Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Falcon Box by Miracle Team
Old 02-05-2017, 15:34   #16 (permalink)
andreiza's Avatar
Member: 793212
Thanks Meter: 29
please solve this my problem
Old 02-05-2017, 15:40   #17 (permalink)
Member: 2517876
Sonork: 100.1675877
Thanks Meter: 3,909
hi
Disable your av or add folder to exception list
please uninstall / remove
install again
and run as admin
if problem remains contact any of supporter
br
Old 02-05-2017, 15:45   #18 (permalink)
Automatico's Avatar
Member: 2140790
Sonork: 100.1679059
Thanks Meter: 212
Originally Posted by Winter Soldier View Post
hi
install again
and run as admin
br
Falcon Module Work Ok (no anti virus)
Falcon MotoPack work ok too, but latest MTK module not work, protected by Enigma.- Re installing / add in path, not solve this issue.-
Check issue with SpFlash (auto closed app)
aUTo
The Following User Says Thank You to Automatico For This Useful Post:
Old 02-05-2017, 15:47   #19 (permalink)
Member: 2185549
Thanks Meter: 535
please team falcon you made boom qualcom mode but the mtk you forgot these few things that are major adb and metamode plus usb method to clean virus monkeytest and unfortunatey...... has stopped you have forgot read adb backup and forgot the new chipsete support
Old 02-05-2017, 15:50   #20 (permalink)
Member: 2185549
Thanks Meter: 535
dd u guys specify boot types for nand and emmc because most tools can do emmc perfectly now a think if you concentrate on nand chipsets that many tools brick maybe you can make more attraction please ensure nand is catered for iin the best way a mean read write and format firmware not forgeting antivirus
Old 02-05-2017, 16:03   #21 (permalink)
Member: 2506794
Sonork: 100.1675120
Thanks Meter: 118
Simple File Sharing and Storage.
please bug remove.
Old 02-05-2017, 16:04   #22 (permalink)
Member: 2506794
Sonork: 100.1675120
Thanks Meter: 118
please help...
Old 02-05-2017, 16:11   #23 (permalink)
Member: 2170171
Sonork: 100.1652359
Thanks Meter: 30
Need Help Windows 10 pro 32bit
Run as Admin With Xp Sp3 Compatibility Mode
check but not opning
Old 02-05-2017, 16:28   #24 (permalink)
sirnavid2010's Avatar
Member: 777729
Sonork: 100.1616470
Thanks Meter: 824
same pb please fix...........................
The Following User Says Thank You to sirnavid2010 For This Useful Post:
Old 02-05-2017, 16:32   #25 (permalink)
Crazy Poster
Member: 775376
Sonork: 6620
Thanks Meter: 4
same problem sir pl how to solved?
Old 02-05-2017, 16:32   #26 (permalink)
Member: 1968946
Thanks Meter: 99
same problem Windows7 32 bit.............slow very very slow!!!!!!!!!!!
Old 02-05-2017, 16:48   #27 (permalink)
riadularif's Avatar
Member: 2225969
Sonork: 100.1611549
Thanks Meter: 80
please give the solution
Old 02-05-2017, 16:48   #28 (permalink)
Member: 652992
Sonork: 100.1651242
Thanks Meter: 28
Any 1 facing any problem just change compatibility with xp sp3
The Following User Says Thank You to basharat7 For This Useful Post:
Old 02-05-2017, 16:49   #29 (permalink)
mobile care sha's Avatar
Member: 2562493
Sonork: mobile care
Thanks Meter: 355
same probem what is this
Old 02-05-2017, 16:49   #30 (permalink)
Member: 652992
Sonork: 100.1651242
Thanks Meter: 28
Try to turn off antivirus then check
Page generated in 0.23093 seconds with 10 queries
