Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > Miracle Team > Falcon Box by Miracle Team
Old 07-04-2017, 09:36   #1 (permalink)
Winter Soldier's Avatar
Member: 2517876
Sonork: 100.1675877
Thanks Meter: 3,894
Arrow Falcon Box Qualcomm Module V1.4 Released [04/07/2017]
News
Falcon Box
Next Generation Mobile Tool
iNNOVATED BY MIRACLE TEAM
Qualcomm Module V1.4 (04th July 2017)
Thanks for Using Miracle Team Product Falcon Box & Falcon Miracle Key Edition
To make the Better Mobile Repair Solution for you, We bring to the Updates regularly.
Every Update of our software include improvements for new functions and better service
and reliability.
Miracle Falcon Box Qualcomm V1.4 Ready
Miracle Falcon Qualcomm Module V1.4 Highlights
Added Read Pattern Lock For Qualcomm Devices - Supports Read Pattern in Edl Mode Direct Unlock (No Root Method) - New Method Network Unlock Without Root Access Auto Detection for Following Chips MSM8x10 MSM8x26 MSM8610 MSM8909 MSM8916 MSM8917 MSM8929 MSM8936 MSM8937 MSM8940 MSM8952 MSM8953 MSM8974 MSM8976 MSM8992 MSM8994 MSM8996 Reboot to Edl Mode - One Click Reboot From Normal mode to Edl Beta Imei Repair in Edl Mode - Supports Imei Repair in Edl Mode (Beta) Script Generation - Ability to Generate Flashing Script Other Improvements Qualcomm Module Features ------------------ Qualcomm Flashing Tool ------------------ Auto Detect Chipset Auto/Manual Select Loader Write RawFirmware - Edl Mode (2 Methods) - Fastboot Mode List Partitions Read Firmware Manually Dump Any Partition Manually Dump Full Firmware Auto Make Raw xml Format List / Wipe Any Single Partition Wipe Full Rom Manual Format Factory Reset Remove Account Lock - Universal Qualcomm Method - Xiaomi Method Custom Flasher - Flash Any Custom Image without Full Flash - Flash Any Partition without Full Flash ------------------ Read Information ------------------ - Normal Mode - Fastboot Mode - Diag Mode - Download/Edl Mode ------------------ Network Unlock ------------------ Read Codes Direct Unlock - Old Security Method - New Security Method - Support Most Models ------------------ Efs Tool ------------------ Read Efs Write Efs Reset Efs ------------------ Qcn Tool ------------------ Read Qcn Write Qcn ------------------ Misc ------------------ Enable Diag Remove Account Locks - Normal Mode - Fastboot Mode Factory Reset - Normal Mode - Fastboot Mode Bootloader Lock Bootloader Unlock ------------------ Repair ------------------ Write Imei 1 (Most Qualcomm Models Supported) Write Imei 2 (Most Qualcomm Models Supported) Write Meid (Most Qualcomm Models Supported) Write Esn (Most Qualcomm Models Supported) Write Spc (Most Qualcomm Models Supported) - 6 Different Methods More Features will be added in comming versions
Note : Run App as Admin if you face any License Error
More To Come - Keep Watching
Get Now Yours From Nearest Distrubutor/Reseller Here
Like Us on Facebook
The Following 35 Users Say Thank You to Winter Soldier For This Useful Post:
Old 07-04-2017, 10:38   #2 (permalink)
Thanks Meter: 3,547
Lenovo A6020a40 Pattern Lock Read Done By Falcon Box Qualcomm Module
The Following 6 Users Say Thank You to king.of.gsm For This Useful Post:
Old 07-04-2017, 10:41   #3 (permalink)
omairlee01's Avatar
Member: 2068959
Thanks Meter: 220
Wow This is it.... please improve spd factory reset
The Following User Says Thank You to omairlee01 For This Useful Post:
Old 07-04-2017, 10:50   #4 (permalink)
yudi_ar's Avatar
Member: 2155369
Thanks Meter: 619
Amazing team and great tools
Thank you
Old 07-04-2017, 10:52   #5 (permalink)
omairlee01's Avatar
Member: 2068959
Thanks Meter: 220
Tanks Falcon Box Qualcomm v1.4 is Working
Old 07-04-2017, 10:54   #6 (permalink)
rafi_5217705's Avatar
Member: 627475
Sonork: 100.1594828
Thanks Meter: 1,067
Super Update Bro i think Some More on the Way ?
The Following User Says Thank You to rafi_5217705 For This Useful Post:
Old 07-04-2017, 11:13   #7 (permalink)
lathik's Avatar
Member: 2199277
Sonork: 100.1678358
Thanks Meter: 167
wow nice update....falcon is always rocking
improve iphone network unlock & icloud read
Old 07-04-2017, 11:21   #8 (permalink)
Member: 2138272
Sonork: 100.1650629
Thanks Meter: 32
can i activate falcon box in other tool tnks .
Old 07-04-2017, 11:21   #9 (permalink)
krishmobitech's Avatar
Member: 2569641
Sonork: WHATS APP & F.B
Thanks Meter: 581
good update team... but too late update..come on miracle team .... give me upcoming updates fast...
Old 07-04-2017, 11:24   #10 (permalink)
Member: 1815849
Thanks Meter: 9
addb.exe closed?
used for edl repair imei
Old 07-04-2017, 11:38   #11 (permalink)
Thanks Meter: 3,547
no not other tool.
you can get falcon box activation on Miracle key Only.
The Following User Says Thank You to king.of.gsm For This Useful Post:
Old 07-04-2017, 11:40   #12 (permalink)
Member: 1815849
Thanks Meter: 9
Starting..
Asking Server for Access..
Checking User Details.. ok
Checking User Login.. ok
Reading Info..
Auto Detection Enabled..
Found : MSM8937
SerialNumber: 0x9f5c9ebe
MSM_HW_ID: 0x0004f0e1
OEM_PK_HASH: 0xcc3153a80293939b90d02d3bf8b23e0292e452fef662c749 98421adad42a380f
SBL SW Version: 0x00000000
Starting Imei Repair Task..
Memory type : Emmc
Flashing Programmer : prog_emmc_firehose_8937_ddr.mbn
Writing Data : Please Wait
Writing Imei : Please Wait
Rebooting Device..
Wrong Port Selected [0x2]..
Hint : Disconnect Phone - Remove/Install Battery if needed
Process Done...
adbb.exe cloesd
Old 07-04-2017, 11:51   #13 (permalink)
Member: 421947
Sonork: 100:1658491
Thanks Meter: 176
Hello good update but solve this pb soon
Starting..
Wrong Username or Password Please Check !!!
Old 07-04-2017, 15:11   #14 (permalink)
UBunlock's Avatar
Member: 1522403
Thanks Meter: 37
What happened to the Qualcomm MSM 8952 ??
In the post says this processor Qualcomm MSM 8952
I can not find it in the program
The Following User Says Thank You to UBunlock For This Useful Post:
Old 07-05-2017, 03:14   #15 (permalink)
Member: 1993526
Sonork: 100.1608505
Thanks Meter: 20
Why i can't find or see the link? pls. reupload the installer so we try the latest updates of falcon qualcomm
Page generated in 0.45158 seconds with 8 queries
