Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > HTC > HTC & PDA WM( With Touchscreen)
HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices
Old 02-10-2009, 17:41   #1 (permalink)
digital_park's Avatar
Member: 681183
Exclamation how we can enter bootloader of ELF
can any one tell me how we can enter bootloader of ELF
Old 02-10-2009, 17:47   #2 (permalink)
frnd_4_gsm's Avatar
Member: 279604
Sonork: 100.1582858
1) Turn device off
2) Unplug power/usb cable from handset
3) Press and hold camera button
4) Plug power/usb cable into handset
or simple press cemera button+power on button and reset
The Following 2 Users Say Thank You to frnd_4_gsm For This Useful Post:
Old 02-10-2009, 17:57   #3 (permalink)
Member: 681183
Exclamation
sir i have htc touch its language is in french
i need to flash it to English version
i successfully enter in bootloader
it show
IPL 2.20.0002
SPL 2.20.0000
and i have this file can i flash it
RUU_Elfin_hTC_Asia_India_3.07.720.03_4.1.13.71_03. 34.90_BLUE_Ship.exe
and plz also tell me procedure
thanks
Old 02-10-2009, 18:34   #4 (permalink)
Member: 681183
Exclamation
Sir i try this file but it gives me this error
ERROR [294] : INVALID VENDER ID
sir i think its a CID problem
can u tell me how i can unlock CID
Old 02-10-2009, 19:48   #5 (permalink)
szig's Avatar
Member: 365452
Hi!
You can find everything here:
http://wiki.xda-developers.com/index...gename=HTC_Elf
You have to use USPL for CID unlock,after that you can flash any ROM you need.Be careful,sometimes it seems OK,but USPL doesn't work for first try,you must check it.Instructions are on the site also.
Szig
The Following User Says Thank You to szig For This Useful Post:
Old 02-11-2009, 03:45   #6 (permalink)
Member: 681183
Exclamation
Now i successfully CID unlock
but when i flash my ELF
it gives me error
ERROR 228 Invalid File SIZE
what should i do sir
Old 02-11-2009, 04:55   #7 (permalink)
.:SUBRATA:.'s Avatar
Member: 319447
it gives me error
This means, your device Flash CHIP Size
For ELF
Its 64 / 128 :-?
For ELFIN
128/256 ? make sure your device Chip size.
Old 02-11-2009, 09:38   #8 (permalink)
tsarkh's Avatar
Member: 165812
Sonork: 100:1627635
You Can Use My program to Look for a lot of models:
TSD v2.0
here is the link:
http://www.mediafire.com/download.php?nonwgkrj5ld
Good Flashing For All
The Following User Says Thank You to tsarkh For This Useful Post:
Old 02-18-2009, 10:03   #9 (permalink)
FZA
Member: 210174
My problem was that the language was in chinese so I tried to flash it but then I got a error 'invalid vendor id' after that I use 'USPL for CID unlock'.I change the SPL, I flash the phone, everything is ok the language is in english now but my question is do I have to flash the USPL again or can I leave it.
thanx
Old 02-18-2009, 14:20   #10 (permalink)
Member: 319447
thanx
why do you think you have to flash USPL once again ?
SPL flashes remove Carrier ID, means you can flash any carrier rom or original HTC rom to your device thats it my cute friend
anything else :-?
B.R
Subrata
Old 02-18-2009, 14:46   #11 (permalink)
Member: 319447
thanx
anything else :-?
B.R
Subrata
How We can enter bootloder mode digital_park HTC & PDA WM( With Touchscreen) 0 11-02-2008 12:34
How we can to save norton commander window(names of folders and files)? alexvideogames Universalbox 2 09-17-2008 15:57
How we can managin connection of PHONIX step by step aukonline MT-BOX 13 08-29-2006 13:25
Phone can enter bootloader, but not connect PC LinPack P2k Series 2 07-06-2006 11:57
Page generated in 2.63771 seconds with 11 queries
