how to unlock HTC innovation and hard reset. plz any one can tell m e how to unlock and hard reset HTC innovation plz help |
why no one want to reply plz help |
What do you think why people don't answer? Maybe they need a proper question.Without a model they can't/don't want to help you.Btw,you can find the answers yourself in this section on the sticky threads. Next time use the search to save forum space. BR. Szig Quote:
then this thread can be helpful for you. :p http://forum.gsmhosting.com/vbb/showthread.php?t=510449 if you have any other specific queries please post it properly. only then someone can help you out :D |
i got this HTC manual. on from its written ( MDA VARIO ) I think its a model .can u plz now tell me |
i use this method from the link u give me HTC Wizard (Prodigy) and this picture looks same. and phone is successfully hard reset. plz can u tell me how can i unlock it. its form T mobile uk. thanks |
Some help: http://forum.gsmhosting.com/vbb/show...t=vario+unlock http://forum.gsmhosting.com/vbb/show...t=vario+unlock Check the links,there are the solutions you need. BR. Szig |
thanks for good link by the way what is activesync. in istraction they said plz slect with activesync. plz tell me and how to do it |
Activesync is a communication program.It helps you to syncronise your device and your computer(outlook contacts,mails,calendar,to do lists,file managing). Link: http://www.microsoft.com/windowsmobi...ivesync45.mspx Install it,restart your computer,after that connect your device via usb.Wait until the connection established,a window will appear,if you don't want to syncronise click cancel.Maybe will be one more window only with ok option.After that a new small window with explore and connect options.Use the explore function,you can browse your device and copy the required files from your PC. So,connect the PDA,then run the software and follow the instructions. Good luck! Szig Quote:
thanks man i install activesync 4.5 and i conect my mda vario . but when i run LokiwizMsl.bat its dont give me code it just try to restart ur device or restart activsync. eho is off eho is off sim lock code is ur code .... try with another code and lot more message. but not providing lock code plz tell me where i am making mistake, plz help. and when i conect my Mda. it without sim |
Please confirm Arte110 MDA possible to unlock. I have tried to using HTCunlock - CVS - Phone still locked Tried also with LokiwiMsl.bat and got the following error. machinagod's HTC Wizard/Prophet/Charmer MSL Revealer v0.3 NOW WITHOUT CID Unlocking POWER! ECHO is off. Supports SPL 2.x!! -------------------- WARNING: This tool is highly experimental! I will NOT be held responsible for any problems caused by this tool. -------------------- Thanks to xda-developers, spv-developers, and especially itsme by the work they released. This solution would not be possible without them. -------------------- Unlocking RAPI Please wait... MachinaGod RapiUnlocker v1.0 Initializing.......................Done! RAPI Unlocked. Starting MSL work... DO NOT DISCONNECT UNTIL THIS SCRIPT ENDS ECHO is off. CopyTFFSToFile(0x0, 0x10000, lock_backup.bin) ERROR: Unable to open host/destination file - Access is denied. ECHO is off. ECHO is off. SIMLock Code is your code... Type it with another SIM in... -------------------- Use of uninitialized value in concatenation (.) or string at C:\Documents and Se ttings\Administrator\Desktop\htc\sim unlock\Utils\lokiwizMsl.exe line 164. openfile: : Permission denied This exe file was created with the evaluation version of Perl2Exe. For more information visit http://www.indigostar.com (The full version does not display this message with a 2 second delay.) ... -------------------- "Standing on the shoulder of giants" Ricardo Afonso, 2005 Press Any key to Exit. its not my log coz i cant copey but my log 1000000000000% has same problem plz tell me how to fix this problem |
maybe you have to copy and run on your device enablerapi.cab and cert_spcs.cab.After that run lokiwizmsl.bat on you pc. Post results! Szig |
Bros, infact i got the same log from unlocking MDA T Mobile now phone is still locked, I used a software on ALL HTC service unlocker by Mouradsamsung ie WIZARD. please can someone give a more clear explanation |
OK guys! I need the proper model of your devices.It can be found on the label under battery. For example:wiza200 Or post a photo of this label. Next step: IPL,SPL,Radio version you can find it on the boot screen after power on or start->settings->device information Sometimes this lokiwiz solution doesn't work without radio downgrade(DO NOT BEGIN TO DOWNGRADE!!!post me these infos first!) BR. Szig |
