HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
06-21-2007, 13:29 | #1 (permalink) |
Junior Member Join Date: Jun 2007
Member: 530870 Status: Offline Thanks Meter: 1 | MioMap v3.2 for Mio C310x - Unlocked for all world - SD launch version Included: Voice: English, Russian, Hebrew Interface: English, Russian, Hebrew Keyboard: English, Russian, Hebrew NO maps are included!!! Easy to find them over WWW. Steps: ************************************************** 1) Copy to SD Copy MioMap folder to main root of your SD card. ************************************************** 2) Upload maps Find maps over WWW. Upload your maps to: \MioMap\maps Then insert SD to yours Mio C310x. ************************************************** 3) The 2-button Unlock The 2-button unlock is simple, and you can't get into too much trouble doing it. Here is how: (1) Power on the MIO (2) Using a paper clip, perform a SOFT RESET (3) Before the MIOMAP opening screen comes on (which is less than 2 seconds), press and hold the "Vol+" and "Menu" keys (the middle two keys) on the side of the MIO. If you were quick enough, you should see a screen that looks very much like an empty Windows screen. Release the keys. You're now almost there. (4) A "splash" screen will appear that says "There is no DM in SD card". Tap on "OK" (5) A second splash screen appears that says "If you want to copy map files?". MAKE SURE YOU TAP NO. If you tap YES, all your Maps will be erased. But don't panic - you can restore them easily from the DVD that came with your MIO, it's just a long (1 hour plus) process for the USA maps. (6) Congratulations - you're now UNLOCKED ! ************************************************** 4) Launch it! From your Mio C310x: 1) Start -> Programs -> Windows Explorer -> Storage Card -> MioMap 2) Select: MioMap 3) File -> Send To -> Desktop as Shortcut 4) Close all windows 5) Double click on Shortcut to MioMap on your Mio desktop. 6) Enjoy! |
The Following User Says Thank You to flash_os For This Useful Post: |
