06-14-2017, 03:22 | #6 (permalink) |
Junior Member Join Date: May 2017
Member: 2722742 Status: Offline Thanks Meter: 20 | Download Oneplus 3 firmware from the official site. http: //downloads. oneplus. net (delete any spaces after the full stops in this guide as my post count won't allow me to add links) Then adb Sideload the firmware to your device using this guide: Step 1 - Download the firmware for the OnePlus 3 Step 2 - Place the Firmware in the Fastboot folder and rename it to 'update. zip'. Step 3 - Power Off your device and once powered off, hold the 'Power Button' + 'Volume Down' simultaneously till you enter the Stock Recovery. Choose 'English'. Step 4 - Next choose 'Install from ADB' > 'OK' and you will see a screen showing 'You are in sideload mode' Step 6 - Connect your device to PC via USB cable and open the Fastboot folder. Hold Shift Key and Right Click and Choose 'Open command window here'. Step 7 - Once the command window is opened, type in the command - adb sideload update. zip. For Mac users, it is - ./adb sideload update. zip Step 8 - The system will now flash the Firmware. Once done, choose Reboot. Hope this helps :-) |
06-21-2017, 20:46 | #7 (permalink) | |
Temporary banned !! Join Date: Jun 2014 Location: Tirumala,Tirupathi
Member: 2199277 Status: Offline Sonork: 100.1678358 Thanks Meter: 167 | Quote:
bro recovery mode is asking password | |
06-21-2017, 23:22 | #8 (permalink) |
Member: 2722742 Status: Offline Thanks Meter: 20 | Oneplus 3 Firmware Have you tried a Hard Reset to remove the pattern lock? Turn off the phone. Press and hold together Volume Down and Power button for a few seconds. Release held keys when you see the OnePlus icon Select your language. Select Wipe data and cache. Finally, select Wipe data to begin. |
06-22-2017, 07:39 | #9 (permalink) | |
08-02-2017, 09:12 | #10 (permalink) |
Freak Poster Join Date: May 2014 Location: MUMBAI INDIA
Member: 2194159 Status: Offline Thanks Meter: 88 | power off phone and press both volum button connect usb cable phone going to edl mode check device manager show 9008 port format with any professional tool |
