HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
09-12-2007, 19:49 | #1 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Morocco/FBS
Member: 537213 Status: Offline Sonork: 100.1577391 Thanks Meter: 362 | MDA compact error 150:rom upgrade utility error error 150:rom upgrade utility error this rom upgrade utility does not design for your device please get proper rom upgrade utility and try again i follow-up all thise instruction 1-Right click on the EXE file and extract to a folder (using WinZip, ?WinRAR or otherwise) 2-You should end up with about 6 - 8 individual files in the folder; ms.nb1, radio.nb1, nk.nb1 ruu.conf, ruu.dll, enterbl, getdevicedata and maupgradeut. 3-Download MaUpgradeUt_noID.exe and place this file in the same folder as the files above. 4-In ActiveSync, click on file and connection settings and untick the USB connection. 5-Put your Magician into bootloader mode by holding the power and camera buttons, and holding the soft reset button with the stylus. 6-The screen backlight will be off, and 'Serial' should be displayed on the screen. Connect the phone to the USB and confirm that it says 'USB' now. 7-Now run MaUpgradeUt_noID.exe. The upgrade wizard wil start, go through a few checks then eventually come up with the Country ID error. 8-Run the MaUpgradeUt_noID.exe file again and this time it should allow you to run the wizard. 9-The process should then go through 3 stages which should last about 10 - 15 minutes. 10-When finished you should get the upgrade successful notification and a prompt to reset the device 11-In ActiveSync, click on file and connection settings and tick the USB connection. but same problem, any help |
freee unlocking for m3000, mda vario, mda compact II etc | arwanis | HTC & PDA WM( With Touchscreen) | 35 | 04-06-2008 16:28 |
MDA Compact / i-Mate Jam Unlocking? | virtualme | HTC & PDA WM( With Touchscreen) | 2 | 08-26-2006 16:27 |
Which one is supported? MDA Compact, MDA Compact II or both? | smartmod.de | JAFWM | 2 | 04-03-2006 22:39 |
mda compact upgrade | hvelect | HTC & PDA WM( With Touchscreen) | 0 | 02-03-2006 09:07 |
change language on t mobile mda compact | mobx montenegro | HTC & PDA WM( With Touchscreen) | 1 | 06-11-2005 23:47 |
