11-05-2018, 14:45 | #1 (permalink) |
Insane Poster Join Date: Feb 2014 Location: VietNam
Member: 2119732 Status: Offline Sonork: No More Used Thanks Meter: 22 | Xiaomi redmi 5 plus Micloud miui 10 |
11-05-2018, 15:27 | #2 (permalink) | |
Product Supporter Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Quote:
Link firmware modified: CuT URLs This is the tool that I mention: Procedure for its correct use: 1. We have to disconnect the xiaomi from the Internet, be it wifi, 3g and 4G. 2. We enable debug usb, we accept the rsa key and check the box to trust this computer, this will come out when we connect the usb cable to the xiaomi. 3. Open the tool as administrator and we will give you the unlock box of micloud. Tool link: CuT URLs Thank you does not cost anything, thank you very much. | |
The Following User Says Thank You to Franky_36 For This Useful Post: |
11-13-2018, 03:29 | #3 (permalink) | |
Member: 2119732 Status: Offline Sonork: No More Used Thanks Meter: 22 | Quote:
11-13-2018, 12:32 | #4 (permalink) |
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Good, it is not necessary for anything to unlock the bootloader, you just have to enable debug usb, in case the xiaomi does not let you disable the wifi by blocking micloud, turn off the phone and access the recovery, factory reset and the xiaomi restarts without blocking micloud, activates usb debugging, connects the mobile to the usb cable and follows the instructions previously said by me, thank you very much. |
The Following 2 Users Say Thank You to Franky_36 For This Useful Post: |
11-14-2018, 10:56 | #6 (permalink) |
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Hi, check if you can disable the wifi, if you do not turn off the phone you enter the recovery and factory reset, when you restart the phone the message or the micloud account lock will have disappeared and now follow these steps: Procedure for its correct use: 1. We have to disconnect the xiaomi from the Internet, be it wifi, 3g and 4G. 2. We enable debug usb, we accept the rsa key and check the box to trust this computer, this will come out when we connect the usb cable to the xiaomi. 3. Open the tool as administrator and we will give you the unlock box of micloud. Tool link: CuT URLs Thank you does not cost anything, thank you very much. |
11-19-2018, 18:31 | #10 (permalink) |
Member: 2665389 Status: Offline Thanks Meter: 2,342 | It was to assure me just in case, I leave you the link to flash in edl mode and then follow the steps before, anything you ask, thank you very much. CuT URLs |
11-20-2018, 15:16 | #12 (permalink) | |
No Life Poster Join Date: May 2004
Member: 64957 Status: Offline Thanks Meter: 100 | Quote:
i dont wanna add any extention and dont spam. any other link? | |
