Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > HTC > HTC & PDA WM( With Touchscreen)
HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices
Old 02-05-2010, 14:52   #1 (permalink)
fethi's Avatar
Member: 57836
Thanks Meter: 47
HTC Qtek 9100 & first time, i need help
hello
i have this device with english lang and the menu is empty, whene i press start i don't find any think, i think it need to be flashed ort some thing,
i never work in this kind of devices befor as i am not ready to kill it
so i am asking for help:
ho to flash it with frensh lang step by step + links to download what i need
here som info in start screen:
IPL: 2.18
SPL: 2.18
GSM: 02.07.10
OS: 2.18.7.6
i will be very thankfull for helping and free lessons
thankx
Old 02-06-2010, 04:45   #2 (permalink)
.:SUBRATA:.'s Avatar
Member: 319447
Thanks Meter: 4,945
Hi
Firstly you try for a hard reset and let phone install rest things.
if not done after hard reset, then unlock CID using aWizard
Then finally, grab rom from
Qtek Owner ? Look here for update.
and you are done.
The Following 2 Users Say Thank You to .:SUBRATA:. For This Useful Post:
Old 02-06-2010, 09:43   #3 (permalink)
fethi's Avatar
Member: 57836
Thanks Meter: 47
thank you for helping,
files are downloading now
is that flash contents frensh lang ?
Old 02-06-2010, 11:47   #4 (permalink)
fethi's Avatar
Member: 57836
Thanks Meter: 47
hi
after downoading files and unlocking cid using aWizard and runing the update rom utility i got this in the end:
this nbf file connot be used for pda phone, pleas use a newer nbf file
what next ???
thanks
Old 02-06-2010, 12:05   #5 (permalink)
Member: 319447
Thanks Meter: 4,945
This is French
http://rapidshare.com/files/18439208..._Ship.exe.html
and about your error. you need newer version rom than your current one.
what is current rom version exactly ?
also try with this rom
3.8.2.1 TM UK WWE
Old 02-06-2010, 17:57   #6 (permalink)
fethi's Avatar
Member: 57836
Thanks Meter: 47
i have tried many files almost of them it's the same problem error
the file: http://rapidshare.com/files/18439208..._Ship.exe.html it's the same error
the file: 3.8.2.1 TM UK WWE (it's RUU 2.5.5
RUU_Prodigy_3821_382119_026911_TMO_UK_WWE_Ship )gives this error:
error[294]: invalid vender id
this update utility cannot be used for your PDA phone,
pleas chek your update utility
the only file worked ok with me is this one: Qtek 9100 ROM Update v2.18.7.106 Nederlandstalig (ZIP, 49.3MB)
got it from here
but the language it's in netherlands not even english and i can't understand or use it with lang, so it will be great if get a file with frensh lang, if not , ok with english
and about the rom version i tink it's : 2.18.7.6 nld ( got it from phone)
and this some informations deaded by wizard service tool :
Wizard Service Tool v4.2.2
06/02/10 17:47:23
CPU: Texas Instruments - OMAP850
MODEL: Wizard
IMEI: 356384007186875
=> Bootloaders:
IPL: 2.18 (G3 device)
SPL: 2.18 (G3 device)
Built on Feb 14 2006 at 18:48:31
Copyright (c) 2003 High Tech Computer Corporation
=> Firmware:
OS: 5.1.xxx (Build 14847.2.0.0)
ROM: 2.18
Registry AKU: .2.0.0
Radio: 02.07.1
Protocol: P413.1.03
=>Extended_ROM:
Version: 2.18.7.106
Status: hidden
=> Drives and partitions:
|--Handle--|---Size---|
ae9dd4a2 - 9.99M (0x9fd800)
4ea9b13a - 48.23M (0x303c000)
cfb23f92 - 50.95M (0x32f4000)
0fb23f3e - 2.94M (0x2f0000)
afb23fb6 - 3.06M (0x30fc00)
=> DOC chip unique ID:
000000002e0e010414300a5a050a05eb
Key Index: 84
All Done.
Old 02-07-2010, 04:55   #7 (permalink)
Member: 319447
Thanks Meter: 4,945
So your set is running ok now ?
Now go to next step.
Unlock CID using LockWiz
after unlocking CID. you will be able to flash any rom. contain any language.
French Rom 1
or use any other English rom from my thread.
The Following 3 Users Say Thank You to .:SUBRATA:. For This Useful Post:
Old 02-07-2010, 09:02   #8 (permalink)
szig's Avatar
Member: 365452
Thanks Meter: 838
Hi!
Lokiwiz0.3 can't do CID unlock,you have to use lokiwiz0.2b to do that.
http://www.fishermangsm.com/Share4HT...Lokiwiz02b.zip
Szig
The Following 2 Users Say Thank You to szig For This Useful Post:
Old 02-07-2010, 13:55   #9 (permalink)
fethi's Avatar
Member: 57836
Thanks Meter: 47
Originally Posted by .:SUBRATA:. View Post
hi
those tow links not working, ( 550 failed to change directory = with mozilla & with enternet explorer server doesn't exisit)
any others links ?
thanks
Old 02-07-2010, 14:39   #10 (permalink)
Member: 319447
Thanks Meter: 4,945
@ fethi
Link updated.
Sorry my fault. i didn't ck b4 post.
The Following User Says Thank You to .:SUBRATA:. For This Useful Post:
Old 02-07-2010, 14:44   #11 (permalink)
Member: 180833
Sonork: 100.1578281
Thanks Meter: 215
Originally Posted by fethi View Post
hi
any others links ?
thanks
Brother,
you can get the wizard love rom from here
http://rapidshare.com/users/EXGZ7T
The Following User Says Thank You to sanjoychy For This Useful Post:
Old 02-08-2010, 13:53   #12 (permalink)
fethi's Avatar
Member: 57836
Thanks Meter: 47
@ Subrata
the problem still the same
i made the unlock cid lokiwiz0.2b (dos program) and tried to update the software of the phone using many versions i found, but allways the file not compatible with phone as the program said, the only file can be uploaded to phone is in netherland language.
what i can do to use it in frensh
thank you
Old 02-08-2010, 14:00   #13 (permalink)
Member: 319447
Thanks Meter: 4,945
@ Subrata
thank you
Flash G4 Soft SPL
and see now.
Old 02-10-2010, 11:38   #14 (permalink)
fethi's Avatar
Member: 57836
Thanks Meter: 47
Flash G4 Soft SPL
and see now.
did not work
Old 02-12-2010, 19:37   #15 (permalink)
fethi's Avatar
Member: 57836
Thanks Meter: 47
ok, i have done it,
i can now upload any rom i with and i got the lang that i want, thank you
but i got a problem
the tactil in Lcd don't work, i mean whene the update finish succifull of cours the handset must makes some setups & i have to do the touch in the screen,
this step dosen't work
what do you think ???
5610d gpg cable newly bought & first time I used, defective product!!! mymiela0419 Latest GPGIndustries News 15 07-15-2009 06:55
wrong code again for HTC Qtek 9100 celcolombia Gsmfather The Wholesale Unlocking Database 0 02-27-2009 09:26
First Time 1208 Flashing-help zone2 MT-BOX 4 02-06-2008 13:16
V3XX first time modding, please help me! IMPORTHUNTER Motorola P2k 1 10-09-2007 03:02
Page generated in 0.61006 seconds with 8 queries
