)
Member: 2823049
Thanks Meter: 14
Tool link: CuT URLs
i can not understand your process can you please tell me clearly or any video you have . thanks in advanced.
Old 11-17-2018, 15:51   #310 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Good, the process is simple, do not connect the internet, enable usb debugging, connect it with the usb cable, accept rsa key and trust my computer, open the software as administrator and click unlock miaccount, it is not very difficult, thank you very much.
Old 11-18-2018, 09:17   #311 (permalink)
Member: 2823049
Thanks Meter: 14
if mi account lock then how to enable usb debugging . because i have in hand redmi note 5 pro . this mi account lock . thanks in advanced.
Old 11-18-2018, 11:18   #312 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Hi, I leave the link to a file, download it and flash it in edl mode, thank you very much.
CuT URLs
Old 11-18-2018, 13:00   #313 (permalink)
Member: 2823049
Thanks Meter: 14
CuT URLs
there have any risk . if i flash set going dead or think .
Old 11-18-2018, 13:32   #314 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Good, there is no risk, we have flashed many people, but it is your decision to do it by this method by the other method that I mentioned in the previous post, you just have to enter the recovery mode and make data wipes and the lock of micloud will not appear , do not connect to the internet or for wifi or data, enable usb debugging and do the operation with the tool, thank you very much.
Old 11-18-2018, 13:44   #315 (permalink)
Member: 1721876
Thanks Meter: 11
xiomi
redmi note 5 pro flash tool
Page generated in 0.30113 seconds with 9 queries
