Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > HTC > HTC & PDA WM( With Touchscreen)
HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices
Old 01-19-2012, 15:51   #1 (permalink)
Member: 68213
HTC HD2 LEO stuck on white HTC screen after flashing windows
I had android installed on my HD2 Leo but it was freezing so I decided to return to windows to diagnose the problem but when I flashed the windows mobile it is stuck on htc screen.
I can flash from sd card and still it freezes after completing installation.
This is how I do it.
task 29
flash hspl 2.08
flash radio
turn phone on and flash from sd card 2gb
100% complete successfully but still stuck.
I tried info8 and recieve no bad blocks.
--- 2K bytes sector version ---
DEVICE NAME=hynix_h8BES0UQ0MCP
DEVICE ID=0xBC
DEVICE MAKER ID=0xAD
PAGE SIZE=0x800
TOTAL PAGE SIZE=0x840
BLOCK COUNT=0x1000
BLOCK PAGE=0x40
Checking block information
BLOCK 0 (0x0) is reversed block
BLOCK 1 (0x1) is reversed block
BLOCK 2 (0x2) is reversed block
BLOCK 3 (0x3) is reversed block
BLOCK 8 (0x8) is reversed block
BLOCK 10 (0xA) is reversed block
BLOCK 11 (0xB) is reversed block
BLOCK 12 (0xC) is reversed block
BLOCK 13 (0xD) is reversed block
BLOCK 14 (0xE) is reversed block
BLOCK 15 (0xF) is reversed block
BLOCK 28 (0x1C) is reversed block
BLOCK 29 (0x1D) is reversed block
BLOCK 30 (0x1E) is reversed block
BLOCK 31 (0x1F) is reversed block
Partition[0], type=0x23, start=0x2, total=0xFE
Partition[1], type=0x0, start=0x0, total=0x0
Partition[2], type=0x0, start=0x0, total=0x0
Partition[3], type=0x0, start=0x0, total=0x0
CE Total Length(with sector info) = 0x80800
CE CheckSum Length(without sector info) = 0x80000
I then try to install android again using magldr but if i try to run from sd card I recieve 1EFATAL hit even If i try to start recovery.
any ideas?
The Following User Says Thank You to jabran200 For This Useful Post:
Old 01-19-2012, 16:03   #2 (permalink)
GSMsurgeon's Avatar
Member: 6524
try to use use diffrent rom
First put 8gb card then try to install diffrent mango rom(for win7) your phone will be ok..if not success contact me on skype.
The Following User Says Thank You to GSMsurgeon For This Useful Post:
Old 01-19-2012, 16:31   #3 (permalink)
Member: 68213
O.k will try that, I have an 8gb sd card which works as well.
thanks for the help, I hope it is okay.
Old 01-19-2012, 18:44   #4 (permalink)
Member: 68213
I tried installing windows 7 and it installed and eveyrything but when it was all installed it said reset now but did not reset so I removed the battery and turned the phone on and it says
booting wph
wph load
1EFATAL HIT 1
any ideas?
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-10-2013 02:07
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 07-31-2012 20:09
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
Page generated in 0.22270 seconds with 11 queries
