Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2004
Member: 51453 Status: Offline Thanks: 2,521
| hi to all i have here HTC Touch 3G T3232 pass word is enable.doing hard reset can remove password? also how to hard reset this model .any one have a solution please share.thanks br |
| | #2 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2008 Location: Angeles City
Member: 697643 Status: Offline Thanks: 41
| To perform a soft reset Remove the back cover and then with the stylus, press the RESET buttonfound at the left side of your device. Your device restarts anddisplays the Today screen. Hard reset You can also perform a hard reset (also known as a full reset). A hardreset should be performed only if a normal reset does not solve asystem problem. After a hard reset, the device is restored to itsdefault settings -‑ the way it was when you first purchased it andturned it on. Any programs you installed, data you entered, andsettings you customized on your device will be lost. Only WindowsMobile® software and other pre-installed programs will remain. To perform a hard reset 1. Press and hold the TALK and END buttons, and at the same time, usethe stylus to press the RESET button at the left side of your device. 2. Release the stylus, but continue pressing the TALK and END buttons until you see the following message on the screen: 3. Release the TALK and END buttons, and then press ENTER on your device. Warning! Your device will be set back to factory default settings.Please ensure any additional installed programs and/or user data havebeen backed up before a hard reset is performed. Important If Encrypt files placed on storage cards is or was enabledbefore, then backup all files from the storage card before using ClearStorage, hard reset or updating the ROM system software. Otherwise youwill no longer be able to access the encrypted files on the storagecard. Use ActiveSync or Windows Mobile Device Center to transfer filesbetween your storage card and computer. After the procedure, copy yourfiles back to the storage card. Clear Storage Another way of clearing the device storage and reset all settings backto factory default settings is to use the Clear Storage feature. Youwill lose all your data and files on the device storage when you useClear Storage, so make sure to do a backup first. 1. Tap Start > Settings > System tab > Clear Storage. 2. Enter “1234” then tap Yes. |
| The Following 2 Users Say Thank You to howell For This Useful Post: |
| | #4 (permalink) | |
| Quote:
br | |
| The Following User Says Thank You to shawgsm For This Useful Post: |
| | #5 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2006 Location: Bangladesh
Member: 319447 Status: Offline Thanks: 1,506
| Try this ![]() 1. Pull out the stylus. 2. With the device turned on, press and hold the VOLUME DOWN and ENTER buttons "aka the center button" , then press the RESET button with the stylus tip. 3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen: This operation will delete all your personal data and reset all settings to manufacturer default. Press Volume Up to reset to manufacturer default, or press other keys to cancel. 4. Release the VOLUME DOWN and ENTER buttons, then press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset. 5. After restore completed press VOLUME UP again to restart the device. |
| The Following 8 Users Say Thank You to .:SUBRATA:. For This Useful Post: |
| | #10 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2006 Location: Ahmedabad
Member: 320205 Status: Offline Thanks: 861
| Quote:
| | #12 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Nov 2009 Location: Takerhat->Madaripur->B.D Age: 30
Member: 1162626 Status: Offline Sonork: 100.1591727 Thanks: 2,826
| HTC Touch Jade 3G T3232 Soft reset Soft reset Occasionally, you may need to reset your device. A soft (or normal) reset of your device clears all active program memory and shuts down all active programs. This can be useful when your device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost. To perform a HTC Jade soft reset 1. Remove the back cover. 2. Pull out the stylus, and use the stylus tip to press the RESET button located near the battery compartment. Your device then restarts and displays the Home screen.. ![]() HTC Touch Jade 3G Hard reset HTC 3G Hard reset You can also perform a hard reset (also known as a full reset). A hard reset should only be performed if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings—the way it was when you first purchased it and turned it on. Any programs you installed, data you enteredand settings you customized on your device will be lost. Only Windows Mobile® software and other pre-installed programs will remain. Warning! Your device will be set back to factory default settings. Make sure that any additional installed programs and/or user data have been backed up before you perform a hard reset. Important If Encrypt files when placed on a storage card is enabled, backup all files from the storage card before using Clear Storage, hard reset, or updating the ROM system software. Otherwise you will no longer be able to access the encrypted files on the storage card. Use ActiveSync or Windows Mobile Device Center to transfer files between your storage card and computer. After the procedure, copy your files back to the storage card. To perform a HTC Jade hard reset 1. Power off your device. 2. Press and hold the VOLUME DOWN and ENTER buttons, and then press the POWER button. The following message then appears on the screen: ![]() 3. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset. Clear Storage You can also use Clear Storage to reset your device back to factory default settings. 1. On the Home screen, slide to the Settings tab and then tap All Settings. 2. On the System tab, tap Clear Storage. 3. Enter “1234” and then tap Yes. This Procedure Tested By Me. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| how to hard reset htc t7272 | rokon | HTC & Smartphones ( WM Without Touch) | 1 | 11-03-2012 07:26 |
| how to HARD reset HTC vox0101 ? | tgsm | HTC & Smartphones ( WM Without Touch) | 24 | 08-29-2012 08:50 |
| How to Hard reset HTC drea110 G1 | ebu mohammed-emin | HTC & Smartphones ( WM Without Touch) | 8 | 08-16-2011 17:28 |
| How to Hard Reset your iPhone/iPhone 3G | ashraf_bcs | iPhone ,iPod & iPad (Apple Inc. Products) | 8 | 08-28-2010 20:20 |
| How to hard reset cingular 2125 by htc to get rid of usercode? | MR.PRESIDENT | HTC & Smartphones ( WM Without Touch) | 5 | 06-10-2009 17:24 |
