Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Walton
Old 11-06-2015, 09:26   #16 (permalink)
Dipankor-ctg's Avatar
Member: 1541551
Sonork: +965 99095810
Thanks Meter: 4,698
Primo EM Firmware Flashing Instructions
Software Download Link- Simple File Sharing and Storage.
1. Install the drivers
2.Open Flash Tool
3. Pac Loading
a. Click "Load Packet". (number "a" showed in the image). New window will appear.
b. Enter "Primo_EM_software_service+sw" folder and select "Walton_Primo_EM_W533_M00_S04S_150619" file (number "b" showed in the image).
c. Click "Open" (number "c" showed in the image)
4. Now Click Firmware Upgrade (Click "Start")
5. Connect The Handset
After clicking the "Start", press the volume down key of your handset, and connect it to your computer with USB cable. Remember: Before connecting the handset with your computer, you must turn it off. Also notice that the battery has to be kept inserted.
Flash operation will begin, you will see this window:
[IMG]http://s22.postimg.org/o***ln75d/image.png[/IMG]
6. There will appear "Passed". This means it is successful.
Disconnect phone, open battery and reconnect again (If non-removable). Enjoy!!
Old 11-06-2015, 09:29   #17 (permalink)
Member: 1541551
Thanks Meter: 4,698
Flash Tool Instruction of Primo EF3
Download Link- Primo EF3 Lollipop Firmware
Step 1: Driver Installation
Step 2: Open Flash Tool
Open the Flash Tool. Enter folder named "UPGRADEDOWNLOAD_R2.9.9001". Then enter file named "Bin". There you will see an icon named "FactoryDownload.exe"
Step 3: Pac Loading
a. Click "Load Packet". (Number "a" showed in the image). New window will appear.
b. Enter "Primo EF3 Lollipop Firmware" folder, then select “Lollipop Firmware” then select "Walton_Primo_EF3_W821_M00_S02_151022.pac" file (number "b" showed in the image).
Step 4: Firmware Upgrade
a.Click "Start". (Number "a" showed in the image).
Step 5: Connect The Handset
After clicking the "Start", press the volume down key of your handset, and connect it to your computer with USB cable. Try to hold the volume down button at least 30 sec.
Step 6: Notification
Old 11-06-2015, 09:30   #18 (permalink)
Member: 1541551
Thanks Meter: 4,698
Primo EF2 Driver, Flashtool & Firmware download Link:
EF2_4.4.2_1
1.Click on Install.bat File
2.Open SPMultiportFlashDownloadProject tool
3.Run download tool
4. Select the MT6582_Android_scatter.txt scatter file
5.Click “Start all”start download
Old 11-06-2015, 09:32   #19 (permalink)
Member: 1541551
Thanks Meter: 4,698
official Firmware Flashing Instructions of Primo E5
Firmware Download Link-
Primo E5 Firmware
1. Install driver.
2. Open Flash Tool
3. Open scatter_loading and select scatter file
(Primo E5 Firmware Ă softwareĂ MT6572_Android_scatter)
4. Click Firmware Upgrade
5. Now select Download and then connect USB cable with mobile (mobile must be off)
6. If you see below image, it means that mobile is detected through Usb cable
7. When it shows Download Ok, it means the installation/flashing firmware is completed.
Old 11-06-2015, 09:33   #20 (permalink)
Member: 1541551
Thanks Meter: 4,698
Lollipop Firmware Flashing Instructions for Primo E4+
Walton_Primo_E4+(Android 5.0 )
1. Extract Downloaded Firmware.
2. Install driver software
3. Open SP Flash Tool
4. Open Download Agent and select MTK_AllinOne_DA
5. Open scatter_loading and select scatter file
(Walton_Primo_E4+(Android 5.0 )\Primo_E4+_Lollipop\MT6582_Android_scatter)
6. Click Firmware Upgrade
7. Now select Download and then connect USB cable with mobile (mobile must be off). If you see below image, it means that mobile is detected through Usb cable.
8. Then start downloading/flashing firmware
9. When it shows Download Ok, it means the installation/flashing firmware is completed. Enjoy Lollipop.
Old 11-06-2015, 09:34   #21 (permalink)
Member: 1541551
Thanks Meter: 4,698
Primo E4 Driver, Flashtool & Firmware
Download Link: E4_4.4.2_1
1. Install driver.
2. Open Flash Tool
3. Open Download Agent and select MTK_AllinOne_DA
4. Open scatter_loading and select scatter file
SW---> Primo_E4_V1.0.0_S - CopyĂ MT6582_Android_scatter
5. Click Firmware->Upgrade andconnect USB cable with mobile (mobile must be off)
6. Then start downloading..
7. When it shows Firmware Upgrade , then installation is completed.
Old 11-06-2015, 09:42   #22 (permalink)
Member: 1541551
Thanks Meter: 4,698
Primo F Series
New official firmware for primo F1 (Build Number: A51B_WALTON_V0_0_9) [solved: black screen, memory & others bugs]
D/L text file from attachment "Primo F1 FW v. 0_0_9" you will get download link
Guide:
1. Install USB cable drive software. (From "Driver" folder )
2. Open Flash Tools MultiportDownload.exe (From "Download Tools" folder)
3. Select smart phone and press ok.
4. Click "Select file" for select scatter file
5. Select scatter file (MT6575_Android_scatter_emmc) from software folder (Under "WALTON_Primo_F1_Firmware" folder)
6. Download file load successfully will show. click "ok" button.
7. Press "Start all"
8. Under POWER OFF mode press & hold Volume up and down key together, then put USB cable in to Handset charging port
(with battery). Software process will be start within few second.
9. Wait till complete software update process.
** NOTES... If auto driver installation failed (step 1) then install manually after ( step 8 ) connect USB Cable as soon as possible.)
https://drive.google.com/uc?id=0B_h4...jBlY3JfaVRXTEk
Old 11-06-2015, 09:49   #23 (permalink)
Member: 1541551
Thanks Meter: 4,698
Firmware Flashing Instruction of WALTON PRIMO F6
Software Download Link- Primo F6 firmware
1. Install drivers
2. Open Flash Tool
(Primo F6 Firmware>Walton_Primo_F6_S006_02072015ŕMT6580_Android_scatter)
4. Click FirmwareUpgrade then select Download and then connect USB cable with mobile (mobile must be off)
5. Now start downloading/flashing firmware
6.When it shows Download Ok, it means the installation/flashing firmware is completed.
Old 11-06-2015, 09:51   #24 (permalink)
Member: 1541551
Thanks Meter: 4,698
Primo F5 Driver, Flashtool & Firmware download Link:
http://www.mediafire.com/download/rqprxjcv7o3bxq0/F5_4.4.2_1.rar
# Install Driver by clicking “install” from “Driver” folder
# Open Flash tool (MultiPortDownload.exe file from flash tools folder)
  1. Set Scatter-loading (“MT6582_Android_scatter.txt “file from “SW” folder)
  2. Click, Start all
3. Press and hold volume up key and then Connect USB cable
It will starts SW Upgrading and After several seconds, it will show “Cksm(FAT) OK…100% “ with green icon.
Done!!!
Old 11-06-2015, 09:55   #25 (permalink)
Member: 1541551
Thanks Meter: 4,698
  2. Click, Start all
Done!!!
Old 11-06-2015, 09:55   #26 (permalink)
Member: 1541551
Thanks Meter: 4,698
Primo F4 Official Driver, flashtools & firmware download Link: F4_4.2.2_1
1. Install driver.
2. Open Flash Tool
SW--- MT6572_Android_scatter.txt
5. Click Firmware->Upgrade and connect USB cable with mobile (mobile must be off)
After Firmware Upgrade give Reset to Factory setting to get all apps.
Old 11-06-2015, 09:56   #27 (permalink)
Member: 1541551
Thanks Meter: 4,698
Download Link: F3i Complete
Release note:
1. Faster and better performance
2. New boot logo
3. Wallpaper changed
4. New ring Tone added
5. Bd Data plan & Walton flashlight (Latest Version) is included.
1.Install driver:
5. Select scatter file (MT6572_Android_scatter) from software folder (Under "WALTON_Primo_F3_Firmware" folder)
8. Under POWER OFF mode press & hold Volume up and down key together, then put USB cable in to Handset charging port(with battery). Software process will be start within few second.
Old 11-06-2015, 09:57   #28 (permalink)
Member: 1541551
Thanks Meter: 4,698
Firmware, Flashtools & Driver Download Link:
1. Install driver. F2 firmware
Instruction:
2. Open Flash Tool
SW---> WBW6803WA_0410_T8142 MT6577_Android_scatter_emmc
5. Click Firmware->Upgrade and connect USB cable with mobile without battery
6. Insert Battery then start downloading..
Old 11-06-2015, 10:39   #29 (permalink)
Member: 1541551
Thanks Meter: 4,698
Software Download Link- 1. Install the drivers
2.Open Flash Tool
3. Pac Loading
Old 11-06-2015, 10:50   #30 (permalink)
Member: 1541551
Thanks Meter: 4,698
http://download673.mediafire.com/cm6...M+Firmware.rar
Page generated in 0.37965 seconds with 9 queries
