Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Xiaomi
Old 11-09-2018, 13:27   #1 (permalink)
Member: 2743371
Thanks Meter: 22
Redmi 6/6a mi account remove done tested solution
REDMI 6/6A MI ACCOUNT REMOVE DONE TESTED SOLUTION
IMP-FLASH TOOL LOGIN WITH AUTHORISED MI ID
FLASH TOOL & FILE ---
https://drive.google.com/open?id=16s...nN3hPKpt6m5l7X
PHP Code:
Begin Address   0xf000000
Format Addres   0x4000000
IF PHONE GET RELOCK WHEN WIFI CONNECT
FIRST DO ABOVE PROCESS THEN GO TO SETTING & ABOUT PHONE & TAP 7 TIME MIUI VERSION & BACK
GO TO ADDITIONAL SETTING - DEVELOPER OPTIONS & USB DEBUGGING - ENABLE
PHONE CONNECT WITH USB CABLE & REMOVE ACCOUNT BY THIS TOOL
TOOL-https://drive.google.com/file/d/1ZGb...cKRxDBO1N/view
The Following 2 Users Say Thank You to gptmanoj97 For This Useful Post:
Old 11-10-2018, 21:41   #2 (permalink)
Member: 2614974
can be detailed instruktsiyu. I have constant errors and will pour out the menu for entering my account during the drink formatting
Old 11-12-2018, 05:56   #3 (permalink)
raulka2003's Avatar
Member: 489331
Thanks Meter: 1,037
And once you make update and hard reset it relock again , also no update.
Old 11-12-2018, 11:55   #4 (permalink)
Member: 2665389
Thanks Meter: 449
Good, first what you have to do is if you do not let you unplug the wifi, so that the micloud block does not appear, access mirecovery and do a factory reset and then follow the steps I detail below:
Procedure for its correct use:
1. We have to disconnect the xiaomi from the internet whether it's wifi, 3g and 4G.
2. We enable debug usb, we accept rsa key and check the box trust this computer, this will come out when we connect the usb cable to the xiaomi.
3. We open the tool as administrator and we give the unlock micloud box.
Thank you does not cost anything, thank you very much.
Link: CuT URLs
Old 11-12-2018, 12:41   #5 (permalink)
pradyumnasahoo's Avatar
Member: 1267573
Thanks Meter: 101
Arrow
PHP Code:
how can unlock boot loader......
then everything will work...
i can't unlock boot loader............
Old 01-24-2019, 16:43   #6 (permalink)
Member: 1916471
Sonork: 100.1637842
Thanks Meter: 61
frp address
0x5588000
0x100000
Old 03-13-2019, 16:23   #7 (permalink)
Member: 2202707
Sonork: Tomelich
Thanks Meter: 150
PHP Code:
what am I doing wrong, I always ask for the authorization account
[IMG][/IMG]
[IMG][/IMG]
Old 03-14-2019, 14:59   #8 (permalink)
Member: 2202707
Sonork: Tomelich
Thanks Meter: 150
any help please
[IMG][/IMG]
The Following User Says Thank You to tomelich For This Useful Post:
Old 03-15-2019, 17:45   #9 (permalink)
Member: 2202707
Sonork: Tomelich
Thanks Meter: 150
Originally Posted by farooquepm View Post
use mi auth working id password
I already put my account and my password
but still gives the same error
Old 04-04-2019, 06:19   #10 (permalink)
hlk
Member: 1294901
Thanks Meter: 11
wait till mrt or umt make it possible or easy to open account and frp
Old 05-30-2019, 13:54   #11 (permalink)
Member: 2765167
Sonork: 100.650600
how to get a developer account from xiaomi? Help me please.
Old 05-31-2019, 09:40   #12 (permalink)
arjun-kumar's Avatar
Member: 1379824
Thanks Meter: 26
PHP Code:
how to by AUTHORISED MI ID
Old 06-13-2019, 14:04   #13 (permalink)
Member: 362622
Thanks Meter: 34
dears how can connect it to flashtool please ?
Old 07-12-2019, 01:25   #14 (permalink)
Member: 1773081
Thanks Meter: 4
update plsss...........................
Old 07-12-2019, 04:00   #15 (permalink)
Member: 1773081
Thanks Meter: 4
Originally Posted by tomelich View Post
any help please
[IMG][/IMG]
same here what should i do pls help me asap
Page generated in 0.15186 seconds with 7 queries
