Redmi6 pro nv data is corrupted imei 00 bootloader lock no bacup efs Qcn %100 ok Redmi6 pro nv data is corrupted imei 00 bootloader lock no bacup efs Qcn %100 ok hanging mi revovery nv data is corrupted 1 open phone edl mod testpoint Download file S2_FACTORY_LLDLMC9_T519_0424_eraseNV.zip https://drive.google.com/file/d/1ToJZIt5fdg-tA0Z-arvOJiFX1MZ0nFHG/view4"] 2 Open Chimera tool load firmware phone dead no problem try edl mod test point download file http://bigota.d.miui.com/8.11.15/***...2bdaf10aae.tgz 3 Open Chimera tool load firmware nv data is corrupted problem solved wait open phone menu imei 0000 or hidden 4 İmei repair developer options open *#*#717717#*#* diag open enabled restart phone download prog WriteDual IMEI Repair Tool https://yadi.sk/d/NgU8c4Z53UAnNu phone connect pc diag port imei2 write imei 1: 0 imei 2: 3540xxxxxxxxxxx restart phone imei control imei 1: 0 imei 2: 3540xxxxxxxxxxx no network problem 5 Write Redmi 6 pro Eng Patched.qcn Download QPST.2.7.477 https://mirrors.lolinet.com/software...ST.2.7.477.zip 1 Open Qpst Configuration 2 Starst clients 3 Software download 6 restore Redmi 6 pro Eng Patched.qcn restart phone network ok phone is ok langue cn not global 6Phone bootloader lock new mi ac**** is phone mi unlock tool and unlock bootloader 7 twrp or global rom https://www.youtube.com/watch?v=R21ndzpe5V4 twrp 3.2.2.0 https://drive.google.com/file/d/1fRz...XhT6-4AnV/view adb 1.4.3 https://drive.google.com/file/d/1RpC...clZSe9919/view Installation: 1. Setup ADB/Fastboot 2. Download the twrp from here : download 3. Power off your device. 4. Hold volume down + power button to boot into the bootloader. 5. Connect your device to your PC with a USB cable. 6. Open the command prompt on your PC. 7. Type cmmand : fastboot flash recovery "filename of recovery.img" done If u have anti rollback enabled : first method: fastboot boot "recovery.img" in that booted twrp recovery flash recovery .img again and it will work 2nd method: fastboot flash antirbpass "recovery.img" I recommend u guys to follow the 2nd Method.Easy and perfectly working.................................... 8 glabal rom multi langue xiaomi.eu_multi_HM6Pro_V10.0.2.0.ODICNFH_v10-8.1.zip https://androidfilehost.com/?fid=1322778262904011180 Open twrp TWRP click button Install ZIP. Select the SD and select the firmware file. Confirm with swipe to the right. After the installation is complete, you will see an offer to reboot into the system. good luck |
Redmi 6 pro Eng Patched.zip PASS: CEPHASTANESI https://drive.google.com/file/d/1vB4...ew?usp=sharing |
2 Open Chimera tool load firmware phone dead no problem try edl mod test point http://bigota.d.miui.com/8.11.1/****...8a8b5c7d75.tgz |
1 Attachment(s) 2 Open Chimera tool load firmware phone dead no problem try edl mod test point |
