10-12-2016, 15:52 | #1 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 705727 Status: Offline Thanks Meter: 61 | mi redmi 3s prime 2016032 locked i tried with miflash 2016.08.30.0 with normal usb cable it gives error ( this phone requires any special cable) i tried with thus ver land_global_images_V7.5.9.0.MALMIDE_20160805.0000. 29_6.0_global pls post me any tested ver or i need purchase any cable or should i unlock boot loader before flashing |
The Following User Says Thank You to lakshmireddy For This Useful Post: |
10-14-2016, 06:47 | #4 (permalink) | |
No Life Poster Join Date: Oct 2008 Location: Delhi Age: 35
Member: 885719 Status: Offline Sonork: 100.1604802 Thanks Meter: 412 | Quote:
No Need Any special cable just Follow This Process Requirement :- 1. fastboot_edl.zip fastboot_edl.zip 2. MiFlashSetup-Beta.zip MiFlashSetup-Beta.zip Extract and Install Setup Detailed Process :- 1. Install Adb Driver 2. Connect Phone in fastboot mode. 3. Open Extracted Folder of "fastboot_edl.zip" and Open edl.cmd Now Handset go to Emergency Boot Mode and only show red Blink LED on Top Of LCD and your set connect in Qualcomm 9008 Driver. not to worry . 4. Open XiaoMiFlash.exe which you installed earlier. 5. Select Flash File Path 6. Tick Clean All in Bottom of tool 7. Press Flash after flashing complete your handset is on and working and all locks are removed. | |
The Following 3 Users Say Thank You to Athelcute For This Useful Post: |
10-19-2016, 08:10 | #5 (permalink) | |
Member: 705727 Status: Offline Thanks Meter: 61 | Quote:
the phone doesent goes to emergency mode | |
10-24-2016, 21:43 | #11 (permalink) |
Freak Poster Join Date: Jan 2011 Location: Manila Age: 37
Member: 1493085 Status: Offline Sonork: n/a Thanks Meter: 92 | 1. "phone in fastboot mode" hold vol + 2. reboot with command "fastboot reboot" (still hold vol +) 3. in menu, pick "Download" 4. flash with "Miflash 2016.04.01.0(64bit)" 5. i hope this step will help u 6. thank you note : i'm test this step only on win7 64bit without special cable |
The Following User Says Thank You to gwlime For This Useful Post: |
11-15-2016, 06:24 | #14 (permalink) |
No Life Poster Join Date: Jun 2007 Location: India
Member: 523972 Status: Offline Sonork: 100.1596548 Thanks Meter: 1,259 | Please friend help me, I have Redmi 3S Prime handset. Problem is Phone Locked, Phone goes to fast boot mode and edl mode but Qualcomm 9008 Driver port not show. only show ADB Port. how to solve problem? |
11-15-2016, 06:48 | #15 (permalink) | |
Product Supporter Join Date: Mar 2008 Location: India
Member: 718725 Status: Offline Sonork: 100.1604953 QQ 2339690693 Thanks Meter: 6,701 | Quote:
Use Special Cable Or Make Cable Like This Or Try Vol Up And Power Key Than If Menu Show Like This Click Download After Click Download Set Will be In EDL Mode Flash With Mi Flash Tool | |
The Following 6 Users Say Thank You to Prem_India For This Useful Post: |
