08-21-2015, 21:21 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Xiaomi Redmi 1s Fastboot Firmware,Flashing Guide, Dead Recover Xiaomi Redmi 1s Official Fast Boot Firmware Redmi 1S WCDMA Stable Version (Singapore) JHCMIBL50.0 Redmi 1S WCDMA Stable Version (Malaysia) JHCMIBL50.0 Redmi 1S WCDMA Stable Version (Philippines) JHCMIBL50.0 Redmi 1S WCDMA Stable Version (India) JHCMIBL50.0 Redmi 1S WCDMA Stable Version (India) JHCMIBH45.0 Redmi 1S WCDMA Stable Version (Indonesia) JHCMIBL50.0 Flash Tool Here Procedure For Flashing Manually: * Install MiPhone flasher * You can find Required drivers in MiPhone flasher installed path * After Download firmware Extract it * Change the extracted files extension to .rar nd extract again * Connect your Device in fastboot Mode * Run flash_all.bat file frm extracted Folder Procedure for flash via Flashtool: * Run flash tool * Browse nd select the extacted flash file Folder * Connect yur device in fastboot mode * Press refresh in the flash tool * After yur get detected by flash tool hit flash. Dead Recover Procedure * Connect your device to your pc * Goto Device Manager Device should detect as QHSUB_BULK * Manually update this driver (Driver path C:\Program Files\Xiaomi\MiPhone\Qualcomm) * Reboot pc * Run miflash tool goto advance * Select files like below givn in the picture * Press ok nd hit refresh Device vil detect press flash Note: Before Qualcomm driver installation disable Driver signature enforcement Last edited by jamesjerss; 02-01-2017 at 20:47. |
The Following 5 Users Say Thank You to jamesjerss For This Useful Post: |
08-21-2015, 22:59 | #2 (permalink) |
No Life Poster Join Date: Sep 2008 Location: India
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | all link has ( sensor / filter ) words gone as asterisk only so kindly allow them or edit link in 1 txt attachments Thanks for your great help. |
The Following User Says Thank You to kariakala For This Useful Post: |
08-28-2015, 15:03 | #5 (permalink) |
No Life Poster Join Date: Apr 2008 Location: inside forum
Member: 759477 Status: Offline Sonork: 100.1618763 Thanks Meter: 111 | Bro i am sorry asking this question in this section what about YUREKA phones those dead after full flash & not detecting in pc only red light when insert usb without battery |
The Following User Says Thank You to mediapeople For This Useful Post: |
01-25-2016, 12:07 | #14 (permalink) |
Freak Poster Join Date: Apr 2011 Location: punjab
Member: 1562820 Status: Offline Sonork: [email protected] Thanks Meter: 32 | my redmi 1s relink driver show only |
The Following User Says Thank You to satwindershine For This Useful Post: |
01-25-2016, 12:09 | #15 (permalink) |
Member: 1562820 Status: Offline Sonork: [email protected] Thanks Meter: 32 | com port show not come fastboot connected cable show qualicum driver |
