Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Xiaomi
Old 04-23-2017, 11:50   #1 (permalink)
sagarjais's Avatar
Member: 2355125
Thanks Meter: 39
Redmi Note 4 MI Account Reset by Boot Short Method
LOcked EDL Mode???
No Issue
you can Try this method To connect it in EDL Mode
Open Back Cover
https://ibb.co/dO9ct5
Disconnect Battery
Short These Two Pins Using any mettal wire or Pin
and Connect your phone with normal cable
https://ibb.co/exPAD5
now your phone will be booted in edl mode
you can reset mi account using umt
Use QcFIre By UMT Tool
The Following 3 Users Say Thank You to sagarjais For This Useful Post:
Old 04-26-2017, 18:48   #2 (permalink)
raulka2003's Avatar
Member: 489331
Thanks Meter: 1,093
Read mi note 4 is mtk not qullacom , this trick work for Qualcomm model
Old 04-27-2017, 16:42   #3 (permalink)
sagarjais's Avatar
Member: 2355125
Thanks Meter: 39
just search it again dude
Redmi Note 4 is availbale in two variants
FIrst MTk
and Second on is Qualcomm
and this method is for qualcomm cpu
Any Doubts?
Old 04-30-2017, 07:06   #4 (permalink)
Vahidpappali's Avatar
Member: 2602890
Sonork: NOTINSTALLED
Thanks Meter: 218
FIrst MTk
Any Doubts?
dosent need to open
just need a deep edl cable tested 7 sets
The Following User Says Thank You to Vahidpappali For This Useful Post:
Old 04-30-2017, 07:12   #5 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 722
why not use modified cable?? no need remove back panel.
The Following User Says Thank You to malka4u For This Useful Post:
Old 04-30-2017, 17:28   #6 (permalink)
sagarjais's Avatar
Member: 2355125
Thanks Meter: 39
because modified cable for EDL is also not working in mi Note 4 Qualcomm series
Old 05-02-2017, 11:49   #7 (permalink)
Member: 2602890
Thanks Meter: 218
who says
its working perfectly
tested and done
if yours not working
maybe its your fault
Old 05-03-2017, 07:54   #8 (permalink)
moinuddin111's Avatar
Member: 864102
Sonork: 100.1617637
Thanks Meter: 139
Originally Posted by Vahidpappali View Post
who says
tested and done
i think latest security does now work edl cable
chek it again.
Old 05-03-2017, 10:17   #9 (permalink)
sagarjais's Avatar
Member: 2355125
Thanks Meter: 39
chek it again.
yes boot to edl not working on latest security thats why i have created this thread and shared this method for mi note 4 latest security
Old 06-04-2017, 19:34   #10 (permalink)
khalidahmed's Avatar
Member: 2298142
Thanks Meter: 233
This is apparently a new deepflash cable that is needed to put the device in EDL mode. Instead of shorting the black and green cable, the cable for this one requires shorting the black and white one. EDL mode come
The Following User Says Thank You to khalidahmed For This Useful Post:
Old 12-13-2017, 16:24   #11 (permalink)
Member: 2515283
Sonork: 100.1671440
Thanks Meter: 76
why waste your time complete procedure with UMT
http://www.youtube.com/watch?v=9E7AwseGEII
https://www.youtube.com/watch?v=9E7AwseGEII
please press thanks meter........
Page generated in 0.30657 seconds with 7 queries
