Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Xiaomi
Old 05-06-2016, 01:44   #1 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,329
Xiaomi Note 3 Unbrick, Firmware & Guides [Qualcomm]
Xiaomi Note 3 Unbrick, Bootloader Unlock, Firmware & Guides
To boot into edl mode try this command
fastboot boot-edl
Important:Try on windows 64 bit OS as windows 32 bit not working properly at the movement.
Note: This phone can not be flashed via fastboot as its locked bootloader so
you can only flash via EDL mode
Tools & Firmware's:
Flash Tool MiFlash_2016.03.30.exe
Stock Firmwares:
China Stable (V7.2.2.0) : Download Here
Global Stable (V7.1.8.0) : Download Here
Latest:
China Stable (V7.2.3.0) : Download Here
Global Stable (V7.2.3.0) : Download Here
Custom Recovery & Supersu.zip
Twrp Recovery
Other:
Edited fixed flash_all.bat and rawprogram0.xml
Procedure 1 :Flashing guide for Bricked Phone with Locked Boot-loader
Note: This guide vil show you how to Reboot Into EDL mode when you re on bootloop
on MI Logo or with 3 Dots.
Manual method to get EDL Mode:
* 1st you have to power off your phone,In some case if unable to power off then you have to wait until it discharge and power off
otherwise you have to open the mobile and remove battery to power off your phone.
* If you power off your phone by discharging then before start charge your battery again to least 25 to 40%.
* Disconnect yur phone form charger.
* Now Important Step, Connect usb cable and immediately press both Vol Keys or press both the vol keys nd connect the usb to Get EDL mode.
if any thing goes wrong it vil show mi logo or boot it to test mode.
if its successfully done your phone will be detected in device manager as
"Qualcomm HSUSB QLoader 9008"
If you see QHUSB_BULK in device manager update the qualcomm driver from mi-flash tool Installed path.
Note: In windows 64 bit Disable Driver Signature Enforcement before update Driver
otherwise it vil not install.
If fully hard bricked, you have to disassemble your phone and use test point to get EDL mode.
* Disconnect all the cables and flat cables
* Reconnect only Battery Display and USB
* Connect the phone to PC, open Mi Flash and load the ROM.
* Then short the points now your device should detect as EDL mode
Flashing Method By Mi Flash Tool:
* Extract the firmware.
* Run mi flash tool and show the path where you extracted the firmware folder.
* Goto Advance tab and select files lik gvn in the below image.
* Now Press Refresh and You should see you phone com ported detected.
* At last Press Flash nd it should Flash your Phone.
Note :After its Done Manually Reboot.
If you face same error like below given
"The system can not find the file specified (0x80070002: Max buffer sector is 256)"
Replace with edited fixed flash_all.bat and rawprogram0.xml and try again
____________________________________________
Procedure 2: Soft bricked & adb driver detected Phones.
* Run this Command to get EDL mode
adb reboot edl
* if its successfully done your phone will be detected in device manager as below given
* Run MI Flash Tool Show the extracted firmware folder path.
* Press Refresh you should see your device port detected.
* Press flash after complete reboot your device.
The Following 18 Users Say Thank You to jamesjerss For This Useful Post:
Old 05-12-2016, 09:01   #2 (permalink)
rekha1255's Avatar
Member: 333796
Sonork: 100.1587155
Thanks Meter: 80
adb reboot edl
not working
set hang on mi Logo
fastboot & ADB working well but cant go in EDL mode
its alo not working -
" * Now Important Step, Connect usb cable and immediately press both Vol Keys or press both the vol keys nd connect the usb to Get EDL mode.
Old 05-12-2016, 10:57   #3 (permalink)
rekha1255's Avatar
Member: 333796
Sonork: 100.1587155
Thanks Meter: 80
when i make jumper the red light blinking only no ask for driver
Old 05-22-2016, 13:38   #4 (permalink)
Member: 1086393
Thanks Meter: 768
1)"adb reboot edl "not working, phone automatically reboot to normal screen.
2)when i try to insert usb and immediately pressing vol up , it just stuck on logo.
3)volup+ down and insert usb, not working too.
My phone problem is "phone lock"
Need solution
Old 05-22-2016, 19:27   #5 (permalink)
i was darling's Avatar
Member: 1114281
Sonork: 100.1651778
Thanks Meter: 74
Need solution
Mi note 3 cable pinout
Old 05-24-2016, 13:01   #6 (permalink)
Member: 2528503
Sonork: 1670792
Thanks Meter: 68
how to hard reset Xiaomi Note 3 jamess bro need help
Xiaomi Note 3 is locked by pattern ,is there any way to hard reset this above model ,is that we need to flash complete flash this model to remove pattern also ??????
Old 05-24-2016, 14:03   #7 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,329
Yes you hav to flash to remove security locks.
Also use 64bit os to flash nd modified usb ( boot cable) if unable to put in qualcomm mode
Old 05-24-2016, 14:38   #8 (permalink)
Member: 2528503
Sonork: 1670792
Thanks Meter: 68
am using 32bit bro is that not possible to flash with 32bit & one more thing can we use spd miracle boot key as boot cable if not what changes to be done plz help >???
Old 06-12-2016, 21:02   #9 (permalink)
Member: 2536535
Thanks Meter: 2
Flash Successful
But The problem is FRP
My Device Is Protected with MI Account
Ned The Mi Account Removing Solution
Old 06-22-2016, 15:04   #10 (permalink)
Member: 1086393
Thanks Meter: 768
Originally Posted by awadheshonwork View Post
Flash Successful
Have you found the solution?
I have the same problem after flashing it ask for mi account.
need help
Old 07-11-2016, 12:20   #11 (permalink)
Member: 911173
Sonork: 1648990
Thanks Meter: 20
HOW TO MAKE XIAOMI DEEP FLASH CABLE
make this cable - https://www.youtube.com/watch?v=DJZ6Ka7mrIA
1. Download miflash platform: ????ROM?? - ??????????MIUI????? - ???????? - ????????
2. The driver download: ????????? - ????????
3. Download the corresponding models of the original data
4. Operate MIFLASH, it is best to use 64 - bit WINDOWNS system
5. Phone in FASTBOOT mode, mobile ...... XIAO MI depth flash cable ........computer USB port
6. Press the phone ON/OFF button, When closing the phone , pls immediately press the switch of the cables about 8 seconds, , and see the computer in the device manager to recognize to port 9008,
indicates success into the depth of the flash mode
7. Use MIFLASH original platform flash
The Following User Says Thank You to manaswb For This Useful Post:
Old 08-08-2016, 14:13   #12 (permalink)
Crazy Poster
Member: 2238121
Thanks Meter: 5
flashing error in edl mode
reached the end of the file.(0x80070026: receiving hello packet getting this error
The Following User Says Thank You to Shafik151986 For This Useful Post:
Old 08-12-2016, 14:40   #13 (permalink)
AHAMEDPONMALA's Avatar
Member: 723178
Thanks Meter: 37
thhis test point methord not worked to me any body try it
to connect edl mode modified usb cable mustneed or no?
Old 08-20-2016, 11:49   #14 (permalink)
loniryan's Avatar
Member: 2279944
Sonork: not avaliable
Thanks Meter: 120
no need any cable or dissembly phone....just boot in fastboot, download and open the ''modified fastboot tool'' from emui homepage....than click and enjoy...this tool rebots your phone to edl from usb
Old 11-29-2016, 07:55   #15 (permalink)
Member: 1090178
Thanks Meter: 3
Dear how open mi account
The Following User Says Thank You to shyam23singh For This Useful Post:
Page generated in 0.40029 seconds with 7 queries
