HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
09-06-2008, 10:34 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: philippines
Member: 699870 Status: Offline Sonork: 100.1647674 Thanks Meter: 69 | i-mate sp5m htc inovation how to remove pasword? i didnt know what im diong. thqanks in advance |
09-06-2008, 11:01 | #2 (permalink) |
Moderator Join Date: Oct 2006 Location: Tunisia Age: 41
Member: 363451 Status: Offline Sonork: 100.1577895 Thanks Meter: 834 | Hi bro , Turn your phone off. Press and hold the two softkey (thoose 2 placed to the left and right side under the display) while you press on/off button for about 0.5 seconds. Make sure you still have the soft buttons pressed when release the on/off button. After a few seconds a text will appear in the display telling you to press "0" (zero) to make an hard reset. |
09-06-2008, 11:57 | #4 (permalink) |
Member: 699870 Status: Offline Sonork: 100.1647674 Thanks Meter: 69 | (thoose 2 placed to the left and right side under the display) what kind of arrow this?,, i try but ni lock bro,, its something with me? |
09-07-2008, 08:03 | #7 (permalink) |
No Life Poster Join Date: Jul 2007 Location: (¯`». Catch Me If U Can .«´¯) Age: 35
Member: 553445 Status: Offline Sonork: 100.1585581 Thanks Meter: 8,184 | here it is 1. Press and hold soft1 and soft2 keys. 2. Press and hold power button for around 1 to 1.5 seconds. Release power button. Keep hold soft1 and soft2 keys. 3. Later, screen shoould show instructions to ask user to press '0' key to reset to factory default. 4. Press '0' within the timeout period, which is only several seconds only. 5. If no instruction is shown on the screen, repeat steps 1 to 4. The timing is sensitive. but you will loose all data. Or THIS Try to Hard Reset first (Backup important stuffs!) Power Off Phone then Press the 2 softkeys and Hold then press the Power Button, release right away the Power Button while the backlight is not lit yet, then just continue holding the 2 softkeys and it will ask you the hard reset confirmation..if it still continued to boot, you might had a bad timing. |
how to remove mmc pasword | shinojmahe | Nokia Multimedia | 5 | 11-04-2012 09:41 |
9000 how to removed pasword | KARK_07 | BlackBerry (RIM) | 4 | 03-02-2010 08:16 |
i-mate sp5m Htc innovation | abdullatheef | HTC & PDA WM( With Touchscreen) | 6 | 07-18-2009 12:10 |
I-MATE PDAL how to remove password plz urgent | asif_ae | HTC & Smartphones ( WM Without Touch) | 1 | 06-13-2009 16:59 |
i-mate PDL HOW TO REMOVE PASSWORD urgent | asif_ae | HTC & PDA WM( With Touchscreen) | 1 | 06-13-2009 14:53 |
