Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Xiaomi
Old 01-23-2020, 20:20   #1 (permalink)
Member: 2942817
Unbrick Pocophone, help!
has how to bypass mi account authentication? i have a dead pocophone in need of an account, i paid for someone doing the flash with UFI Tools, but he stole my money and did not solve the problem, is there a safer way?
Old 01-24-2020, 10:36   #2 (permalink)
Member: 2665389
Thanks Meter: 1,392
Good, with the files that are online in zip or tgz format you have to compress it and the chimera tool pro software, it is the only solution there is, you do not need credits, nor authorized xiaomi account, you test point and unlock the bootloader, remove micloud through twrp or revive the xiaomi, the servers do not work and the other softwares that go with credits do not work because they depend on a server and are down.
The Following 2 Users Say Thank You to Franky_36 For This Useful Post:
Old 01-24-2020, 15:25   #3 (permalink)
Crazy Poster
Member: 2925373
Sonork: goldengsm
Thanks Meter: 12
Will you please tell us how exactly to flash xiaomi phones by Chimera .How to compress the files and to flash them without authorization.
Old 01-24-2020, 19:46   #4 (permalink)
Member: 2665389
Thanks Meter: 1,392
Good, entering the page of chimera tool comes out all the models that are supported and as I said you do not need an authorized xiaomi account, nor credits and the way of connection in edl mode like all qualcomm.
Way to compress files or folders to tgz:
Good, like compressing a file or folder in tgz format without programs.
1. we locate the folder or file, for example downloads, shift and right button and open cmd or power shell and copy and paste this command:
tar czvf archivo.tar.gz /archivo/carpeta/*
And we only have to edit it and drag the folder and it would be as in the screenshot:
Compressing file, see screenshot:
Result as you will see in the following screenshot a file or folder is compressed to the tgz format:
There is no file weight limitation
I hope it has served you
Old 01-24-2020, 21:29   #5 (permalink)
Crazy Poster
Member: 2925373
Sonork: goldengsm
Thanks Meter: 12
First thank you that you are trying to help everybody.One thing i don't understand.Do we need unlocked bootloader to flash Xiaomi phones with Chimera?If only phones with unlocked bootloader are supported ,then we can't repair phones that are with locked bootloader and only get in fastboot mode.Then the only solution is to flash the phone in EDL mode with some of the boxes with credits to unbrick it,then we have to unlock its bootloader in official way and then we can flash it with Chimera or another tools if we want to convert it from CN to Global version?
Old 01-25-2020, 10:52   #6 (permalink)
Member: 2665389
Thanks Meter: 1,392
Good, you do not need to have the bootloader unlocked, if you need it because it is effective for example to activate the diag port, remove micloud by the TWRP method this method is the most effective and without relock, to convert a global Chinese phone to global version, but for normal operations you don't need the unlocked bootloader, you do test point and flash, frp, etc., not if I explained myself well so that you understand it.
Old 01-25-2020, 10:58   #7 (permalink)
Crazy Poster
Member: 2925373
Sonork: goldengsm
Thanks Meter: 12
I have Chimera tool with me but if i try to flash fastboot rom into the phone ,the software tells me that bootloader is locked and i can't flash it.The phone is xiaomi 8se and its from the list of supported models by Chimera.The phone only get into fastboot mode ,can't get into recovery mode.What should i do to flash it with Chimera?
Sent from my iPhone using Tapatalk
Old 01-25-2020, 12:07   #8 (permalink)
Member: 2665389
Thanks Meter: 1,392
Good, as I told you in edl mode, you have to do test point and the file has to be in tgz or zip format.
Another method is to do it by isp pinout or by emmc, there is no relock and it works perfectly, that is, if you have to have experience in welding and extracting emmc in case you do it for one or the other and also logically have a box for ips pinout and emmc
Old 01-25-2020, 13:47   #9 (permalink)
Crazy Poster
Member: 2925373
Sonork: goldengsm
Thanks Meter: 12
Brother you deserve billion thanks.I didn't know that Chimera supports xiaomi in Edl mode.My phones are repaired thanks to you.One main thing that all the users must to know that xiaomi is edl mode drivers dependent.
Old 01-25-2020, 17:10   #10 (permalink)
Member: 2665389
Thanks Meter: 1,392
Good, that should be known by any user or technician who is dedicated to this, is nothing new.
Old 01-27-2020, 17:20   #11 (permalink)
Member: 2942817
it didnít work, i donít know what to do, it seems i lost my phone
thanks for helping
Preparing Qualcomm programmer
Gathering device info
Downloading Qualcomm programmer
Connecting to Qualcomm programmer
Failed to prepare Qualcomm programmer
Old 01-27-2020, 17:40   #12 (permalink)
Member: 2665389
Thanks Meter: 1,392
thanks for helping
Good, have you done test point ?, In what format is the file you are going to flash ?, You also have to check that the Xiaomi model is supported, please read previous post, it may not be that many users that I include us It works and it doesn't work for you, something doesn't match.
Old 01-27-2020, 20:18   #13 (permalink)
Crazy Poster
Member: 2925373
Sonork: goldengsm
Thanks Meter: 12
Brother try to install drivers from UMT dongle QC fire,and then try to connect it to Chimera.Check you cable connection,prepare test point and try again.
Page generated in 0.32679 seconds with 7 queries
