Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > HTC > HTC & PDA WM( With Touchscreen)
HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices
Old 04-18-2010, 23:42   #1 (permalink)
COVVA's Avatar
Member: 142645
Sonork: 100.1604204
Repair imei htc touch+exca100+gene100
Hi friends..Here repair htc imei Touch(elf0101..)
1. Using goldcard..(sd card)
2. Create Goldcard.
XDADeveloperWiki - Elf_Gold Card.
3. Copy to goldcard 2 files: elfdiag.nbh+ELFIMG.nbh(mfg patch).
4. Put sd into htc touch without battery after put battery and press
power+camera button.
5. Show in htc.. "input pass" pass is: keys send+end + center button press
this buttons.ok
6. Press again center button to unlock htc touch ..
7. Repeat procces remove the battery in htc..insert battery..press
power+camera button enter pass: digit: key send+key end +key center
after press power button to reflash wait to succefull procces.
8. Desactive actyvesync ..desactive option allow usb connection.
9. Open mtty program connect htc elf.
10. Digit in mtty:
erasedata+enter
IMEI XX XX XX XX XX XX XX XX+enter
ResetDevice+enter
11. Is all
The Following 6 Users Say Thank You to COVVA For This Useful Post:
Old 04-19-2010, 00:14   #2 (permalink)
COVVA's Avatar
Member: 142645
Sonork: 100.1604204
RapidShare: 1-CLICK Web hosting - Easy Filehosting
Old 04-21-2010, 08:01   #3 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Any MFG patch for htc Viva u Opal 100 ?
Old 04-24-2010, 23:21   #4 (permalink)
COVVA's Avatar
Member: 142645
Sonork: 100.1604204
Make You Mfg patched...
Old 04-26-2010, 20:58   #5 (permalink)
Cheater -Don't Deal with him-
Member: 110715
Sonork: -
!!!!! You _____ !!!!
Old 04-27-2010, 18:43   #6 (permalink)
COVVA's Avatar
Member: 142645
Sonork: 100.1604204
Exca imei without goldcard..
Solution thanks to Dexter team monoxide .and ovalle team..STEP 1.
1. Unzip the file USPLMFG inside a folder called excavation or whatever.
2. Excalibur Htc Sync .. q with the syn actyve actyvesync get in verdesito.
March. Inside the folder you unzipped q q is a small program called sda unlock Correlo .. and dale click to remove ..
4. Now give upsl.bat and click to see by looking at the screen on the Excalibur on the screen of the excavation permits were installed give yes and yes and enter on the pc ..
5. Now the screen goes blank excalibur If it does not repeat the process until the blank .. q
6. Q After the screen is blank excalibur .. see a folder called excalibur-q-UCP upsl go to update and correlate rom is flashed dale accept a file and you will end the message congratulations.
7. After q turn the excalibur and put off the actyvesync in excalibur Nla tricolor boot you do this by giving a touch to down the Power and Botond and leaving the chamber.
8. After q is in the open tricolor mtty and you click on usb usb saldra das clik n cmd. Digitas him
erasedata 1 AND ENTER
IMEI 35 15 57 01 61 96 08 50 And ENTER
ResetDevice
Here the computer will restart q batteries here waiting restarts and when you leave the bar filling the battery lequitas setting ...
9. You place the battery put in tri-mode or boot the open excalibur mtty and digits:
ResetDevice
10. Normal clothes and let Q excalibur While you probably q give out a red screen .. ok yes
* Connect the excavation and sincronozas -
11. After normal garment excalibur proceed to open the band .. for this you open a folder called q q excalibur bands send you via mail .. ok open the Dash2bunlock of software to sync the excalibur simobolo green activesync ..
you will get a black screen in Dos give him enter, and then will ask you to run a file with the name of imei q is inside the same folder .. wait a while and the team with the bands there will be open ..
We now proceed to put the imei you want .. q
12. To put it simply disable Actyvesyc in trichloro and want to put the imei q
example
erasedata 1 and enter
IMEI 35 01 02 23 11 12 32 12 AND ENTER
ResetDevice and ENTER
13. Q hoped to restart the waiting exca lighting batteries go you expect q saldra mobileoperator the glimpse of hope from there will tell you des q ready click the bar you fill out allli you remove the battery -
14 - Put the battery put back in tricolor and digits ..
Original tutorial for me from:" Excuseme my English"
PASO 1.
1. Descomprime el archivo USPLMFG dentro de una carpeta llamada exca o como quieras.
2. Sincroniza la Htc Excalibur..con el actyve syn q el actyvesync se ponga en verdesito.
3. Dentro de la carpeta q descomprimiste hay un programita q se llama sda unlock correlo.. y dale click a remove..
4. Ahora dale click a upsl.bat y ves fijandote en la pantalla de la excalibur en la pantalla de la exca se instalaran permisos dale si y si y enter en el pc..
5. Ahora l a pantalla de la excalibur se pondra en blanco si no sucede asi repite el proceso hasta q este en blanco..
6. Despues q la pantalla de la excalibur este en blanco..ves a la carpeta q se llama excalibur-upsl-ruu vete al rom update y correlo dale aceptar este flasheara un archivo y al final te saldrą el mensaje congratulations.
7. Despues de q prenda la excalibur desactiva el actyvesync y pon en tricolor en boot ńla excalibur esto lo haces dandole un toque al power y dejando presionado el botond e la camara.
8. Luego de q este en tricolor abres el mtty y das click en usb das clik n usb saldra cmd. y le digitas
erasedata 1 Y ENTER
IMEI 35 15 57 01 61 96 08 50 Y ENTER
ResetDevice
Aqui el equipo se reiniciarą pilas aca esperas q se reinicič y cuando te salga la barrita de llenado de configurando ...lequitas la pila
9. Colocas la pila pones en tricolor o en modo boot la excalibur abres mtty y digitas:
ResetDevice
10. Dejas q prendas Normal y bien la excalibur es probable q te salga una pantalla roja dale yes..ok
* Conectas la exca y sincronozas--
11. Despučs de que prenda normal la excalibur procedemos a abrir la bandas..para esto abres una carpeta q se llama bandas de excalibur q se te enviara via mail..ok abres el programita Dash2bunlock sincronizas la excalibur simobolo de activesync en verde..
te saldrą una pantalla negra en Dos le das enter,,y corre luego te pedira un archivo con el nombre del imei q esta dentro de la misma carpeta esperas un tanto..y el equipo alli estara con las bandas abiertas..
Ahora procederemos a colocar el imei q tu quieras..
12. Para esto sencillamente desactivas Actyvesyc pon en triclor y pon el imei q quieras
ejemplo
erasedata 1 Y enter
IMEI 35 01 02 23 11 12 32 12 Y ENTER
ResetDevice y ENTER
13. Espera q se reinicie la exca esperas pilas esperas q vaya prendiendo te saldra el pantallazo de mobileoperator de alli esperas te dira q le des clic en listo te sale la barra de llenado allli quitas la pila--
14- Colocas la pila pones de nuevo en tricolor y digitas..
ResetDevice y ENTER
15. Espera q reinicie normal y listo----verificas
......................files upload in 4 hours..
The Following 4 Users Say Thank You to COVVA For This Useful Post:
Old 04-28-2010, 03:07   #7 (permalink)
COVVA's Avatar
Member: 142645
Sonork: 100.1604204
Here excadiag...imei alphanumeric+unlock 5 seg to exca 100.
The Following 2 Users Say Thank You to COVVA For This Useful Post:
Old 04-28-2010, 03:48   #8 (permalink)
COVVA's Avatar
Member: 142645
Sonork: 100.1604204
Img spanish way goldcard..
copy to goldcard..excadiag.nbh+EXCAIMG.NBH
Download EXCAIMG.rar from Sendspace.com - send big files the easy way
Insert Goldcard to exca
Put in Test exca
press power button+camera button
input pass: press..send button+end button+center button(red button+green button+center button)..
Press center button..after power button..and ok Imei is changes alphannumeric..number.
Flash..6 leanguages.
1. With Goldcard in exca..
2. Put in test ..press power button+camera button.
3. Show Display Input pass.Digit..only key send+jkey end.
4. Press power button..
5. Wait to screen show sucefull is allTomaroow solution Imei numeric files..thanks----
Old 04-28-2010, 03:53   #9 (permalink)
COVVA's Avatar
Member: 142645
Sonork: 100.1604204
Gene 100 unlock solution+imei solution goldcard
Here...gene 100 unlock+imei alpha solutions.
Old 04-28-2010, 03:58   #10 (permalink)
COVVA's Avatar
Member: 142645
Sonork: 100.1604204
Opal100...htc viva unlock solution with goldcard
Here diag opal100 same htc Viva only put opaldiag in sd(goldcard)..Insert sd in htc remove battery..put battery and on hct with power button+down volumen button. Input pass is: Digit send button+end button +center button..afer power button is All..Unlockk freeeeeeeee 1 min....
Old 04-28-2010, 05:37   #11 (permalink)
Member: 110715
Sonork: -
Another guy killling HTC market... Anyway, this is the worst thing i ever seen!
Old 04-28-2010, 06:45   #12 (permalink)
Member: 459220
Sonork: 100.1590597
yes friend luigivsf u have the reason
i dont understand
these people that win with post and give free
win much thanks of comunity
and win fame
jajajaj but no matter always free kill market all jajaja
another more than ****ty
regards
pd_ ;learned or not born gifted
but I think this should be in a box or should be a very private software not to do this,,,much work to vote in the trash
GaMmaHigh Colombia
htc unlock and ixxx long time ago
Old 04-28-2010, 10:10   #13 (permalink)
cellsolution's Avatar
Member: 121078
Sonork: 100.1590676
COVVA Good work..
But dear u earns nothing by posting this left to thanks.
Keep watch on Olipor & all graps. U illl come to know wt u did.
Anyways great job for market people.
Old 04-28-2010, 13:52   #14 (permalink)
.:SUBRATA:.'s Avatar
Member: 319447
@ cellsolution
This is GSM Market all about my friend
BTW Nice to see you again.
Old 04-28-2010, 15:04   #15 (permalink)
Member: 110715
Sonork: -
Originally Posted by .:SUBRATA:. View Post
@ cellsolution
Probably you're right, but HTC was the unique market that wasnt too dead. Now is gone, no one will spend on boxes and those stuff
Anyway, another GSM market killer
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 07-31-2012 20:09
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 04-06-2012 16:22
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 11-21-2011 00:44
Working IMEI changed phone? Barjo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 10-08-1999 14:22
Imei Arnis Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 09-15-1999 02:38
Page generated in 1.33679 seconds with 14 queries
