11-14-2017, 12:26 | #1 (permalink) |
No Life Poster Join Date: Nov 2011 Location: MIRACLE TEAM
Member: 1690589 Status: Offline Sonork: 100.1609373 Thanks Meter: 39,695 | Miracle Falcon Moto Pack 1.7 more then Advanced (14th Nov 2017) Miracle Falcon Box Next Generation Repair Tool iNNOVATED BY MIRACLE TEAM Miracle Falcon Moto Pack 1.7 Free : What News Inside : Motorola Service Pack V1.7 Released About Motorola Pack Direct Frp Reset Most Motorola Models (Select New Security in Userlocks Tab) # Without Manually Putting Factory Mode # 4 Different Methods Supported Now # New/old Security Devices Supported # Support for Nexus 6 and Similar Enable ADB # 2 Different Methods # New/old Security Devices Fix Devices Stuck in Fastboot/Factory Mode Loop # Reset Screen Locks for Motorola Devices (Beta) # Fixed Motorola Mtk Frp Reset in Flash Mode Motorola Qualcomm Devices # Read Device Info # Normal Mode # Ap Fastboot Mode # Diag Mode Simlocks # Direct Unlock Most Moto Qcom Devices # Direct Unlock Most Moto Sprint Devices without root # Reset Security IMEI Repair 2 Methods # Moto Method # Generic Qcom Method # Write Meid (Moto Method or Qcom Method) # Write Esn (Moto Method or Qcom Method) # Write Spc (Moto Method or Qcom Method) # Reset Spc (Moto Method or Qcom Method) # Meid to Esn Converter QCN/ EFS GENERIC # Read Qcn # Write Qcn # Read Efs # Restore Efs # Reset Efs Moto Mtk Android Devices # IMEI Repair # Direct Unlock Misc Tab # Enable ADB # 2 Different Methods # Factory Mode or Fastboot Mode # 2017 Latest Patch Motorola Enable Adb Frp Reset # 3 Different Methods (Old Security/New Security/Fastboot Method) Enable Diag (Need Root) Factory Reset # Normal Mode # Fastmode Mode Reset Screen locks # Normal Mode / Custom Recovery Mode One Click Reboot tool # Reboot to Factory Mode from Fastboot Mode # Fix Factory Mode Bootloader Tool Get Unlock Data # Relock # Unlock Factory Flasher # Ability to Direct Flash Factory Firmwares # Zip or Firmware xml Files # Ability to Select Partitions # Md5 Checksum # Check and Compare Directly All Files in Flash Package # Ability to Generate Flashing Script* Worlds first # Firmware zip or xml to bat # Manual Flasher with Erase and boot options # Sideload and Recovery mode flasher Added Motorola Mtk Flashing # Direct Flash Scatter File # Format/Upgrade Motorola Mtk One Click Frp Remove # No Need Root # No Need Enable Adb Fallow us on Facebook F/miracleteam Br [SV] Miracle Team Last edited by [SV]; 01-27-2018 at 16:13. |
The Following 35 Users Say Thank You to [SV] For This Useful Post: |
11-14-2017, 12:28 | #2 (permalink) |
Member: 1690589 Status: Offline Sonork: 100.1609373 Thanks Meter: 39,695 | Post Reserved for Team News
DOWNLOAD MIRACLE FALCON ALL IN ONE LAUNCHER Last edited by [SV]; 04-25-2018 at 15:18. |
The Following 6 Users Say Thank You to [SV] For This Useful Post: |
11-14-2017, 14:10 | #4 (permalink) |
Freak Poster Join Date: Feb 2016 Location: karnataka, mysore
Member: 2528503 Status: Offline Sonork: 1670792 Thanks Meter: 70 | SOFTWARE SAYS UNLOCK DONE - BUT STILL INVALID SIM CARD please help tarting.. Asking Server for Access.. Checking User Details.. ok Checking User Activations.. ok Checking User Login.. ok Starting Adb Server.. Waiting for Phone... Phone Found.. Manufacturer : motorola Model : Moto E (4) Plus Android Version : 7.1.1 Platform : msm8937 Release Tags : release-keys Network Type : Unknown Ril-Imp : Qualcomm RIL 1.0 Hardware : qcom Baseband : M8920_02.02.06.71R OWENS_NA_CUST Root Status : Not Rooted !!! Reading Sys Config.. Reading Data.. (Please Wait) Calculating Data.. Msl/Spc : N/A Unlocking ok.. Rebooting.. Process Done... |
The Following User Says Thank You to masimobilecare For This Useful Post: |
11-14-2017, 18:37 | #5 (permalink) |
Junior Member Join Date: Jul 2017 Age: 37
Member: 2742347 Status: Offline Thanks Meter: 1 | please help me with this mistake Starting... Checking User Login.. ok Checking User Activations.. ok Unpacking Files... Loading Files... Da File : C:\Falcon Box\FMOTO\bin\MTK_AllOne_DA.bin Chip : MT6737M Storage : EMMC Format Before Flash is Disabled... Using High-Speed Port... No-Battery Flashing is Disabled... Starting Motorola Frp Remove Task... 1 - Power off Phone.. 2 - Remove Install Battery.. 3 - Connect Usb Cable to Powered off Phone.. Waiting For Phone - [Brom Mode]... Phone Found on : MediaTek PreLoader USB VCOM (Android) (COM4) Connected to Device [Brom-Mode].. Writing Da File.. connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Device [Da-Mode].. Disconnect Phone - And Power on Manually.. Error - PMT changed for the ROM; it must be downloaded.. |
11-14-2017, 18:48 | #6 (permalink) | |
Junior Member Join Date: Jul 2016
Member: 2593143 Status: Offline Thanks Meter: 3 | Quote:
The Following User Says Thank You to Pausides For This Useful Post: |
11-15-2017, 10:12 | #7 (permalink) | |
Member: 2528503 Status: Offline Sonork: 1670792 Thanks Meter: 70 | whats wrong with team no reply on my post whats wrong with team no reply on my post Quote:
11-15-2017, 11:07 | #8 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | Starting.. Asking Server for Access.. Checking User Details.. ok Checking User Activations.. ok Checking User Login.. ok Opening Port.. COM121 : Qualcomm HS-USB Diagnostics 9091 (COM121) Compile : Dec 15 2016 01:08:30 Release : Dec 06 2016 00:00:00 Hw Ver : 8952.gen Esn : 807D7765 Build : N/A Bt : N/A wifi : N/A code : 0000 imei : 354122070522070 imei 2 : 000000000000000 Starting Unlock Process.. Reading Data.. Unlock Success... Rebooting Phone.. Process Done... phone still lock |
11-15-2017, 11:26 | #9 (permalink) |
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | Starting.. Asking Server for Access.. Checking User Details.. ok Checking User Activations.. ok Checking User Login.. ok Waiting for Phone... Phone Found.. version: 0.5 version-bootloader: moto-msm8952-B1.03 product: athene_13mp board: athene_13mp secure: yes hwrev: P2A radio: 3 storage-type: emmc emmc: 16GB SAMSUNG QE13MB RV=08 PV=07 FV=0000000000000007 ram: 2GB SAMSUNG LP3 DIE=8Gb M5=01 M6=05 M7=00 M8=1F cpu: MSM8952 serialno: ZY223BM65F cid: 0x0032 channelid: 0x4e uid: 2ACEC30000000000000000000000 securestate: oem_locked iswarrantyvoid: no max-download-size: 536870912 reason: Volume down key pressed imei: 354122070522077 meid: date: 06-17-2016 sku: XT1622 battid: SNN5970A iccid: cust_md5: max-sparse-size: 268435456 current-time: "Thu Jul 7 20:18: 5 UTC 2016" ro.build.fingerprint[0]: motorola/athene/athene:7.0/NPJ25.9 ro.build.fingerprint[1]: 3-14/16:user/release-keys ro.build.version.full[0]: Blur_Version.25.11.16.athene.reta ro.build.version.full[1]: il.en.US ro.build.version.qcom: LA.BR.1.3.6-01710-8976.0 version-baseband: M8952_70030.25.03.62R ATHENE_EMEA_CUST kernel.version[0]: Linux version 3.10.84-g478d03a (hudsoncm kernel.version[1]: @ilclbld26) (gcc version 4.8 (GCC) ) #1 kernel.version[2]: SMP PREEMPT Fri Jan 6 05:12:56 CST 2017 sbl1.git: git=MBM-NG-VB1.03-0-ge433b40 rpm.git: git=a970ead tz.git: git=119e5b2-dirty hyp.git: git=119e5b2-dirty keymaster.git: git=119e5b2-dirty cmnlib.git: git=119e5b2-dirty aboot.git: git=MBM-NG-VB1.03-0-gb44c0ee qe: qe 0/0 frp-state: no protection (0) ro.carrier: tescogb Unlock Code : 3A45210207250277#5A59323233424D363546004D6F746F204 7200000#E41C0FBA41230B12253D088AA725E1F7C6F8D9DC#2 ACEC300000000000000000000000000 Unlocking Bootloader.. Debug: jd7ot+H8bruF5aWDYaU4uqk2x9P/uRCqk5ZGuzZAW3IN+ubOAgGzykFZBtZ9sz3saqt9b982vPOnvw UG4vrsaQ== Process Done... |
11-28-2017, 10:58 | #11 (permalink) |
Freak Poster Join Date: Nov 2015 Location: INDIA
Member: 2482400 Status: Offline Sonork: 100.1677259 Thanks Meter: 115 | moto sprint unlocked but still invalid sim Starting.. Asking Server for Access.. Checking User Details.. ok Checking User Activations.. ok Checking User Login.. ok Starting Adb Server.. Waiting for Phone... Phone Found.. Manufacturer : motorola Model : Moto E (4) Android Version : 7.1.1 Platform : msm8937 Release Tags : release-keys Network Type : Unknown Ril-Imp : Qualcomm RIL 1.0 Hardware : qcom Baseband : M8920_15000.280.06.58R PERRY_NA_CA_CUST Root Status : Not Rooted !!! Reading Sys Config.. Reading Data.. (Please Wait) Calculating Data.. Msl/Spc : N/A Unlocking ok.. Rebooting.. Process Done... |
12-06-2017, 11:32 | #14 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Abidjan,ivory coast
Member: 1272267 Status: Offline Sonork: 100.1667652 Thanks Meter: 407 | Starting.. Asking Server for Access.. Checking User Details.. ok Checking User Activations.. ok Checking User Login.. ok Starting Adb Server.. Waiting for Phone... Phone Found.. Manufacturer : motorola Model : XT1575 Android Version : 6.0 Platform : msm8992 Release Tags : release-keys Network Type : Unknown Ril-Imp : Qualcomm RIL 1.0 Hardware : qcom Baseband : M8992_1255331.29.01.88.02R SUPER_NA Reading Sys Config.. Setting New Configs.. Using Frp Reset Method 1.. Hint : Press any key to Return.. Frp Reset ok.. Process Done... |
