03-15-2017, 07:38 | #3 (permalink) |
No Life Poster Join Date: Mar 2016
Member: 2547620 Status: Offline Thanks Meter: 3,431 | I believe There is some connection issue , If you are trying with J100ML try to check your connections because this model is tested by us too . Second do not select files as you downloaded from support you best is extract them and use the bin or xml files inside Best regards F4T0N |
The Following User Says Thank You to FAT-ON For This Useful Post: |
03-19-2017, 17:55 | #5 (permalink) |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | AFTER_SUCCESSFULL_CONNECTION_SUCCESSFULL_RESULT is in ur service.. LG_H810 BE |
The Following 2 Users Say Thank You to mobile_hotman For This Useful Post: |
