Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2007 Location: IRaN,Teh,7HoZ Age: 25
Member: 649578 Status: Offline Sonork: 100.1592568 Thanks: 709
| i900 omnia toch calibration not complete After hard reset i can not calibrate my touch screen. There is appear align screen and... nothing. Can i remove align screen from windows mobile 6.1 and how to do this? |
| The Following User Says Thank You to jam_mobile For This Useful Post: |
| | #2 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2007 Location: tunisia Age: 34
Member: 546406 Status: Offline Thanks: 528
| installa actinsynch 4.5 or higher, then create new txt file then rename it to welcome.con then copy it to memory phone with activesynch and usb cable open phone then recalibrate touch |
| The Following 4 Users Say Thank You to gsmdok For This Useful Post: |
| | #3 (permalink) |
| cant skip calibration pls help meeeeeeeeeeeeeeeeeeeeeeeeeee |
| | #6 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2006 Location: Bangladesh
Member: 319447 Status: Offline Thanks: 1,506
| Quote:
long time ago i uploaded. Samsung Service Manual | |
| The Following User Says Thank You to .:SUBRATA:. For This Useful Post: |
| | #8 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2006 Location: Hungary Age: 36
Member: 365452 Status: Offline Thanks: 274
| Hi! First of all you can try to skip alignment with MSP_remotealignment.If the digitizer doesn't work after that,then you can continue with replacing digitizer or checking the controller IC. BR Szig |
| | #13 (permalink) | |
| Quote:
It's not on the phone,you have to create an empty txt file named welcome.not and copy it to the root of the memory card (or maybe it works if you copy it to the phone's root). I use MSP_remotealignment that worked on every model so far (when welcome.not method didn't). BR Szig | |
| | #14 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2004 Age: 43
Member: 66136 Status: Offline Thanks: 123
| tks for your reply szig, so I put this text file rename : welcome.not, but dn't work (for infromation, now I test the solution on a HTC handset), and about MSP_remotealignment pls, it's this one : 01.gif and if yes how about use it pls ? Best Regards, JAVA Good. |
| | #15 (permalink) | |
| Quote:
The first button is that what it seems:Skip screen alignment push the button and it will restart your device without the alignment screen,directly to the Today screen.It helps you if your screen has small damages,but the final solution is replacing the touch screen. BR Szig | |
| The Following User Says Thank You to szig For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| i900 omnia tr language not support flash file[SOLVED] | turkcellgsm | SPT BOX | 2 | 01-22-2010 18:48 |
| i900 OMNIA Code not found! | adelgsm | UST Pro II | 1 | 10-01-2009 19:25 |
| samsung i900 Omnia camera module not ready | Kashif Khan | Samsung Hardware Repair Area | 0 | 08-10-2009 17:26 |
| I900 need always calibrating | roniri | QUALCOMM Models (3G) | 5 | 06-07-2009 21:09 |
| Warning!! I900 Omnia not unlocked buy rpl !! | volkangsm2 | UST Pro II | 4 | 11-18-2008 19:00 |
