06-27-2018, 14:18 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Emmc & Ufs Chips Age: 42
Member: 145494 Status: Offline Sonork: 100.111656 Thanks Meter: 18,407 | Falcon Box HTC ANDROID TOOL V2.0 World's First Features [27/06/2018] Falcon Box Next Generation Mobile Tool iNNOVATED BY MIRACLE TEAM Version 2.0 (27TH JUNE 2018) Thanks for Using Miracle Team Product “Falcon Box & Falcon Miracle Key Edition” To make the Better Mobile Repair Solution for you, We bring to the Updates regularly. Every Update of our software include improvements for new functions and better service and reliability. Falcon Box HTC ANDROID TOOL V2.0 Highlights [+] Can Available on Miracle key Activation Added [+] Auto Authorization No need Login [+] HTC Mtk Frp Removal in Flash Mode - Remove Frp In Flash Mode [+] Enable Usb Debug for Frp Removal - Enable Adb For Frp Removal [+] Remove Frp In Adb Mode - Remove Frp In Adb Mode [+] Ruu Analyse, Encrypt/Decrypt - Analyse, Encrypt/Decrypt Ruu Files [+] Partition Dump for Mtk HTC Devices Dump Any Single Partition in Flash Mode or Adb Mode Possible to get all software and hardware information like: # OTA # Factory Build # CPU Specification # Default # Nand IC # Original Equipment Manufacturer # Kernel # System # Can show similar devices and hard reset guides # Can Detect Model automatically [+] S-OFF Section Ability to Disable Hboot Security(S-OFF) for this models: (only in normal mode)(radio lock not change) And Super CID for: HTC One s(s4 series) [+] Root Tool Temporarily and perm root by 6 different method in normal mode. [+] GoldCard Section # Ability to create goldcard (new and old phone) and write it and store it on computer # (stand alone – so you can flash any device without need s-off) –> (World’s First) # Ability Direct Gold-card writing on SDcard for PC [+] Easy Update & Recovery Section # Downgrade and upgrade original ROM available by one click # (no need to select files for supported models) (for who users installed Full Setup) –> (World’s First) # Custom recovery installation with one click (no need to select the files under supported models) (for who users installed Full Setup) –> (World’s First) # Custom ROM installation with support for all languages with one click # (no need to select the files under supported models) (for who users installed Full Setup) –> (World’s First) # Custom Kernel installation with one click # (no need to select the files under supported models) (for who users installed Full Setup) –> (World’s First) [+] Generic Read Codes / Direct Unlock for HTC Mtk Devices # Read Simlock Status # All HTC SPRINT/Virgin Unlock (With or without Root) # All HTC SPRINT/Virgin Read Msl/Spc (With or without Root) # All HTC Android Enable All Languages without Flash (Need Root) # HTC Mtk Cid Changer # 111 Different Themes [+] Manual Flash & Dump,Erase # Manual Flash, files can be Boot – Recovery – System – Userdata – Hboot. # Manual Flash in normal mode, files can be Misc – Recovery –> (World’s First) # Dump possible from the system partition and display the operating system map –> (World’s First) # Auto Flash ZIP/OTA Package in Recovery mode –> (World’s First) # Partition dumping for All partitions and All Android devices in Normal&Recovery mode(HTC,Samsung,LG,Motorola,ZTE…) [+] Advance Function Section # Change CID – MID – Serial (in-state S-OFF) # Possible to boot the phone with the desired file Erase all the possible partitions –> (World’s First) # Change main versions with manual method just one click (for downgrade – no need S-OFF) –> (World’s First) # Change main versions with auto method just one click (for downgrade – no need S-OFF) –> (World’s First) Ability to fix USB Brick –> (World’s First) [+] Application Section # Ability to install APK software (mass installation) and display file info with ability to the install on external memory # Uninstall application(apk) on the operating system [+] Misc section # Google Account Bypassing just with one click(Normal and Custom Recovery) –> (World’s First) # Ability to change phone mode automatically (HBoot – Recovery – Fastboot – Ruu mode) # Possible activation App2SD WITHOUT ROOT (for installing software on the External Storage – version 2.1 and up) –> (World’s First) # Wipe off the System – Cache – UserData # Possibility of temporarily and permanently activate the USB Debug (for HTC mobile phones ) –> (World’s First) # Ability to remove Password – Pin – Pattern without losing user data(all brands) –> (World’s First) # The ability to Easy and Fast unlock the boot loader for HTC # The ability to Easy and Fast unlock the boot loader for Motorola # The ability to Easy and Fast unlock the boot loader for Google # The ability to Easy and Fast unlock the boot loader for Sony # The ability to Easy and Fast unlock the boot loader for SonyEricisson [+] MTK HTC Devices # MT6572 # MT6573 # MT6577 # MT6582 # MT6589 # MT6592 # MT6595 # MT6732 # MT6735 # MT6752 # MT6753 # MT6795 [+] Added Write Scatter # Added Factory flash support for old scatters type # Added Partition Dumping for Following MTK Chipsets # Added Format and Erase for MTK devices # Added Scatter(old and new type) creator on DA Mode(boot mode) for MTK devices # Added CPU auto detection for MTK devices BR [SV]'S MIRACLE TEAM Last edited by [SV]; 06-28-2018 at 04:10. |
The Following 17 Users Say Thank You to chinchik For This Useful Post: |
06-27-2018, 14:19 | #2 (permalink) |
Member: 145494 Status: Offline Sonork: 100.111656 Thanks Meter: 18,407 | Miracle Falcon Activation Available for Miracle Key # No Need Login Auto Login # All Free Packs Available # No Need buy Other Dongle or Card This is Summer Offer any time will Stop. |
The Following 5 Users Say Thank You to chinchik For This Useful Post: |
07-01-2018, 20:58 | #10 (permalink) |
Insane Poster Join Date: Dec 2002
Member: 19271 Status: Offline Thanks Meter: 17 | Any chance to add support HTC M9e (MTK MT6795T)? Of course I run FHM as Administrator I try dump partition and now looks like this: Establishing secured session... Session Established.. Loading Scatter File... Elapsed: 0 seconds Dump configuration failed,run as administrator or try again Elapsed: 0 seconds Creating MTK scatter file... Getting Device partition map... Power off device then connect to usb cable or reboot device Scanning USB port... Searching for USB device... USB port is obtained. path name(\\?\usb#vid_0e8d&pid_2000#5&17864ebc&0&3#{a5d cbf10-6530-11d2-901f-00c04fb951ed}), port name(MediaTek PreLoader USB VCOM (Android) (COM29)) USB port detected: \\?\usb#vid_0e8d&pid_2000#5&17864ebc&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Detecting Device chipset... Power off device then connect to usb cable or reboot device Scanning USB port... Searching for USB device... USB port is obtained. path name(\\?\usb#vid_0e8d&pid_2000#5&17864ebc&0&3#{a5d cbf10-6530-11d2-901f-00c04fb951ed}), port name(MediaTek PreLoader USB VCOM (Android) (COM29)) USB port detected: \\?\usb#vid_0e8d&pid_2000#5&17864ebc&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Target cpu type is MT6795 HOLD POWER BUTTON ON DEVICE FOR "10 SECOND" TO RESTART BOOTLOADER Elapsed: 14 seconds Dump configuration failed,run as administrator or try again Elapsed: 0 seconds Dump configuration failed,run as administrator or try again Elapsed: 0 seconds Dump configuration failed,run as administrator or try again Elapsed: 0 seconds Creating MTK scatter file... Getting Device partition map... Power off device then connect to usb cable or reboot device Scanning USB port... Searching for USB device... USB port is obtained. path name(\\?\usb#vid_0e8d&pid_2000#5&17864ebc&0&3#{a5d cbf10-6530-11d2-901f-00c04fb951ed}), port name(MediaTek PreLoader USB VCOM (Android) (COM29)) USB port detected: \\?\usb#vid_0e8d&pid_2000#5&17864ebc&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Failed to Connect DA: S_BROM_DOWNLOAD_DA_FAIL Uncaught BaseException in main(): BROM ERROR : S_BROM_DOWNLOAD_DA_FAIL (2004) Target cpu type is MT6795 hw_ver(0xCA00), sw_ver(0x0000), hw_code(0x6795), hw_subcode(0x8A00) Failed to get partition map Failed to get Scatter File Scatter file looks good, extracted from ROM by ruu_decrypt_tool. Anyway I try to dump scatter from phone, without success. |
07-02-2018, 12:34 | #11 (permalink) |
Junior Member Join Date: Feb 2014 Location: Bolivia
Member: 2137463 Status: Offline Sonork: [email protected] Thanks Meter: 0 | Good wishes team Falcon. A query I bought a dongle, but I could not use the smart card in any way or activate it, I tried everything and nothing, have another and if it works very well, but it is last it came to yes me defective. Any solution this time? |
