Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC & PDA WM( With Touchscreen)
HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices
Old 08-11-2007, 15:11   #1 (permalink)
BURHANLAHERI's Avatar
Member: 242626
Thanks Meter: 218
Arrow Some registry Twiking for WM3, WM5 and WM6
Here is some useful Registry twik for Windows Mobile. Some time its spped up you device a little or help you from unwanted items.
Increase Ringer Volume:
navigate to: HKCurrentUser\ControlPanel\SoundCategories\Ring\In itvol
change from 3 to 5 (anything over 5 seems to be the same volume)
NEW!
Hack for louder ear piece volume for verizon.
Dial ##778
Tap Edit
Unlock Code 000000
Tap Display Arrow goto CDMA Settings
Tap and hold "EVRC Enabled" line
Select Edit
Switch to Disabled
Tap OK
Tap and hold "Home Page" line
Select edit
Switch to "Voice 13k"
-Also switch "Home Orig" and "Roam Orig" to "Voice 13k"
NEW!
Disable Flight Mode:
Go to the registry and change the following key:
HKEY_CURRENT_USER -> ControlPanel -> PhoneExtendFunction -> CDMA
Change FlightModeSwitchByPnHEndKey to 0
NEW!
To Remove Screen Rotation:
HKLM\services\screenrotate === change from 1 to 0 (zero)
To Remove the Wireless connection manager
HKEY_LOCAL_MACHINE\Services\WirelessMgr and change the DWORD Keep to 0,
NEW!
Repeat Notifications--Turn them on (source)
This will enable the "Repeat" option within Sounds and Notifications for Phone: Missed Call.
\HKCU\ControlPanel\Notifications\{A877D660-239C-47a7-9304-0D347F580408}
Options
Value data: 1073741845
Decimal
Changing this registry setting enables the Repeat option as well as "Flash Light for 15 minutes". You can make changes to any of the options, as needed and the Repeat should stay enabled.
Alternatively, you can do a quick FIND within your registry for "missed call" and this should help you to quickly locate the proper key.
Disable menu animations
To disable menu animations (sliding in/out) and speed up performance of the UI a bit:
HKLM\SYSTEM\GWE\Menu\AniType = 0 (DWORD decimal)
To change it back to the default:
HKLM\SYSTEM\GWE\Menu\AniType = 6 (DWORD decimal)
Disable window animations
To disable window animations (minimizing/maximizing) and speed up performance of the UI a bit:
HKLM\SYSTEM\GWE\Animate = 0 (DWORD decimal)
And to switch them back on:
HKLM\SYSTEM\GWE\Animate = 1 (DWORD decimal)
Increase font cache
To increase the font cache, speeding up font rendering at the cost of a bit of memory:
HKLM\SYSTEM\GDI\GLYPHCACHE\limit = 16384 (DWORD decimal)
HKLM\SYSTEM\GDI\GLYPHCACHE\limit = 8192 (DWORD decimal)
You can set the value to pretty much anything you like
Enable FileSystem cache
To enable the FileSystem cache, speeding up overall performance at the risk of the cache not being written on a sudden reset:
HKLM\System\StorageManager\FATFS\EnableCache = 1 (DWORD decimal)
To disable again:
HKLM\System\StorageManager\FATFS\EnableCache = 0 (DWORD decimal)
Note that by default, the cache size is zero, and you will see no effect. See "Increase FileSystem cache" to incease the cache size
To increase the file system cache:
HKLM\System\StorageManager\FATFS\CacheSize = 4096 (DWORD decimal)
To return the file system cache to zero:
HKLM\System\StorageManager\FATFS\CacheSize = 0 (DWORD decimal)
Increase FileSystem filter cache
To enable the file system filter cache, speeding up overall performance with file mangement:
HKLM\System\StorageManager\Filters\fsreplxfilt\Rep lStoreCacheSize = 4096 (DWORD decimal)
To return the file system filter cache to zero:
HKLM\System\StorageManager\Filters\fsreplxfilt\Rep lStoreCacheSize = 0 (DWORD decimal)
Change the thickness of scrollbars
To change the thickness of the scrollbars at the right/bottom of documents larger than the screen, adjust...
For the horizontal (bottom) scrollbar:
HKLM\System\GWE\cyHScr = 9 (DWORD decimal)
For the vertical (right) scrollbar:
HKLM\System\GWE\cxVScr = 9 (DWORD decimal)
The default thickness is 13. You can set the value to pretty much anything you like
Change the length of scrollbar arrow buttons
To go with changing the thickness of the scrollbars, you may wish to change the length of the scrollbar arrow buttons...
For the horizontal (bottom) scrollbar arrows:
HKLM\System\GWE\cyVScr = 9 (DWORD decimal)
HKLM\System\GWE\cxHScr = 9 (DWORD decimal)
The default length is 13. You can set the value to pretty much anything you like
Enable ClearType in Landscape mode
To enable ClearType in Landscape mode:
HKLM\System\GDI\ClearTypeSettings\OffOnRotation = 0 (DWORD decimal)
To disable:
HKLM\System\GDI\ClearTypeSettings\OffOnRotation = 1 (DWORD decimal)
Note that your PocketPC screen's LCD red/green/blue ordering required for proper ClearType display is only correct for Portrait display. You may or may not prefer to leave ClearType in Landscape mode disabled
Add a 'Disconnect' button (and Timer) to the Connection List for GPRS
To add a Disconnect button:
HKLM\ControlPanel\Phone\Flags2 = 8 (DWORD decimal)
To add a Disconnect button and a timer display showing how long GRPS is in use for the session:
HKLM\ControlPanel\Phone\Flags2 = 16 (DWORD decimal)
To disable both the Disconnect button and the timer:
HKLM\ControlPanel\Phone\Flags2 = 0 (DWORD decimal)
Change the 'user agent' identification of Pocket Internet Explorer
To change the 'user agent' identification of Pocket Internet Explorer, several fields need to be adjusted. The example shows how to identify as Internet Explorer 6 - desktop version
The standard compliance 'user-agent' string:
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings\5.0\User Agent\(Default) = "Mozilla/4.0" (REG_SZ string, no quotes)
Defaults to "Mozilla/2.0" The application/version string:
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings\5.0\User Agent\Version = "MSIE 6.0" (REG_SZ string, no quotes)
Defaults to "MSIE 4.01" The host operating system string:
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings\5.0\User Agent\Platform = "Windows NT 5.0" (REG_SZ string, no quotes)
Defaults to "Windows CE" Please note that if you change the Platform string, PDA-friendly sites may stop sending you PDA-friendly content automatically. Leave this string set to "Windows CE" unless a site absolutely refuses to work, or you want the site to feed you its normal content.
Change the location of 'Temporary Internet Files'
When browsing the web, pages and images are saved in the 'Temporary Internet Files' location. You can change this location to, for example, your Storage Card:
HKCU\Software\Microsoft\Windows\CurrentVersion\Exp lorer\Shell Folders\Cache = "\Storage Card\cacheie" (REG_SZ string, no quotes)
To return to the original location:
HKCU\Software\Microsoft\Windows\CurrentVersion\Exp lorer\Shell Folders\Cache = "\Windows\Profiles\guest\Temporary Internet Files" (REG_SZ string, no quotes)
Change the display of the clock in the taskbar
The clock in the taskbar can be changed to show not only the time, but also the date, or just the date, or nothing at all.
To show nothing:
HKLM\Software\Microsoft\Shell\TBOpt = 0 (DWORD decimal)
To show just the clock:
HKLM\Software\Microsoft\Shell\TBOpt = 1 (DWORD decimal)
To show just the date:
HKLM\Software\Microsoft\Shell\TBOpt = 2 (DWORD decimal)
To show both the date and the clock:
HKLM\Software\Microsoft\Shell\TBOpt = 3 (DWORD decimal)
Note 1: If you switch to the Analog clock display, the date will remain visible -through- the Analog clock
Note 2: Setting the clock to show 'nothing' will still keep the reserved space, showing the taskbar background, and obscure any icons that will shift to the right.
Note 3: Your date may get obscured by the space reserved for the OK/Close button in the top-right. You can fix this my adding spaces at the end of your 'Short Date Format'. See also the tweak on 'Change the Short Date Format'
Applications may call upon the system to provide a 'short date format'. One such application is the Date/Time display in the taskbar, if set to show the date. To change the Short Date Format to show "Mon/2" (example):
HKLM\nls\overrides\SSDte = "ddd/d " (REG_SZ string, no quotes)
Note 1: For more information on date/time formatting strings, see: http://msdn.microsoft.com/library/d...dateformats.asp
Note 2: All applications using the short date format will be affected by this change. Choose wisely
Disable the security warning when installing non-certified application
To disable the security warning when installing a non-certfied application, set:
HKLM\Security\Policies\Policies\0000101a = 1 (DWORD decimal)
To restore the warnings:
HKLM\Security\Policies\Policies\0000101a = 0 (DWORD decimal)
Note that this makes it easier for any malware to install itself
Default SMS Delivery Notifications to on
To always have SMS Delivery Notifications enabled:
HKCU\Software\Microsoft\Inbox\Settings\SMSDelivery Notify = 1 (DWORD decimal)
To disable them (can still enable per-SMS in SMS settings):
HKCU\Software\Microsoft\Inbox\Settings\SMSDelivery Notify = 0 (DWORD decimal)
Note that SMS Delivery Notifications are a network provider option, and the recipient may refuse them to be sent out
Change the application launched by Today screen Soft Keys
To change the application launched by the Today screen Left soft key:
HKCU\Software\Microsoft\Today\Keys\112\Open = "\Windows\Calendar.exe" (REG_SZ string, including quotes)
To change the title of the Left soft key:
HKCU\Software\Microsoft\Today\Keys\112\(Default) = Calendar (REG_SZ string, no quotes)
To change the application launched by the Today screen Right soft key:
HKCU\Software\Microsoft\Today\Keys\113\Open = "\Windows\Calendar.exe" (REG_SZ string, including quotes)
To change the title of the Right soft key:
HKCU\Software\Microsoft\Today\Keys\113\(Default) = "Calendar" (REG_SZ string, no quotes)
Note that 113 normally doesn't exist by default, and probably needs to be created Also note that there is at least 1 application that allows you to set these through a GUI, developed by FdcSoft called SoftKeyAppletEx
Disable 3gp (video) size limit (only on HTC devices)
To disable the 3gp (video recording format) size limit:
HKLM\SOFTWARE\HTC\camera\AppDefSettings\P3\EnableL imit = 0 (DWORD decimal)
To re-enable:
HKLM\SOFTWARE\HTC\camera\AppDefSettings\P3\EnableL imit = 1 (DWORD decimal)
Add GPS settings icon
If you have a GPS device, you can add a GPS settings icon to your Start > Settings menu using:
HKLM\ControlPanel\GPS Settings\Group = 2 (DWORD decimal)
HKLM\ControlPanel\GPS Settings\redirect <-- delete, or rename, this value
Note that '2' stands for the Connections tab, '1' is System and '0' would be Personal
Add Lunar Calendar mode to Calendar
You can add a Lunar Calendar mode to the Calendar view, showing a 'Month' view with the Lunar months/days.
HKLM\Software\Microsoft\Calendar\ShowLunarCalendar = 1 (DWORD decimal)
And to disable again:
HKLM\Software\Microsoft\Calendar\ShowLunarCalendar = 0 (DWORD decimal)
Change location of ringtones
You can change the location where WM5 will look for ringtones by adjusting the following key (example given is for ringtones placed on the Storage Card root folder)
HKCU\ControlPanel\Sound\Categories\Ring\Directory = "\Storage Card\" (REG_SZ string, no quotes)
The default location may be "\Windows\" or "\Windows\Rings\" depending on your Device provider
Change slide-out keyboard layout
If you have a Device from one country, but would like to use the keyboard layout of another, you can change the keyboard's language setting to do so...
For US layout (QWERTY):
HKCU\ControlPanel\Keybd\Locale = 1033 (DWORD decimal)
For German layout (QWERTZ):
HKCU\ControlPanel\Keybd\Locale = 1031 (DWORD decimal)
For French layout (AZERTY):
HKCU\ControlPanel\Keybd\Locale = 1036 (DWORD decimal)
For other codes, see: hxxp://www.microsoft.com/globaldev/...p/xp-lcid.mspx
Make reminders show only once
By default, reminders will keep bugging you for 2 minutes. You can change this to zero minutes by adjusting this value:
HKCU\ControlPanel\Notifications\Reminders\AutoSnoo ze\AutoSnoozeMins = 0 (DWORD decimanl)
Note that you can set this to any value you like. Alternative to setting this value to zero is to delete the '?AutoSnooze' key altogether
Remove operator skin from Phone app
If your device's Phone app is skinned, you can remove by setting:
HKLM\Security\Phone\Skin\Enabled = 0 (DWORD decimal)
Similarly, you can restore it with:
HKLM\Security\Phone\Skin\Enabled = 1 (DWORD decimal)
Enable/Disable receiving of files over BlueTooth/IrDA
If you want to prevent receiving files over BlueTooth or IrDA, you can set the following value:
HKLM\Software\Microsoft\Obex\IsEnabled = 0 (DWORD decimal)
And to (re-)enable:
HKLM\Software\Microsoft\Obex\IsEnabled = 1 (DWORD decimal)
GPRS always on
If you want your GPRS (or EDGE) connection to always be on, set the following:
HKLM\Comm\ConnMgr\Providers\{7C4B7A38-5FF7-4bc1-80F6-5DA7870BB1AA}\|gprs connection name|\AlwaysOn = 1 (DWORD decimal)
And to turn it off:
HKLM\Comm\ConnMgr\Providers\{7C4B7A38-5FF7-4bc1-80F6-5DA7870BB1AA}\|gprs connection name|\AlwaysOn = 0 (DWORD decimal)
Note that |gprs connection name| will depend on the name you've given your GPRS connection
Hide/Show Screen orientation icon
If you wish to hide the Screen orientation icon, shown in the task bar on some devices, you can set:
HKLM\System\GDI\Rotation\HideOrientationUI = 1 (DWORD decimal)
And to show it again:
HKLM\System\GDI\Rotation\HideOrientationUI = 0 (DWORD decimal)
If this doesn't work, you can try:
HKLM\Services\screenrotate = 0 (DWORD decimal)
HKLM\Services\screenrotate = 1 (DWORD decimal)
Note that this icon and its feature may not be available on your device at all.
Hide/Show battery indicator in Task bar
If you wish to hide the battery indicator in the task bar on some devices, you can set:
HKLM\Services\Power\ShowIcon = 0 (DWORD decimal)
And to show:
HKLM\Services\Power\ShowIcon = 1 (DWORD decimal)
Note that this icon and its feature may not be available on your device at all. For example, the HTC Wizard regularly ships with a battery indicator in the Tray instead, governed by "Windows\Startup\Init_Tray.exe".
Change ringtone/vibrate/LED flash characteristics
If you would like more control over how your device rings/vibrates/flashes its LEDs on events, you can can change the Script values of these events. For example, for an incoming call performing 'activate device, play ringtone, wait 3 seconds, repeat':
HKCU\ControlPanel\Sounds\RingTone0\Script = "apw3r" (REG_SZ string, no quotes)
For performing 'active device, set volume to 33%, play ringtone, set volume to 67%, play ringtone, set volume to 100%, play ringtone (no repeat)':
HKCU\ControlPanel\Sounds\RingTone0\Script = "ac33pc67pc100p" (REG_SZ string, no quotes)
The following are the full codes available to you. Please note that all the codes are executed simultaneously except after a ringtone play / wait code. E.g. 'v1p' will vibrate and play at the same time, while vibrating for 1 second. But 'pv1' will play the ringtone through all the way first, then start vibrating for 1 second.
a = activate device
cN = set volume to N in percentage max volume
fN = flash notification LED for N seconds
p = play ringtone. Note that this will play the ringtone all the way through before continuing with the next code.
r = repeat. Note that this should be the last code in your Script string, if used at all.
vN = vibrate for N seconds
wN = wait for N seconds. Note that the device will wait this long before continuing with the next code.
Disable the SMS Sent notification
If you're tired of the "Message Sent" notification after sending an SMS/text message, you can disable them:
HKLM\Software\Microsoft\Inbox\Settings\SMSNoSentMs g = 1 (DWORD decimal)
And to re-enable:
HKLM\Software\Microsoft\Inbox\Settings\SMSNoSentMs g = 0 (DWORD decimal)
Please note that the 'Settings' key may not exist in your device, and thus may have to be created first.
Change the SMS Sent notification text
If you just want the "Message Sent" notification to read something different, adjust the following:
HKLM\Software\Microsoft\Inbox\Svc\SMS\MessageSent = "Message Sent" (REG_SZ string, no quotes)
Always require SMS Delivery notification
If you always want an SMS Delivery notification (see note below!), and are tired of ticking the 'Request message delivery notification' checkbox, set:
HKLM\Software\Microsoft\Inbox\Settings\SMSDelivery Notify = 1 (DWORD decimal)
To disable again:
HKLM\Software\Microsoft\Inbox\Settings\SMSDelivery Notify = 0 (DWORD decimal)
Note 1: Delivery notifications will depend on your and the recipient's operator network capabilities! Note 2: You can still override this with the regular checkbox.
Disable charging over USB
If your device can charge over USB, you can probably disable this feature by setting:
HKLM\Drivers\BuiltIn\usbfndrv\EnableUsbCharging = 0 (DWORD decimal)
And to re-enable:
HKLM\Drivers\BuiltIn\usbfndrv\EnableUsbCharging = 1 (DWORD decimal)
Show Calendar event text in Week View
If you wish to see a Calendar event's text in the Week View, set the following:
HKCU\Software\Microsoft\Calendar\ShowTextInWeekVie w = 1 (DWORD decimal)
To disable it again:
HKCU\Software\Microsoft\Calendar\ShowTextInWeekVie w = 0 (DWORD decimal)
Please note that your event must have long enough a duration to show the event text, and the week view (with its narrow columns) truncates long words easily
Also note that the key "Calendar" may not exist - just create it if it doesn't
The Following 2 Users Say Thank You to BURHANLAHERI For This Useful Post:
Old 02-06-2009, 20:12   #2 (permalink)
Member: 965516
Have you or can you post an edit that will disable the missed call and voice message notification that's in the lower left of the screen?
The Following User Says Thank You to iSwami For This Useful Post:
Spb Pocket Plus v4.0.2 for WM5 & WM6 Full rmgrms HTC & PDA WM( With Touchscreen) 12 12-17-2016 02:46
windows mobile wm ce,wm5,wm6 and wm6.1 apps here sphameed HTC & PDA WM( With Touchscreen) 3 07-07-2009 03:03
HTC 9100 (Qtek) upgrade from WM5 to WM6? 9100user HTC & PDA WM( With Touchscreen) 8 12-26-2007 23:49
Upgrading Wm5 To Wm6? lawman HTC & PDA WM( With Touchscreen) 0 05-19-2007 10:40
Page generated in 0.24429 seconds with 9 queries
