10-17-2018, 07:49 | #1 (permalink) |
Junior Member Join Date: May 2014
Member: 2185701 Status: Offline Thanks Meter: 3 | Need help with dead Redmi Note 4 mtk |
10-17-2018, 09:16 | #2 (permalink) | |
Product Supporter Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Quote:
1. Install drivers from folder MTK_Driver_Installer_.1352 ext using DriverInstaller.exe inside this folder as Administrator. https://www.dropbox.com/s/orq4cjf0qm...aines.rar?dl=0 2. Download Official Fastboot ROM for Redmi Note 4 or Redmi Pro (China Dev, China Stable, Global - whatever you'd like) from here: http://bigota.d.miui.com/V9.5.3.0.MB...4f5e35e9b0.tgz 3.Run flash_tool.exe as Administrator. After program starts for Download Agent, select this download agent (MTK_All_In_One.bin). You can find it on SP Flash Tool folder. For Scatter file select MT6797_Android_scatter.txt from extracted ROM's images' folder. After files loaded uncheck preloader (In the case that you flash and after 10 minutes or 15 you see that it does not start or it stays in bootlop, you re-flash with included preloader. Now with phone powered Off, click Download button and hold the Volume down (-) and connect the USB cable to the phone. Hold the Volume down until you see the Chip info in left bottom corner or wait for yellow line: Now sit back and wait to be finnished: Remove the cable and hold Power button until vibrate. Wait up to 15min (dont panic) to finish the boot. Congrats you have working phone with your desired ROM (China Dev, China Stable, Global). FINISH | |
10-17-2018, 11:34 | #3 (permalink) |
Member: 2185701 Status: Offline Thanks Meter: 3 | Thanks for your time. I have tried this but I never works. I gives me this error: "ERROR: STATUS_DA_EXCEED_MAX_NUM (0xC0070005) ) I also tried it again with your files and again the same. Even with volume down and connecting or if I just connect the phone. Red bar comes and then the error message. The only way I found to bypass this error and flash it 100% is to change the cust. img with an online edited one I found. But even then the phone doesn't boot at all. I think I need a better tool to flash. I heard EFT dongle is good but I don't have it. |
