HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
02-18-2004, 14:29 | #2 (permalink) | |
Freak Poster Join Date: Sep 2001 Location: uk
Member: 6537 Status: Offline Thanks Meter: 0 | Quote:
hi check your mail. reg jinn | |
02-18-2004, 23:39 | #4 (permalink) |
Member: 6537 Status: Offline Thanks Meter: 0 | my freind this is FREE SOLUTION download from here free http://groups.yahoo.com/group/c5gsm/files/ phone need to be in bootloader mode so WARNING MAKE BACK UP FIRST. as u will loose all data. enjoy jinn jinn@c5 electronics.com |
02-19-2004, 10:34 | #5 (permalink) |
Freak Poster Join Date: Jan 2004
Member: 48403 Status: Offline Thanks Meter: 1 | You can get the software from here and here are the instuctions XDA Developers xda2unlock tool This program will extract the unlock code from your XDA II. For this to be possible, a few steps are necessary: 1. The XDA II needs to be put in bootloader mode. NOTE: THIS WILL WIPE ALL YOUR DATA SO FIRST BACK-UP! You enter the bootloader by holding the Power button and the Action button while pressing the stylus in the reset hole on the bottom. In the bootloader mode, the display will be gray and say Serial at the top. 2. Next put the device in the USB cradle. The display will now say USB and the first time Windows will detect a new device. 3. Disable USB in Active Sync in 'File -> Connection Settings' Now the device is ready to extract the unlock code. Type YES when you have completed the above steps and want to continue: YES Communication port opened. waiting for radio bootloader reading first block... reading second block... Unlock code: 2040248 When you insert a blocked SIM in your XDA2, you can enter the above code in the SIMlock box. Alternatively, you can connect to the wireless modem and enter the following AT command: AT%HTCLOCK=0,2040248,1 Do not forget to enable USB in Active Sync again! |
08-04-2004, 20:12 | #7 (permalink) |
Freak Poster Join Date: May 2004 Age: 48
Member: 64672 Status: Offline Thanks Meter: 4 | hi is any one know how to cheange imei on (O2 xda2)? please help thanks from now.... [email protected] |
09-10-2004, 19:34 | #8 (permalink) |
Freak Poster Join Date: Apr 2004 Location: Where night is bright Age: 43
Member: 61649 Status: Offline Thanks Meter: 113 | Can U help me too? [email protected] |
09-19-2004, 15:24 | #10 (permalink) |
Junior Member Join Date: Sep 2004 Age: 40
Member: 82629 Status: Offline Thanks Meter: 0 | Xda2 Unlock Instructions And Software software availbull at You cant click on it you need to copy and paste http://www.angelfire.com/weird/beneyre/xda2unlock.zip 1. The XDA II needs to be put in bootloader mode. NOTE: THIS WILL WIPE ALL YOUR DATA SO FIRST BACK-UP! You enter the bootloader by holding the Power button and the Action button while pressing the stylus in the reset hole on the bottom. In the bootloader mode, the display will be gray and say Serial at the top. 2. Next put the device in the USB cradle. The display will now say USB and the first time Windows will detect a new device. 3. Disable USB in Active Sync in 'File -> Connection Settings' Now the device is ready to extract the unlock code. Type YES when you have completed the above steps and want to continue: YES Communication port opened. waiting for radio bootloader reading first block... reading second block... It Will Tell you the unlock code then put in the blocked sim enter the code in the sim lock box Enjoy |
02-06-2005, 22:55 | #11 (permalink) |
Junior Member Join Date: Jan 2005 Age: 61
Member: 105014 Status: Offline Thanks Meter: 0 | is it locked? i have a o2 xda2 i am on o2 when i put my sim in it it will not make a call it dos't say it is blocked but when i put my sim back in my own phone it will work please help!! allso when i ring the xda2 when the sim is in it (my sim) it says can't connect? please pm me or [email protected] |
03-09-2005, 19:39 | #14 (permalink) | |
No Life Poster Join Date: Feb 2004
Member: 52597 Status: Offline Thanks Meter: 275 | Quote:
It seems a lot of wrong codes were keyed in earlier. The set is a XDA II locked to O2 network; any suggestions ??? | |
03-13-2005, 13:35 | #15 (permalink) |
No Life Poster Join Date: Nov 2003 Location: Americas Age: 44
Member: 43802 Status: Offline Thanks Meter: 36 | Not a valid pocket PC application I am trying to unlock a XDA II. I have downloaded the XDA II V 2.2 unlock program copied it to the SD card , tried running it and got that it is not a valid pocket PC application. Please help me. ROM Version 1.72.00WWE ROM Date 03/15/04 Radio Version 1.17.00 Last edited by tical; 03-13-2005 at 14:39. |
how to unlock o2 xda II ?? | yadra^^ | HTC & Smartphones ( WM Without Touch) | 1 | 10-20-2009 11:10 |
how to unlock O2 XDA | sniper007 | HTC & PDA WM( With Touchscreen) | 1 | 05-12-2009 13:49 |
how to unlock o2 xda mini s | ruvanw1979 | HTC & PDA WM( With Touchscreen) | 5 | 10-22-2008 14:13 |
How to unlock O2 XDA ORBIT? | makkan00 | HTC & PDA WM( With Touchscreen) | 2 | 05-07-2007 13:28 |
how to unlocked o2 xda IIs and Orange m2000? | kharheng | Various | 5 | 01-06-2006 14:28 |
