HTC Qtek 9100 & first time, i need help hello i have this device with english lang and the menu is empty, whene i press start i don't find any think, i think it need to be flashed ort some thing, i never work in this kind of devices befor as i am not ready to kill it so i am asking for help: ho to flash it with frensh lang step by step + links to download what i need here som info in start screen: IPL: 2.18 SPL: 2.18 GSM: 02.07.10 OS: 2.18.7.6 i will be very thankfull for helping and free lessons :D thankx |
Hi Firstly you try for a hard reset and let phone install rest things. if not done after hard reset, then unlock CID using aWizard Then finally, grab rom from Qtek Owner ? Look here for update. and you are done. |
thank you for helping, files are downloading now is that flash contents frensh lang ? |
hi after downoading files and unlocking cid using aWizard and runing the update rom utility i got this in the end: this nbf file connot be used for pda phone, pleas use a newer nbf file what next ??? thanks |
This is French http://rapidshare.com/files/18439208..._Ship.exe.html and about your error. you need newer version rom than your current one. what is current rom version exactly ? also try with this rom 3.8.2.1 TM UK WWE |
i have tried many files almost of them it's the same problem error Quote:
the file: 3.8.2.1 TM UK WWE (it's RUU 2.5.5 RUU_Prodigy_3821_382119_026911_TMO_UK_WWE_Ship )gives this error: Quote:
got it from here but the language it's in netherlands not even english and i can't understand or use it with lang, so it will be great if get a file with frensh lang, if not , ok with english and about the rom version i tink it's : 2.18.7.6 nld ( got it from phone) and this some informations deaded by wizard service tool : Quote:
So your set is running ok now ? Now go to next step. Unlock CID using LockWiz after unlocking CID. you will be able to flash any rom. contain any language. French Rom 1 or use any other English rom from my thread. |
Hi! Lokiwiz0.3 can't do CID unlock,you have to use lokiwiz0.2b to do that. http://www.fishermangsm.com/Share4HT...Lokiwiz02b.zip BR Szig |
hi those tow links not working, ( 550 failed to change directory = with mozilla & with enternet explorer server doesn't exisit) any others links ? thanks |
@ fethi Link updated. Sorry my fault. i didn't ck b4 post. |
you can get the wizard love rom from here :) http://rapidshare.com/users/EXGZ7T |
@ Subrata the problem still the same i made the unlock cid lokiwiz0.2b (dos program) and tried to update the software of the phone using many versions i found, but allways the file not compatible with phone as the program said, the only file can be uploaded to phone is in netherland language. what i can do to use it in frensh thank you |
and see now. |
ok, i have done it, i can now upload any rom i with and i got the lang that i want, thank you but i got a problem the tactil in Lcd don't work, i mean whene the update finish succifull of cours the handset must makes some setups & i have to do the touch in the screen, this step dosen't work what do you think ??? |
