12-26-2016, 07:13 | #18 (permalink) | |
No Life Poster Join Date: Aug 2009
Member: 1092799 Status: Offline Sonork: 100.1603347 Thanks Meter: 111 | Quote:
virus infected file.... when i m clinking on url | |
12-26-2016, 11:18 | #21 (permalink) |
Freak Poster Join Date: Jan 2013 Location: INDIA ANDHRAPRADESH Age: 32
Member: 1873923 Status: Offline Thanks Meter: 41 | falcon flashing lenova a6000 or vibe k5 after 50% falcon closed falcon flashing lenova a6000 or vibe k5 after 50% falcon closed ,edl mode and fastboot mode same problem |
12-26-2016, 18:53 | #24 (permalink) |
No Life Poster Join Date: Nov 2009 Location: huanuco-peru
Member: 1168673 Status: Offline Sonork: 100.1638333 Thanks Meter: 235 | Repair imie zte a310 fail Starting. Asking Server for Access.. Checking User Details.. ok Checking User Login.. ok Opening Port.. COM115 : ZTE Handset Diagnostic Interface(DFU) (COM115) Compile : Sep 27 2016 15:42:07 Release : Aug 31 2016 03:00:00 Hw Ver : 8909.gen Esn : 00000000 Build : PE_MOV_B28OF_P809A50V1.0.0B08 Bt : N/A wifi : N/A code : 0000 imei : 861174030768767 imei 2 : 000000000000000 Imei 1 Read-only Failed to Write... Imei 1 Write Successfull... Imei Repair ok .. Rebooting Phone.. Process Done... |
12-26-2016, 18:58 | #25 (permalink) |
12-26-2016, 19:05 | #26 (permalink) |
12-26-2016, 21:36 | #27 (permalink) | |
No Life Poster Join Date: Jan 2016 Location: Somewhere
Member: 2517876 Status: Offline Sonork: 100.1675877 Thanks Meter: 3,909 | Quote:
did u use method 3 and phone in ftm mode ? if yes try erase imei using xiaomi method then repair or contact me by pm will check | |
The Following User Says Thank You to Winter Soldier For This Useful Post: |
12-27-2016, 13:22 | #30 (permalink) |
Major Poster Join Date: Sep 2011 Location: Western Sahara
Member: 1657159 Status: Offline Thanks Meter: 4 | wiko rainbow lite 4g imei null after unlock Opening Port.. COM149 : Qualcomm HS-USB Diagnostics 9091 (COM149) Compile : Nov 19 2015 11:36:30 Release : Jun 11 2015 06:00:00 Hw Ver : 8909.gen Esn : 00000000 Build : N/A Bt : N/A wifi : N/A code : 0000 imei : 351597077171452 imei 2 : 351597077321958 Imei 1 Write Successfull... Imei 2 Write Successfull... Imei Repair ok .. Rebooting Phone.. Process Done... You all attempts and still imei null |
