11-14-2019, 15:44 | #1 (permalink) |
Insane Poster Join Date: May 2017
Member: 2712589 Status: Offline Thanks Meter: 6 | MI Note 5 Pro Hang on logo Mobile Read info Reading Device Information...OK Device : Xiaomi Redmi Note 5 [whyred] Software : OPM1.171019.011, V10.2.2.0.OEIMIXM [Thu Mar 14 14:52:10 WIB 2019] Android Ver. : 8.1.0 Patch Level : 2019-03-01 USERDATA : Normal You can use RESET LOCKS to remove Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 4.9.1 Mobile is come with hang on MI logo only no recovry mode only fastboot working i tried to flash mobile and it was giving me error i mean emmc was carpet not able to take full flash and I changed that old EMMC to new One dead Mobile Emmc now mobile is taking full flash after change that Emmc but problem remain same here Pleas help me what have to do next It may hardware issue(cpu) or software issue please same one suggest me Flashing info Operation : Flash Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM17) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Writing [storsec.mbn] -> [storsec] ...Done Writing [storsec.mbn] -> [storsecbak] ...Done Writing [rpm.mbn] -> [rpm] ...Done Writing [rpm.mbn] -> [rpmbak] ...Done Writing [hyp.mbn] -> [hyp] ...Done Writing [hyp.mbn] -> [hypbak] ...Done Writing [pmic.elf] -> [pmic] ...Done Writing [pmic.elf] -> [pmicbak] ...Done Writing [cmnlib.mbn] -> [cmnlib] ...Done Writing [cmnlib.mbn] -> [cmnlibbak] ...Done Writing [cmnlib64.mbn] -> [cmnlib64] ...Done Writing [cmnlib64.mbn] -> [cmnlib64bak] ...Done Writing [abl.elf] -> [abl] ...Done Writing [abl.elf] -> [ablbak] ...Done Writing [devcfg.mbn] -> [devcfgbak] ...Done Writing [devcfg.mbn] -> [devcfg] ...Done Writing [tz.mbn] -> [tz] ...Done Writing [tz.mbn] -> [tzbak] ...Done Writing [mdtpsecapp.mbn] -> [mdtpsecapp] ...Done Writing [mdtpsecapp.mbn] -> [mdtpsecappbak] ...Done Writing [keymaster.mbn] -> [keymaster] ...Done Writing [keymaster.mbn] -> [keymasterbak] ...Done Writing [BTFM.bin] -> [bluetooth] ...Done Writing [xbl.elf] -> [xbl] ...Done Writing [xbl.elf] -> [xblbak] ...Done Writing [dspso.bin] -> [dsp] ...Done Writing [mdtp.img] -> [mdtp] ...Done Writing [splash.img] -> [splash] ...Done Writing [persist.img ] -> [persist]...Done Writing [NON-HLOS.bin] -> [modem] ...Done Writing [boot.img] -> [boot] ...Done Writing [recovery.img] -> [recovery] ...Done Writing [cache.img ] -> [cache]...Done Writing [system.img ] -> [system]...Done Writing [vendor.img ] -> [vendor]...Done Writing [cust.img ] -> [cust]...Done Writing [userdata.img ] -> [userdata]...Done Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup0.bin] -> [BackupGPT] ...Done Applying Patches................Done Resetting device...Done Operation Finished. QcFire Ver. 4.9.1 Even after flash mobile is on same condtion |
11-14-2019, 17:31 | #2 (permalink) | |
Product Supporter Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Quote:
11-15-2019, 10:16 | #4 (permalink) |
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Good, you always have to try first with miflash and more with these xiaomi models that are older or have their certain time on the market, with the new is already another story, but if you have a xiaomi account, well go ahead always with miflash, another tip, when flashees with umt or another tool you should not flash full partitions, where the error may come or it will remain in bootloop. |
11-15-2019, 15:07 | #5 (permalink) | |
Member: 2712589 Status: Offline Thanks Meter: 6 | Quote:
i tried to flash from mi flash tool i was giving error on EDL flashing time Then i tried to flash from fastboot mode but in fastboot mode mobile is not able to connect to PC i changed that cc strip even not going to connect from fastboot mode to flash.... Mi flash toll LOG [17:59:50]:lsusb path:"C:\Users\samee\Downloads\MiFlash20181115\MiF lash20181115\Source\ThirdParty\Qualcomm\fh_loader\ lsusb.exe" [17:59:51]:ls ubs :Qualcomm HS-USB QDLoader 9008 (COM17) [17:59:52]:GetScriptDevices [17:59:54]:add device COM17 index 17 [17:59:58]:lsusb path:"C:\Users\samee\Downloads\MiFlash20181115\MiF lash20181115\Source\ThirdParty\Qualcomm\fh_loader\ lsusb.exe" [17:59:58]:ls ubs :Qualcomm HS-USB QDLoader 9008 (COM17) [17:59:59]:GetScriptDevices [17:59:59]:FlashingDevice.flashDeviceList.Remove COM17 [17:59:59]:add device COM17 index 17 [17:59:59]:Thread start,thread id 17,thread name COM17 [18:05:47]:Login failed. errcode:2 lasterr:The system cannot find the file specified [18:05:48]:Thread stopped, thread id 17, thread name COM17 | |
