Prototip4ik | 08-14-2019 13:22 | xiaomi redmi 4 pro need log emmc Salute colleagues !!! Give if anyone has a dump with redmi 4 Pro with an unlocked bootloader and a log with configuration? (need Boot, Aboot, abootbak and log)
My emmc is dead :rolleyes: Quote:
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Unknown eMMC
Page size : 512 B
Block size : 512 B
Block count : 787769408
Size : 375.64 GB (384653.03 MB)
CID Info
CID : 3C3C000006010015FFFFFFFFFFFFFF01
Manufacturer ID : 0X3C
Device/BGA : Device (removable)
OEM/Application ID : 0X00
Product name :
Product revision : 15.15
Product serial number : (hex) FFFFFFFF
Manufacturing date : 15/2012
CSD Info
CSD : 5A5A00000000000000000000000000E9
CSD structure : CSD version No. 1.1
SPEC version : Allocated by MMCA
Data read access time1: 0.0005 ms
TRAN speed : 0 MHz
READ block length : 1 Bytes
WP group enable : NO
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Erase block size : 91136 Kbytes
Boot1 size : 4864 Kbytes
Boot2 size : 4864 Kbytes
RPMB size : 3712 Kbytes
Partition config : (0x50) 01010000
Boot partition enable : Boot partition 2
(Bus width = 8Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
Boot bus conditions : (0xEE) 11101110
Boot bus width : x8 (sdr/ddr) bus width in boot operation mode
Reset boot bus conditions : Retain BOOT_BUS_WIDTH and BOOT_MODE values after boot operation
Boot mode : Use single data rate + High Speed timings in boot operation
RST_n function : (0x02) RST_n signal is permanently disabled
Max enhanced data size: 199163904 Kbytes
Partitions attribute : 0x7D
Part setting completed: 0x5D
GP partition 1 size : 3328 MB
GP partition 2 size : 2240 MB
GP partition 3 size : 1344 MB
GP partition 4 size : 1344 MB
Enhanced area size : (0x60000000) 1536 MB
Enhanced area start : (0xEF84B400) 3832 MB
---------------------------------------------------------------Searching Android build info...
Not found
