Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > Miracle Team > Falcon Box by Miracle Team
Old 05-26-2017, 07:57   #1 (permalink)
Winter Soldier's Avatar
Member: 2517876
Sonork: 100.1675877
Thanks Meter: 3,896
Arrow Falcon Box Htc v1.4 - Frp, Sprint, Mtk [26/05/2017]
News
Falcon Box
Next Generation Mobile Tool
iNNOVATED BY MIRACLE TEAM
Htc V1.4 (26th May 2017)
Thanks for Using Miracle Team Product “Falcon Box & Falcon Miracle Key Edition
To make the Better Mobile Repair Solution for you, We bring to the Updates regularly.
Every Update of our software include improvements for new functions and better service
and reliability.
Miracle Falcon Htc Module V1.4 Highlights
Added Htc Sprint Read Msl/Spc Over Adb - Enable Usb Debug, Goto Basic Tab Htc Enable Dm Port - Enable Usb Debug, Goto Basic Tab Htc Frp Remover Universal Method - Enable Usb Debug, Goto Userlock Tool Updated Htc Mtk Flasher - Added Manual Da Selection Improved Htc Sprint Unlock - Fixed Port Detection Improved Htc Qualcomm zip Flasher - Fixed Memory Usage Option --------------------------------------------------------------- Htc Pack Features # All HTC SPRINT/Virgin Unlock (With or without Root) # All HTC SPRINT/Virgin Read MSL/SPC (With or without Root) # All HTC Android Enable All Languages without Flash (Need Root) # HTC M9 # HTC M8 # HTC M7 # ONE A9 # HTC 10 # ONE M9 # HTC A9 # And Most Others HTC FIRE PACK Other Details # Generic Read Codes / Direct Unlock for HTC MTK Devices. # Read Simlock Status. # HTC MTK CID Changer. # HTC FRP Unlock* Beta. # Added 111 Different Themes (Right Click on top to change). # HTC DESIRE 210 # HTC DESIRE 310 # HTC DESIRE 320 # HTC DESIRE 516T # HTC DESIRE 526G+ # HTC DESIRE 616W # HTC DESIRE 620G+ # HTC DESIRE 820S # HTC DESIRE 816G # HTC DESIRE 826 [The Information Section] (Possible to get all software and hardware information like) # OTA. # Factory Build. # CPU Specification. # Default. # Nand IC. # Original Equipment Manufacturer. # Kernel. # System. # Can show similar devices and hard reset guides. # Can Detect Model automatically. [S-OFF Section] # Ability to Disable H-boot Security (S-OFF) for this models: (only in normal mode) (Radio lock not change). [And Super CID for] # HTC One s (S4 series). [Root Tool] # Temporarily and Permanent Root by 6 Different Method in Normal Mode. [GoldCard Section] # Ability to create Goldcard (New and Old HTC Phone) and write it and store it on computer (stand alone – so you can flash any device without need s-off) (World’s First). # Ability Direct Gold-card writing on SD Card for PC. [Easy Update & Recovery Section] # Downgrade and Upgrade Original ROM available by one click (no need to select files for supported models) (for who users installed Full Setup) (World’s First). # Custom Recovery Installation with one click (no need to select the files under supported models) (for who users installed Full Setup) (World’s First). # Custom ROM Installation with support for all languages with one click (no need to select the files under supported models)(for who users installed Full Setup) (World’s First). # Custom Kernel Installation with one click (no need to select the files under supported models)(for who users installed Full Setup) (World’s First). [Manual Flash & Dump,Erase] # Manual Flash, files can be Boot – Recovery – System – Userdata – H-boot. # Manual Flash in normal mode, files can be Misc – Recovery (World’s First). # Dump possible from the system partition and display the operating system map (World’s First). # Auto Flash ZIP/OTA Package in Recovery mode (World’s First). # Partition dumping for All partitions and All Android devices in Normal&Recovery mode (HTC,Samsung,LG,Motorola,ZTE). [Advance Function Section] # Change CID – MID – Serial (in-state S-OFF). # Possible to boot the phone with the desired file. # Erase all the possible partitions (World’s First). # Change main versions with manual method just one click (for downgrade – no need S-OFF) (World’s First) # Change main versions with auto method just one click (for downgrade – no need S-OFF) (World’s First). # Ability to fix USB Brick (World’s First). [Application Section] # Ability to install APK software (Mass Installation) and display file info with ability to the install on external memory. # Uninstall application (apk) on the operating system. [Misc Section] # Google Account Bypassing just with one click (Normal and Custom Recovery) (World’s First). # Ability to change phone mode automatically (HBoot – Recovery – Fastboot – Ruu mode). # Possible activation App2SD WITHOUT ROOT (for installing software on the External Storage – version 2.1 and up) (World’s First). # Wipe off the System – Cache – UserData. # Possibility of temporarily and permanently activate the USB Debug (for HTC mobile phones ) (World’s First). # Ability to remove Password – Pin – Pattern without losing user data(all brands) (World’s First). # The ability to Easy and Fast unlock the boot loader for HTC. # The ability to Easy and Fast unlock the boot loader for Motorola. # The ability to Easy and Fast unlock the boot loader for Google. # The ability to Easy and Fast unlock the boot loader for Sony. # The ability to Easy and Fast unlock the boot loader for Sony Ericsson. [MTK HTC Devices Supported] # Added Write Scatter. # Added Factory Flash Support for old Scatters Type. # Added Partition Dumping for Following MTK Chip sets. # Added Format and Erase for MTK Devices. # Added Scatter (old and new type) creator on DA Mode (Boot Mode) for MTK Devices. # Added CPU Auto Detection for MTK devices. # MT6572 # MT6573 # MT6577 # MT6582 # MT6589 # MT6592 # MT6595 # MT6732 # MT6735 # MT6752 # MT6753 # MT6795
Note : Run App as Admin if you face any License Error
More To Come - Keep Watching
Get Now Yours From Nearest Distrubutor/Reseller Here
Like Us on Facebook
The Following 46 Users Say Thank You to Winter Soldier For This Useful Post:
Old 05-26-2017, 07:59   #2 (permalink)
Member: 2517876
Sonork: 100.1675877
Thanks Meter: 3,896
Arrow
Update Review :
http://www.youtube.com/watch?v=IFZpAJogkFI
The Following 20 Users Say Thank You to Winter Soldier For This Useful Post:
Old 05-26-2017, 10:32   #3 (permalink)
.::TEAM CCS::.'s Avatar
Member: 1766494
Sonork: 100.1649672
Thanks Meter: 283
Wow
Timely Update !
ITS TIME TO BUY FALCON BOX THEN .
The Following 4 Users Say Thank You to .::TEAM CCS::. For This Useful Post:
Old 05-26-2017, 10:44   #4 (permalink)
FALCON-BOX's Avatar
Member: 2525549
Thanks Meter: 147
Arrow
GREAT UPDATE FOR
The Following 4 Users Say Thank You to FALCON-BOX For This Useful Post:
Old 05-26-2017, 11:15   #5 (permalink)
Member: 2140067
need htc flash file
flash file for htc from falcon htc fire
The Following User Says Thank You to talktodanbest For This Useful Post:
Old 05-26-2017, 11:49   #6 (permalink)
Member: 2713606
Thanks Meter: 220
Great update,Good luck
The Following User Says Thank You to Hoshang_Gsm For This Useful Post:
Old 05-26-2017, 12:18   #7 (permalink)
lathik's Avatar
Member: 2199277
Sonork: 100.1678358
Thanks Meter: 167
wow nice awesome update team ,Thanq
The Following User Says Thank You to lathik For This Useful Post:
Old 05-26-2017, 13:11   #8 (permalink)
simcityreal's Avatar
Member: 955971
Sonork: 100.1638835
Thanks Meter: 108
No Need Thanks....,Only Need Good Support And Stable Service....
The Following 6 Users Say Thank You to simcityreal For This Useful Post:
Old 05-26-2017, 13:19   #9 (permalink)
Member: 257716
Sonork: 1650684
Thanks Meter: 52
i trust in falcon team great and boom update you kill all htc boxes
The Following 2 Users Say Thank You to harold6x For This Useful Post:
Old 05-26-2017, 13:22   #10 (permalink)
Member: 2169054
Thanks Meter: 53
wawww nice update......
The Following User Says Thank You to mantumobile17 For This Useful Post:
Old 05-26-2017, 13:44   #11 (permalink)
krishmobitech's Avatar
Member: 2569641
Sonork: WHATS APP & F.B
Thanks Meter: 589
wow ...superb update miracle team keep it up....
The Following User Says Thank You to krishmobitech For This Useful Post:
Old 05-26-2017, 14:49   #12 (permalink)
Member: 257716
Sonork: 1650684
Thanks Meter: 52
but what about problem
The Following User Says Thank You to harold6x For This Useful Post:
Old 05-26-2017, 16:13   #13 (permalink)
Member: 139936
Thanks Meter: 13
Falcon Team Current phone model, ZTE N9520, is no supported f
The Following User Says Thank You to mduncan For This Useful Post:
Old 05-26-2017, 16:18   #14 (permalink)
Member: 1361365
Sonork: 100.1670394
Thanks Meter: 14
what is this ???
Old 05-26-2017, 16:49   #15 (permalink)
Thanks Meter: 3,619
Originally Posted by waddaho View Post
what is this ???
disable antivirus and install
Page generated in 0.65914 seconds with 8 queries
