10-25-2019, 02:16 | #1 (permalink) |
Junior Member Join Date: Sep 2019 Location: brazil
Member: 2929960 Status: Offline Thanks Meter: 0 | Xiaomi Mi A2 LITE flash with incorrect ROM When I try to falsh to the original A2 lite ROM error, in MiFlash error "cant not head from COM3 port", in Miracle Xioami Tools the error "BootLoad Error. ID: 0003 Please change Model, Try again." I make flash recognize it as redmi6 pro it accepts, but it doesn't work. From what you understand when I forced the ROM flash from another device it does not work due to different partition issues, but it recorded the name of the ROM device, and now that I want to go back to the original ROM it does not accept because it is not his ROM. In summary, I would like help to undo this ****. |
10-25-2019, 11:31 | #3 (permalink) | |
Product Supporter Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Quote:
Good, emmc is your solution | |
10-27-2019, 14:29 | #6 (permalink) |
Member: 2929960 Status: Offline Thanks Meter: 0 | REDMI 6 PRO(FORCED) s a k u r a_images_V10 3 4 0 PDICNXM_20190716 0000 00 9.0_cn MI A2 LITE(ORIGINAL) daisy_global_images_V10 0 13 0 PDLMIXM_9 0 Strange it seems that when I forced the REDMI 6 PRO ROM, I changed getvar product to ******, if I could, why can't I get getvar product back to daisy? Last edited by ansxau; 10-27-2019 at 14:35. |
10-27-2019, 14:42 | #7 (permalink) |
Member: 2929960 Status: Offline Thanks Meter: 0 | REDMI 6 PRO(FORCED) s a k u r a_images_V10 3 4 0 PDICNXM_20190716 0000 00 9.0_cn MI A2 LITE(ORIGINAL) daisy_global_images_V10 0 13 0 PDLMIXM_9 0 Strange it seems that when I forced the REDMI 6 PRO ROM, I changed getvar product to s a k u r a, if I could, why can't I get getvar product back to daisy? I can write a rom daisy using prog_emmc_firehose_8953_ddr mbn from s a k u r a, but it doesn't turn on, because it's with rom daisy but emmc s a k u r a. |
10-28-2019, 13:47 | #8 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | As it is dead you need to erase everything, nck Qualcomm can do it, if not have you can use miracle for reading partitions and then select all and wipe, now again flash orignal rom which was inside. It is dangerous for alive mobile but since you already hv dead one go for it |
10-29-2019, 00:43 | #9 (permalink) | |
Member: 2929960 Status: Offline Thanks Meter: 0 | Quote:
10-29-2019, 21:29 | #10 (permalink) |
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Use original firhose file from firmware and select manually in miracle, and short tp with wire not tuser or pins |
