05-21-2018, 17:18 | #1 (permalink) |
Major Poster Join Date: Mar 2012 Location: malda , kolkata , india
Member: 1732186 Status: Offline Sonork: bimanrockstar Thanks Meter: 15 | MI mdi6s (MI Y1) unknown baseband and repair imei 100% solve READ CAREFULLY STEP BY STEP..... for repair imei frst need to open diag port.... To enable Diag Port Dial *#*#717717#*#* and restart Mobile while connected to PC (NO NEED TO WORRY IF SHOW OPEN DIAG PORT FAILED) NO WORKING THIS METHOD 2nd try Open CMD and copy paste as below. adb shell setprop sys.usb.config diag,adb THE PROSSES FOR IMEI REPAIER 1 - Reset efs 2 - Write firmware 3 - write QCN if reset efs not done then downgrade the firmware with this file http://bigota.d.miui.com/8.4.19/miui...5f464e_7.1.zip then u can erase or wipe efs by umt dongle with edl mode... after that set going to bootloop no need to worry...just flash this file china devloper file by mi flash tool... http://bigota.d.miui.com/8.4.26/ugg_...a4779268ad.tgz after flash this set will be okay..but unknown baseband...no need worry bro... nest step just write a good qcn file....unknown baseband will solv...imei will back... qcn - Y1 bimanrockstar - Download - 4shared - Biman Sarkar before write this qcn u need to change the imei no by RBSoft_V1.5 injoy..... its my experience....allresdy 3 set okay with this prosses..... after all prosses imei get back..then u can flash the official firmware press thanks button........ onlyyyyy The imei should be original imei................. |
The Following 8 Users Say Thank You to bimanrockstar For This Useful Post: |
06-28-2018, 11:55 | #3 (permalink) |
Freak Poster Join Date: Jan 2012 Location: Kilis
Member: 1715473 Status: Offline Thanks Meter: 105 | Root Your devices and QPST qcn backup Open adb command and partition modemst1 and modemst2 delete. Edit your qcn new or old imei. Restore qpst to qcn imei repair or change lost imei |
The Following User Says Thank You to nbrios For This Useful Post: |
06-29-2018, 16:32 | #5 (permalink) |
Member: 1715473 Status: Offline Thanks Meter: 105 | please be careful your devices UNLOCKED. 1. Method a.) Root your devices and open qualcomm diag adb shell su setprop sys.usb.config diag,adb b.) Qualcomm imei writer 2.Method way http://forum.gsmhosting.com/vbb/f979...epire-2423694/ this way same qualcomm partation code and delete modemst1 modemst2 fsg. rebuild qcn file edit and restore devices. |
07-19-2018, 13:20 | #6 (permalink) |
Member: 1732186 Status: Offline Sonork: bimanrockstar Thanks Meter: 15 | RBSoft_V1.5...in qualcom tab.select qcn then rt og imei..then click on repair or start...then outomatic creat a inject qcn file in RBSoft_V1.5 file directry...then u rt this qcn.....okay |
