Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Xiaomi
Old 08-21-2015, 21:21   #1 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Xiaomi Redmi 1s Fastboot Firmware,Flashing Guide, Dead Recover
Xiaomi Redmi 1s
Official Fast Boot Firmware
Redmi 1S WCDMA Stable Version (Singapore) JHCMIBL50.0
Redmi 1S WCDMA Stable Version (Malaysia) JHCMIBL50.0
Redmi 1S WCDMA Stable Version (Philippines) JHCMIBL50.0
Redmi 1S WCDMA Stable Version (India) JHCMIBL50.0
Redmi 1S WCDMA Stable Version (India) JHCMIBH45.0
Redmi 1S WCDMA Stable Version (Indonesia) JHCMIBL50.0
Flash Tool Here
Procedure For Flashing Manually:
* Install MiPhone flasher
* You can find Required drivers in MiPhone flasher installed path
* After Download firmware Extract it
* Change the extracted files extension to .rar nd extract again
* Connect your Device in fastboot Mode
* Run flash_all.bat file frm extracted Folder
Procedure for flash via Flashtool:
* Run flash tool
* Browse nd select the extacted flash file Folder
* Connect yur device in fastboot mode
* Press refresh in the flash tool
* After yur get detected by flash tool hit flash.
Dead Recover Procedure
* Connect your device to your pc
* Goto Device Manager Device should detect as QHSUB_BULK
* Manually update this driver (Driver path C:\Program
Files\Xiaomi\MiPhone\Qualcomm)
* Reboot pc
* Run miflash tool goto advance
* Select files like below givn in the picture
* Press ok nd hit refresh Device vil detect press flash
Note: Before Qualcomm driver installation disable Driver signature enforcement
The Following 5 Users Say Thank You to jamesjerss For This Useful Post:
Old 08-21-2015, 22:59   #2 (permalink)
Member: 851193
Sonork: 100.1615313
Thanks Meter: 348
all link has ( sensor / filter ) words gone as asterisk only
so kindly allow them or edit link in 1 txt attachments
Thanks for your great help.
The Following User Says Thank You to kariakala For This Useful Post:
Old 08-21-2015, 23:02   #3 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Will upload tnkx for the info m8
The Following 2 Users Say Thank You to jamesjerss For This Useful Post:
Old 08-22-2015, 14:47   #4 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Links has been updated n 1st post
Old 08-28-2015, 15:03   #5 (permalink)
mediapeople's Avatar
Member: 759477
Sonork: 100.1618763
Thanks Meter: 111
Bro i am sorry asking this question in this section what about YUREKA phones those dead after full flash & not detecting in pc only red light when insert usb without battery
The Following User Says Thank You to mediapeople For This Useful Post:
Old 10-02-2015, 17:09   #6 (permalink)
Member: 737502
Thanks Meter: 11
where is the NvBoot script i cant found this file in this firmware
The Following User Says Thank You to lasertalk2k4 For This Useful Post:
Old 11-14-2015, 11:34   #7 (permalink)
ashad77's Avatar
Member: 1525116
Thanks Meter: 68
100% working solution
here is result.....
[IMG][/IMG]
[IMG][/IMG]
The Following User Says Thank You to ashad77 For This Useful Post:
Old 11-14-2015, 11:48   #8 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
No need NvBoot script leave it blank.
The Following User Says Thank You to jamesjerss For This Useful Post:
Old 12-04-2015, 07:56   #9 (permalink)
Member: 1910376
Thanks Meter: 50
link not working flash tool
The Following User Says Thank You to khothbharat For This Useful Post:
Old 12-09-2015, 10:17   #10 (permalink)
dineshras's Avatar
Member: 2185083
Sonork: 100.1670782:dineshras
Thanks Meter: 185
yes link not working flash tool
The Following User Says Thank You to dineshras For This Useful Post:
Old 12-09-2015, 11:08   #11 (permalink)
Member: 1784493
Thanks Meter: 20
miflash tool
Redmi 1s Dead or Bricked - Guide to Fix it
The Following User Says Thank You to shankar99 For This Useful Post:
Old 12-10-2015, 06:42   #12 (permalink)
dineshras's Avatar
Member: 2185083
Thanks Meter: 185
error
MI MODEL NAME 2013029
Old 01-23-2016, 12:23   #13 (permalink)
abishekkumar's Avatar
Member: 1761355
Sonork: 0818211
Thanks Meter: 105
Old 01-25-2016, 12:07   #14 (permalink)
satwindershine's Avatar
Member: 1562820
Thanks Meter: 32
my redmi 1s relink driver show only
The Following User Says Thank You to satwindershine For This Useful Post:
Old 01-25-2016, 12:09   #15 (permalink)
Member: 1562820
Thanks Meter: 32
com port show not come fastboot connected cable show qualicum driver
Page generated in 0.37391 seconds with 8 queries
