HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
01-01-2010, 03:58 | #1 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1177967 Status: Offline Thanks Meter: 1 | How to block incoming calls for windows mobile phone Are you often bothered with some unwanted phone calls? Especially when you are too busy or having an important meeting. Why not block these unwanted incoming calls? Now iMobileTool Incoming Calls Blocker offers a powerful phone calls blocking solution to block incoming calls whenever and whereever you want at your will. How to install iMobileTool Incoming Calls Blocker ? How to block incoming calls ? How to view the incoming calls blocked logs ? How to turn on and turn off the block incoming call service ? How to install iMobileTool Incoming Calls Blocker ? * Step 1. Download iMobileTool Incoming Calls Blocker from HERE * Step 2. Check the system version of your mobile phone. Select "Start" -> "Settings" -> "System" -> "About". * Step 3. Copy the installation file "IncomingCallsBlockerSetup.CAB" with the right version as you have checked to your mobile device. You may need to connect your device to a host computer using ActiveSync. You can also transfer the file using a memory card. * Step 4. On your device, navigate to the location of the CAB file using File Explorer. Click on the CAB file (displayed as the following screenshot) and click "Install" to begin installation. * Step 5. Now installation completes. Select "OK" to continue. * Done. Now you can run the program to trun on the service.(Read Part4) How to block incoming calls ? * Step 1. Click "start" and then select "programs". * Step 2. Run "Incoming Calls Blocker". You will see the follow screenshot: * Step 3. Now you can click the "BlackList" icon to add phone numbers which you want to block. * Step 4. You can check the "block all" menu to block all the incoming calls or use the "Add" Menu to add custom phone number to block. When you click "Add" menu,you will see: Here you can input a number in the text box or click to select phone number from your contacts book. Then you can choose a number matching rule. There are 4 types of number matching rules: A: Full matching: this will block the phone number that is the same as you input (set as default); B: Beginning Matching: this will block all phone numbers starting from the number you input. For example, you can choose this matching rule to block all calls from ****** City that begin with 201; C: Ending Matching: this will block all phone numbers ending with the number you input; D: Middle Matching: this will block all numbers containing the number you input anywhere in the phone number. For example, you can use this matching type to block all phone numbers that contain "00". Click "Save" button to save you added or cancel to exit. You can add as much phone numbers to your blacklist as you wish in the above way. * Now, the incoming calls will be blocked as you set the moment it calls. How to view the incoming calls blocked logs ? * Step 1. Click the "Logs" icon to view logs: * Step 2.About Logs settings. You can clear all logs records by checking "Clear", or check/uncheck "Enable Logs" from the menu: How to turn on and turn off the block incoming call service ? * iMobileTool Incoming Calls Blocker runs as service on your mobile phone. You can click the "Service" icon to turn on and turn off service whenever you wish to. You also can set the service to auto start or not from the menu shown as ****: Free Download iMobileTool Incoming Calls Blocker from HERE to have a try. |
How to Transfer SMS/ Contacts for Windows Mobile Phone | alex034 | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 12-01-2009 04:32 |
How to block incoming calls for windows mobile phone | imtpro | HTC & PDA WM( With Touchscreen) | 0 | 08-18-2009 02:26 |
