04-16-2017, 05:43 | #61 (permalink) |
Insane Poster Join Date: Aug 2012 Location: philippine Age: 39
Member: 1803654 Status: Offline Sonork: 12345 Thanks Meter: 10 | how to fix it, qualcom v1.2 is ok, but falcon v3.0 connot open?????? Screenshot by Lightshot |
04-17-2017, 17:36 | #62 (permalink) | |
Member: 1803654 Status: Offline Sonork: 12345 Thanks Meter: 10 | Quote:
Realy i need this tools. | |
04-20-2017, 18:33 | #63 (permalink) |
Junior Member Join Date: Oct 2011
Member: 1679785 Status: Offline Thanks Meter: 2 | Please Login to Continue If You are New User Please Fill Mail and Password and Click Login Establishing secured session... Session Established.. Serial MICBX15V00017078 License File Not Found !!! Click Get License !!! plz solve my problem? |
04-28-2017, 18:03 | #64 (permalink) |
Freak Poster Join Date: Sep 2010
Member: 1397982 Status: Offline Thanks Meter: 44 | When install setup v2.7 my falcon box not open, not open falcon any window. Till my box and falcon dead now. Please help . How run box now. SORRY FOR MY BAD ENGLISH.Thanks. SORRY FOR NOT POST SCREENSHOT BECAUSE NOT OPEN ANY WINDOWS OF FALCON BOX |
04-28-2017, 20:00 | #65 (permalink) | |
Product Supporter Join Date: Oct 2009 Location: Mumbai. Great India
Member: 1135304 Status: Offline Sonork: 100.1592050 QQ:3549168141 Thanks Meter: 4,071 | Quote:
http://forum.gsmhosting.com/vbb/f982...nside-2198402/ | |
05-01-2017, 16:10 | #71 (permalink) |
Freak Poster Join Date: Apr 2017
Member: 2711418 Status: Offline Thanks Meter: 28 | Samsung Galaxy Edge G935P on PL6 Sim Unlock Unsuccessful Samsung Galaxy Edge G935P on PL6 Sim Unlock says completed but was Unsuccessful This Phone was a nightmare 4 days of Hell First had FRP on it I tried to Use Falcon tool 3.0 it kept saying FRP Successful but the FRP was still on the phone so then I tried all 3 methods Under Android Tool tab for Samsung on Falcon that Failed Finally after using another Box for the FRP Removal 1st I enabled Developer Mode and USB Debugging Go to Settings > About Device > and tap "Build Number" 7 times to enable "Developer Menu", then enable "USB Debugging" and "OEM unlock" in the Developer Menu. Connect USB and more drivers may install. 4.) Power off the phone completely, now hold Home and Volume-(down), keep them pressed and power the phone on. 5.) Press Volume+(up) when prompted to enter "Downloading Mode" 6.) Connect USB and wait for all drivers to finish installing on PC. I Did Sim Unlock using Falcon Box and said Successful but kept saying Sim Un recognized I believe Falcon doesn't support the newest PL6 6.01 or the newest Nougat update or theres a glitch in the 3.0 software I need install older version back 2.8 If It does work I do not understand what I did wrong Next I used adb enabler tool to create my own files using stock of PL6 Sprint rom G935PVPU4APL6 | Android 6.0.1 ? G935PVPU4APL6_G935PSPT4APL6_SPR.zip 2017-01-26 and flashed them in Odin in Download mode but none would work so I removed FRP with Octoplus but then it got stuck on Logo and kept saying custom after that I flashed The G935U Rom, I flashed it 3 times still said custom so I used a priv frp tool from gsm forums to get rid of the custom splash screen for SPR it was unlocked but some settings wouldn't work and the phone was crashing alot so I booted into recover and Del the Cache and did system Wipe / restore then flashed the stock sprint rom back using PL6 After that it Came up asking for Password for storage which was caused by bad cache left behind booted back into Recovery selected clear cache then booted into Download mode used Odin and flashed stock PL6 sprint rom after that I tried to use Octoplus to do a Sim Unlock but kept getting error ADB in use by other applications I rebooted my pc and still got the same error so I used my other box Falcon Box Clicked on Samsung then Selected Unlock and unlocked it or at least said it did it kept saying sim un recognized So I went back in download mode ran falcon 3.0 then selected Sprint Unlock still got the same error with the Sim, I went back in tried use Kingoroot to root the phone that failed the newest security was installed so I tried to use falcon 3.0 Said rooted but as you can see it wasn't Since I don't know what the difference is from Qcom and the Sprint Unlock I did them booth to be safe Finally after that client had enough and took his phone to another Unlocker What was causing the ADB in use error no idea seemed to be caused after the frp unlock by Octoplus which is great software and hardware was only tool could bypass the pl6 software my falcon box failed miserably and 5 other programs my only gripe is I don't like the custom with lock splash screen on startup after using the Octoplus frp ee removal neither did my client I just lost a client had to refund Money because I couldn't get the data or signal to work on a Fresh U Rom for the G935U so I flashed back to stock and tried to unlock But it wouldn't unlock the new PL6 and LTE didn't work either I wish I would of known about this Link and Info http://forum.gsmhosting.com/vbb/f684...-here-2126469/ If You have no LTE then reset Network 6 for LTE data enter settings>Activate this device>press 2 times Vol(+), 3 times Vol(-) . >will appear HiddenMenu>LTE settings> Global Mode. 100% unlocked and 3G/LTE data enabled tested with Bolivia's Tigo and Entel SIM Cards. https://idoneapps.com/forum/index.php?topic=616.15 About Sprint yes, once unlocked the phone will work with any carrier of both CDMA and GSM networks, so Sprint included, just make sure to use the right network settings in: Settings > Mobile Networks > Network Mode changing it to: 1. "GSM/UMTS" or "GSM/WCDMA auto" in order to use a GSM SIM (e.g. like AT&T or T-Mobile). 2. "LTE/CDMA" in order to use a CDMA SIM (e.g. like Verizon or Sprint) I wish I had these steps Before maybe I could of kept my $30 Had I left it on the U rom not tried any unlocks with Falcon Box and actually gotten the data to work |
05-03-2017, 13:25 | #74 (permalink) |
Junior Member Join Date: Apr 2016
Member: 2566420 Status: Offline Thanks Meter: 10 | Team falcon you guys are taking too long to update the modules please try an make the updates more frequent. Look at htc module last update was in November an we are now in may that's 6 months no update. The Samsung section is really outdated as well because there are a lot of new models an falcon doesn't have those. So please team need more updates. |
The Following User Says Thank You to akeemjunior For This Useful Post: |
