Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > HTC > HTC & PDA WM( With Touchscreen)
HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices
Old 07-21-2005, 10:12   #196 (permalink)
hancurit's Avatar
Member: 52502
Thanks Meter: 5
Unhappy
Originally Posted by alimazhar
Summary
The most powerful Today plug-in with tabs. Close button that really
closes. ZIP support in File Explorer. And many other features missing
in official OS updates in one product.
Features
Today Plug-in:
Tabs. Battery, backlight, memory indicators, drag-and-drop, ...
File Explorer:
ZIP support, encryption, "Folder Up" button, storage card format, file
properties, ...
Close Button:
The close (X) button really closes programs, task manager, ...
Pocket Internet Explorer:
Multiple windows, full screen mode, save as, view source, ...
Buttons:
Alt-Tab, backlight change using a button, keyboard navigation in the
Today plug-in, ...
Safe Mode:
Loading the device in safe mode to prevent it from hard-reset in case
of any problems.
Other:
Taskbar battery indicator, extended Pocket PC themes, plug-ins, ...
link::::
download
register with the serial.,.,:::
Serial Number : 30372645
thx for the nice latest spb +....
i have one q... why does my sms will sent double if i install spb pocket plus, any solutions ? or maybe anyone can help solving this prob ?
this s/w is good but i dont like this problem. i use xda iis.
Old 07-21-2005, 11:28   #197 (permalink)
alimazhar's Avatar
Member: 132838
Thanks Meter: 49
Exclamation Did Not Know About This Problem
SORRY MAN ,.,.???? DID NOT KNOW ABOUT THIS PROBLEM???
IT WORK FINE WITH MY I MATE JAM ,.,.
I ASK MY FRIENDS ABOUT THIS ,.,.
IF I HAVE SOME SOLUTION I WILL TELL U ,.,.,.
ONE THING ,.,. CHECK OUT ALL THE SETTING,,.,.
MAY BE IT HELP S U ,.,.,.
Old 07-21-2005, 15:11   #198 (permalink)
alimazhar's Avatar
Member: 132838
Thanks Meter: 49
Talking New Games Posted
NEW GAMES POSTED
re-markable job man ,.,. tooooooooooo good ,.,.
like it tooo much ,.,.,imprassive
post more ,.,.
we grow this theard till it is the best ,.,.,.
GOOD GAMES ,.,. EVERY ONE MUST SEE
The Following User Says Thank You to alimazhar For This Useful Post:
Old 07-21-2005, 18:16   #199 (permalink)
alimazhar's Avatar
Member: 132838
Thanks Meter: 49
Talking SKTools PPC 2002
Originally Posted by Trek55
Any has the crack for SKTools 2.2.9?, thanks for any help.
Application Description
Powerfull maintenance tool. Cleaning registry and file system, databases maintenance, system backup/restore and much more...
Cleaning:
Find and delete temporary and absolete files
Clear temporary and cache folders like IE contents, IE history, Mail attachments, Large mails, AvantGO and custom users folders
Find and remove bad registry keys and values
Find and delete bad shortcuts
Find and delete duplicate shortcuts
Find and delete duplicate notify queue entry/entries
Find and delete bad uninstall info
Find and delete files depending on whose size or/and names (wipe optional)
Find and delete duplicate files (find with name,size,crc)
Find and delete MS Reader bookmarks (sensitive for bookmark in-use/not-use)
Find and delete empty folders
Find and delete exceed appointments
Find and delete duplicate appointments
Delete PIE history (registry)
System Information:
Device information and features
Processor information
Memory information
Screen information
OS version
Network
Power state
ROM information
Duplicate Contacts:
Find duplicate contacts (by all fields or names,email,company,phones)
Show
Delete
Notify Queue:
View records
Add records
Delete records
Find doublicates
Memory Usage:
Show all folders with size (bytes and percent)
Open selected folder
Backup/restore:
Auto (may disabled) backup registry key before delete it
Sheduled weekly full backup
Full system backup
Full registry backup
Full filesystem backup
All databases backup
ActiveSync Partnership backup
MSReader activation backup
Self backup
Password protection for backup files
Find and restore all SKTools backup files
Good compression for backup files
Storage card maintenance:
Show information about card(s)
Format
Scan and Fix
Empty
Rename
Other...
Database maintenance:
Show information
Delete
Empty
Export/Import to XML file (as example for partially backup or for transfer contacts database to other PPC)
Process list:
Show all process
Show list of modules of any process
Show information about memory usage, threads
Show command line for procees (if it exist)
Close one or selected processes
Today plugins list:
Show information about plugins
Delete and Uninstall (if possible)
Enable/disable plugin
Reorganise today plugin order with renumbering
Input methods list:
Show information about installed
Enable/disable
Select default method
Windows Startup:
Display list of programs that run when system loading
Delete program
Add new
Startup programs order control
Built-in Uninstaller:
Show list of installed program with size and date
Show list of files and registry keys for installed programs
Uninstall program
Save installed programs list to text file
Automation mode:
Run SKtools when system loading
Run SKTools every day at user defined time (with power off after work)
User defined operations list
Silent (run with out any window, only with led blink) mode
Other:
Multi-language support ( English, German, Spanish, French, Russian, Italian )
Change location of PIE cache, PIE history, PIE coockies, AvantGO datas
Soft and Hard reset
Command line support (screen off/on,power off, soft/hard reset and more...)
Change system path (after this you can move some dlls from windows folder to any location, as example to storage cards)
Free customizable today plugin (you can run SKTools and your favourite programs quickly)
More...
File Type: rar sktools[1].2.1.99.pocketpc.2002.cracked.rar (231.3 KB, 3937 views)
The Following 6 Users Say Thank You to alimazhar For This Useful Post:
Old 07-21-2005, 19:41   #200 (permalink)
Member: 153469
Thanks Meter: 2
Thanks a lot HuBMOBILE, for the Worldmate 2005, and alimazhar. for posting SKTools
Old 07-21-2005, 20:35   #201 (permalink)
Member: 153469
Thanks Meter: 2
HuBMOBILE, I have already install the Worldmate 2005, and then apply the crack .exe, for some reason when I try to updte the weather forcast, it says "Service Denied contact customer service" therefore I cannot update, what you think is the problem is it the crack doesn't work or what, please help if you know the solution, thanks again.
Old 07-22-2005, 13:00   #202 (permalink)
HuBMOBILE's Avatar
Member: 78673
Thanks Meter: 1,241
@Trek55
Here im Uploading the .nfo file, the cracker states that "when you update flight status the program going to trial mode." but at last he also states that he has fixed that bug, i don't know what could the exact Problem be..
(Maybe this bug has not been Fixed by the cracker still.)
The Following User Says Thank You to HuBMOBILE For This Useful Post:
Old 07-22-2005, 14:00   #203 (permalink)
MFC
MFC's Avatar
Member: 83741
Sonork: 100.1624702
Thanks Meter: 88
Hi Guys,
Sorry to bug you's but i just got my hands on an xda2, but i'am having problems with some application such as games? The problem being once i've uploaded the game to the xda it says " 'xxxxxx' is not a valid Pocket application.".I dowloaded the games from FuzionGSM's Forum in the pocket pc section.Any Ideas?
Regards
MFC
Old 07-22-2005, 18:44   #204 (permalink)
HuBMOBILE's Avatar
Member: 78673
Thanks Meter: 1,241
@MFC
In Which Format is it..??
Are you trying to transfer the .rar Files, if yes extract this .rar files first in your PC using Winrar, and then Start the .exe file or Simply transfer the .cab fle into your PPC and then it will automatically install the Appz for you..
Old 07-22-2005, 23:34   #205 (permalink)
Member: 153469
Thanks Meter: 2
Ya maybe the crack is not fully cracked...
The Following User Says Thank You to Trek55 For This Useful Post:
Old 07-23-2005, 04:51   #206 (permalink)
Member: 163161
Originally Posted by HuBMOBILE
DVD2PPC v2.0
Download
Crack
Help.
it cant crack it. pls help
Old 07-23-2005, 05:01   #207 (permalink)
Member: 163161
Originally Posted by Pip_X
How about ******* Chinese or CEStar software for PPC?
They is for writing and viewing chinese words on a PPC...
yap. i also looking for ******* chinese and smartmovie for my xda2i.
can anyone help. (tried smartmovie 2.72 cannot work on my pda. izzit i installed it wrongly , ls guide me.)
Old 07-23-2005, 08:55   #208 (permalink)
HuBMOBILE's Avatar
Member: 78673
Thanks Meter: 1,241
@kelvintan81
Download the Latest Version of SmartMovie v2.76 from the Official site..
http://lonelycatgames.com/download/s...c_lcg_2_76.zip
NOTE: You can use the Old Keygen(Supplied in the v2.72 in my earlier Post) to Register.
And If you need Some Instructions on how to install the App on your PDA, Go here..
Pocket PC Appz & Games
Old 07-23-2005, 10:27   #209 (permalink)
Member: 163161
@kelvintan81
thanks hubmobile.
and how about ******* chinese. i need this software to read chinese characters. can u help me with this also.
thanks lots.
cheers
Old 07-23-2005, 11:01   #210 (permalink)
AWAIS's Avatar
Member: 16520
Sonork: 1580837
Thanks Meter: 90
@HuBMOBILE
hi dear,
do you have Theme dream for ppc registered????
Palm Appz & Games HuBMOBILE PalmOS /HP and others 23963 06-19-2019 05:29
Nokia Latest Appz & Games Section HuBMOBILE Nokia Multimedia 17 11-21-2010 13:03
Whats wrong with the "Pocket pc appz & games" thread? brayndeded HTC & PDA WM( With Touchscreen) 0 01-15-2008 17:01
WM5 Pocket PC Appz & Games eboy44 HTC & PDA WM( With Touchscreen) 2 08-08-2006 22:23
Pocket PC Appz, games and more fuzionGSM GSM Mobile Links 0 05-03-2005 15:58
Page generated in 0.48890 seconds with 9 queries
