09-08-2016, 16:39 | #1 (permalink) |
Freak Poster Join Date: Mar 2013
Member: 1892311 Status: Offline Thanks Meter: 12 | Repair Dead Boot Xiaomi Redmi Note 3 Repair for Xiaomi Redmi Note 3 HOW TO REPAIR Xiaomi Redmi Note 3 Dead Boot No Connect USB Drives qualcomm hs-usb diagnostics 900e CPU qualcomm Keep it up team Last edited by lotfy; 09-08-2016 at 16:47. |
The Following User Says Thank You to lotfy For This Useful Post: |
09-11-2016, 08:50 | #3 (permalink) |
Freak Poster Join Date: Sep 2014 Location: I . N . D . I . A Age: 45
Member: 2255989 Status: Offline Sonork: 1001675246 Thanks Meter: 47 | How to flash . See here http://forum.gsmhosting.com/vbb/f979...32bit-2102234/ |
The Following 2 Users Say Thank You to Hamid memon786 For This Useful Post: |
09-12-2016, 11:01 | #4 (permalink) | |
Freak Poster Join Date: May 2007 Location: philippines
Member: 517175 Status: Offline Sonork: none Thanks Meter: 44 | Quote:
exact procedure but need to dismantle and connect the testpont... to recognized the flasher.. used 64bit os...and used the latest MiFlash Tool | |
02-08-2017, 13:41 | #7 (permalink) |
No Life Poster Join Date: Jul 2016 Location: Gods.On.Country
Member: 2602890 Status: Offline Sonork: NOTINSTALLED Thanks Meter: 230 | I GOT SAME PROBLEM DRIVER SHOW qualcomm hs-usb diagnostics 900e BUT FLASH TOOL NOT RECOGAGNISE WHAT I DO IS HOLD 3 SWITCHES TOGETHR FOR LONG TIME THEN I CONNECT IT IT SHOW qualcomm hs-usb diagnostics 9008 TRY IT USE DEEP CABLE |
04-14-2018, 06:26 | #10 (permalink) |
Member: 2602890 Status: Offline Sonork: NOTINSTALLED Thanks Meter: 230 | |
07-21-2020, 11:48 | #11 (permalink) |
Freak Poster Join Date: Dec 2019 Location: multan
Member: 2940758 Status: Offline Thanks Meter: 12 | flashed on umt q c fire Operation : Flash Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM30) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.0.5 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_022]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Writing [dummy.img] -> [switch] ...Done Writing [storsec.mbn] -> [storsec] ...Done Writing [storsec.mbn] -> [storsecbak] ...Done Writing [rpm.mbn] -> [rpm] ...Done Writing [rpm.mbn] -> [rpmbak] ...Done Writing [hyp.mbn] -> [hyp] ...Done Writing [hyp.mbn] -> [hypbak] ...Done Writing [cmnlib.mbn] -> [cmnlib] ...Done Writing [cmnlib.mbn] -> [cmnlibbak] ...Done Writing [cmnlib64.mbn] -> [cmnlib64] ...Done Writing [cmnlib64.mbn] -> [cmnlib64bak] ...Done Writing [keymaster.mbn] -> [keymaster] ...Done Writing [keymaster.mbn] -> [keymasterbak] ...Done Writing [pmic.elf] -> [pmic] ...Done Writing [pmic.elf] -> [pmicbak] ...Done Writing [BTFM.bin] -> [bluetooth] ...Done Writing [devcfg.mbn] -> [devcfg] ...Done Writing [devcfg.mbn] -> [devcfgbak] ...Done Writing [abl.elf] -> [abl] ...Done Writing [abl.elf] -> [ablbak] ...Done Writing [dummy.img] -> [misc] ...Done Writing [xbl.elf] -> [xbl] ...Done Writing [xbl.elf] -> [xblbak] ...Done Writing [tz.mbn] -> [tz] ...Done Writing [tz.mbn] -> [tzbak] ...Done Writing [dspso.bin] -> [dsp] ...Done Writing [logo.img] -> [logo] ...Done Writing [persist.img] -> [persist] ...Done Writing [boot.img] -> [boot] ...Done Writing [recovery.img] -> [recovery] ...Done Writing [NON-HLOS.bin] -> [modem] ...Done Writing [cache.img ] -> [cache]...Done Writing [cust.img ] -> [cust]...Done Writing [system.img ] -> [system]...Done Writing [userdata.img ] -> [userdata]...Done Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup0.bin] -> [BackupGPT] ...Done Applying Patches................Done Resetting device...Done Operation Finished. QcFire Ver. 5.6 |
