HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
08-08-2006, 06:26 | #2281 (permalink) | |
Junior Member Join Date: Aug 2006 Location: In a Van down by the River
Member: 324007 Status: Offline Thanks Meter: 1 | Quote:
I have a Ipaq hx4700 with wm2003 I installed just the .cab file that came in the quick notes today v1.5.5c rar file. I installed to main memory and worked just fine. When I installed just the .cab on my HTC wizard running WM5 and it woul'nt work. So it seems its only for WM2003(like it says in the description) So I guess i will just use the older version till a WM5 crack comes out. Thanks | |
08-08-2006, 07:07 | #2282 (permalink) | |
Freak Poster Join Date: Jul 2006
Member: 311312 Status: Offline Thanks Meter: 14 | Quote:
Did you try to install Trial version (quicknotes-v1_5_5c.exe) file BEFORE installing the Crack ( .CAB) file ? thanks. | |
08-08-2006, 07:10 | #2283 (permalink) | |
Yes, I just think the crack (.cab file) is only for wm2003. thanks | |
08-08-2006, 07:14 | #2284 (permalink) | |
Member: 322689 Status: Offline Thanks Meter: 6 | Quote:
08-08-2006, 08:26 | #2285 (permalink) |
Junior Member Join Date: Jan 2005 Age: 38
Member: 107759 Status: Offline Thanks Meter: 0 | anyone got a serial/ crack for the latest pocketmusic including the AAC plug in? EDIT: dont worry about it. my version comes up with this illegal version causes an error. and then i click ok and then it closes. and i;ve uninstalled and reinstalled it but its still the same. Last edited by kidwizz; 08-08-2006 at 08:56. |
08-08-2006, 09:10 | #2287 (permalink) | |
Member: 107759 Status: Offline Thanks Meter: 0 | Quote:
i did do. i'll see if i can find it now. edit. nope sorry i dont. i got mine from a torrent file. it has heaps on files in it | |
08-08-2006, 09:52 | #2291 (permalink) | |
Junior Member Join Date: May 2006
Member: 271802 Status: Offline Thanks Meter: 0 | Quote:
I tried already, it go simply not It will not be register...... | |
08-08-2006, 11:16 | #2293 (permalink) |
Member: 311312 Status: Offline Thanks Meter: 14 | AE Button Plus 2.4.1 AE Button Plus 2.4.1 Last updated: 7-Jun 2006 Requirements: WM 2003 / 2003SE / 2005 Summary: Allow to bind up to 4 different actions (programs or built in) to almost any hardware button including volume slider, SoftKey buttons and even green/red phone buttons. Picture Application Description: Extends functionality of hardware keys on Windows Mobile devices. It allows you to: * Intercept almost any standard button: application buttons, WM5 SoftKeys, Volume slider, Enter/Action and even Red/Green phone buttons * Distinguish up to 4 different keypress events on each button grabbed (single, double, triple and "long" keypresses) * Remap each of the keypress events to "virtual" application button or assign them directly to one of the built-in actions. Current set of built-in actions includes running applications with optional command line parameters, hardware buttons emulation, closing/switching current apps, number of built in actions like triggering display/WiFi/BlueTooth, clipboard operation, clock display etc. and even BUILT IN TASK MANAGER or battery monitor with UPTIME FORECAST As a result you may "convert" volume slider to up/down arrows, assign several essential application buttons to these "SoftKey" buttons and even assign your favorit alternative dialer to red/green phone buttons. It may be used on the following mobile devices: * Windows Mobile 2003 PocketPC and PocketPC Phone Edition * Windows Mobile 2003SE PocketPC and PocketPC Phone Edition * Windows Mobile 2005 PocketPC and PocketPC Phone Edition * Windows Mobile 2003SE Smartphone (*) * Windows Mobile 2005 Smartphone (*) (*), don't think this utility is useful on Smartphone. Anyway be sure to backup your Smartphone before installing AEBPlus. PocketPC users are safe because of touchscreen. Update Description: New keypress actions implemented. Battery monitor with uptime forecast, other usefull actions. SoftKey emulation fix Download: Here |
08-08-2006, 12:28 | #2295 (permalink) | |
Member: 324923 Status: Offline Thanks Meter: 0 | Quote:
Palm Appz & Games | HuBMOBILE | PalmOS /HP and others | 23989 | 04-01-2023 09:46 |
Nokia Latest Appz & Games Section | HuBMOBILE | Nokia Multimedia | 17 | 11-21-2010 14:03 |
Whats wrong with the "Pocket pc appz & games" thread? | brayndeded | HTC & PDA WM( With Touchscreen) | 0 | 01-15-2008 18:01 |
WM5 Pocket PC Appz & Games | eboy44 | HTC & PDA WM( With Touchscreen) | 2 | 08-08-2006 22:23 |
Pocket PC Appz, games and more | fuzionGSM | GSM Mobile Links | 0 | 05-03-2005 15:58 |
