Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Xiaomi
Old 06-15-2017, 07:44   #61 (permalink)
domestik's Avatar
Member: 40118
Thanks Meter: 87
read nvram via SPFT (start_address: 0xab00000, lenght: 0x500000).
Flash any FW via SPFT with format all+download option.
Power on, pass start sequence (you have no imei and no account). Power off. Write back
your nvram via SPFT. Power-on. Profit. No lock, you can enter new account
The Following User Says Thank You to domestik For This Useful Post:
Old 06-21-2017, 07:01   #62 (permalink)
mdalamgir's Avatar
Member: 694638
Thanks Meter: 163
Originally Posted by beaviz View Post
Yes !!! Account Remove Directly TESTED By Me.....
Thanks Brow
After do this ime will be gone
After write any ime mi account will be come.
What is real solution?
Old 06-22-2017, 01:16   #63 (permalink)
Member: 2729342
u can splain that? i dont understand
Old 06-23-2017, 07:57   #64 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 3,958
how to read NVRAM via spft ?
Old 06-23-2017, 14:31   #65 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 3,958
I read via spft but after edit scatter file can't load it , it's says invalid scatter
Old 06-25-2017, 14:33   #66 (permalink)
sagarjais's Avatar
Member: 2355125
Thanks Meter: 42
you can use any chinese box rg Miracle CM2 etc to read NV
after that you have to flash with spflashtool by seleting FormatlAll+Download
then Write that backup NV with Miracle Box
Done
Press Thanks If It Helped
Old 06-25-2017, 16:05   #67 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 3,958
Cm2 not supported to read nv
Old 06-26-2017, 08:29   #68 (permalink)
domestik's Avatar
Member: 40118
Thanks Meter: 87
Why u edit scatter? You've written >6K posts and don't know how to read nvram in SPFT???????????
1. don't edit scatter. load original scatter from original FW for Xiaomi RN4.
2. go to readback.
3. Press "Add".
4. Press on "File". Enter desired filename.
5. Enter start address and lenght.
6. Press "Readback".
I cannot explain easier, if anybody dont understand, run away from cellular phones to wild village.
Old 06-26-2017, 12:30   #69 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 3,958
2. go to readback.
3. Press "Add".
Read the thread again carefully
Man no one knows everything it's doesn't matter 6k poster need help from user.
I know to how to read nvram from sptool , I need to how to write back again via sptool with original scatter file which nvram false
Old 06-26-2017, 16:29   #70 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,339
Xiaomi Mtk variants mi accounts can not be removed permanent unless yu chg its serial number or official service by mi store, Other wise the only solution is you need to remove mi account related apps frm system, But its not permanent if yu flash yur phone it vil lock again.
Ps, Format and flash rebuild imei, Downgrade can not fix this issue
dnt waste yur time on it.
The Following User Says Thank You to jamesjerss For This Useful Post:
Old 06-26-2017, 17:25   #71 (permalink)
domestik's Avatar
Member: 40118
Thanks Meter: 87
It is false!
MTK Redmi Note 3 - we can remove account, MTK Redmi Note 4 - we can remove account. Tested by me, permanent. So don't write nonsense.
Old 06-26-2017, 18:10   #72 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 3,958
Yes someone selling m4 file that's account function totally disable but don't know what will happen after ota update ,
Old 06-26-2017, 18:26   #73 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,339
It is false!
Lol then keep it with yu
Old 06-26-2017, 18:47   #74 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,339
I dnt think so bcz its signed firmware,, if yu modify nd flash system img it end up bootloop.
Old 07-05-2017, 10:23   #75 (permalink)
Member: 2622185
Sonork: 100.1675196
Thanks Meter: 6
i've flashed succuessfully my note 4 pro with sptool followed the instructions below
UnBrick Flash Redmi Note 4 MTK on Locked Bootloader - Redmi Note 4 - Xiaomi MIUI Official Forum
but i am not able to comletely remove mi account
i used miracle box latest update for removing mi account
it says Being Disable Account...
but account is not disabled
as i connect wifi, it agains come with a message "activate device"
any body help.......
Page generated in 0.37591 seconds with 7 queries
