Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GSMFABRICA Products
Old 01-17-2017, 09:18   #16 (permalink)
Member: 2547620
Thanks Meter: 3,431
Originally Posted by neo_49 View Post
Thanks for wonderful update , please need resume support for download .
Regards
I will let this information delivered .
We will have some support area progress these days , hope we can add this too .
Originally Posted by citra kalasan View Post
when EMMC pro support FFU/tespoint for hinyx and sandisk...?
is world be waiting for this
this will come in few updates , already some of you requested and we have it in the list .
Originally Posted by zacxrhay View Post
What About This ???
This looks like Write Failed , either write protected eMMC or dead one .
Can you check the log we have information such as Permanent Write , Temporary Write Block or smiliar.
Originally Posted by aliusmanbava View Post
my phone model 816w pinouts same check my words other box detect good but emmc pro not detect
816t and 816w dump same?????
I asked you because I have a "T" in the office and works fine for me .
I am not sure about T and W dump compatibility because i have not seend the W yet in my hand .
I can check for you if i can find this device.
Best Regards
F4T0N
The Following User Says Thank You to FAT-ON For This Useful Post:
Old 01-17-2017, 10:24   #17 (permalink)
Member: 844866
Thanks Meter: 22
err
Best Regards
F4T0N
The Device is Life with cannot wipe,actually this devices will come will previous state condition when i was wipe...i try write extcsd tool is writing,but now
.....Connect a Device and Click "Detect"
Detect eMMC failed(3)).
Old 01-17-2017, 11:08   #18 (permalink)
Member: 1886712
Thanks Meter: 53
you still not understand
my phone not detect emmc pro i try other box my phone detect fine its mean your pin outs fine but box detecting not good i try to check many phone but emmc pro show (error16) (error60) (cmd error) only 2 or 3 time phone detect fine but many time error if i check same pin outs same time other box phone detect good
Old 01-17-2017, 11:13   #19 (permalink)
Member: 2547620
Thanks Meter: 3,431
Maybe box have some problem ?
You can contact me private (PM) to check your problem in remotely .
Best Regards
F4T0N
Old 01-17-2017, 15:11   #20 (permalink)
alkim's Avatar
Member: 992568
Sonork: kulit
Thanks Meter: 231
do you support also mtk emmc chips
Old 01-17-2017, 18:53   #21 (permalink)
Member: 125037
Sonork: 100.1649338
Thanks Meter: 254
Originally Posted by Electroboys View Post
eMMC Pro 1.08 Release Notes
[16 JAN 2017]
We are trying to make more powerful eMMC software with every each update
There are alof of optimizations and progres based on customers requests and demands.
  1. # Detection Routines improved .
  2. # SW Default Set as "12 Mhz"
  3. # Format Functions added
  4. # Partitioning / GP Area Partitioning features added.
  5. # Config Features Added .
  6. # Soft Erase Function Added .
  7. # Deep Erase Function Added .
  8. # UI - Full Flash mode added .
  9. # UI - Partition mode added .
  10. # UI - Selection USER ( ROM1 ) .
  11. # UI - Selection BOOT1 ( ROM2 ) .
  12. # UI - Selection BOOT2 ( ROM3 ) .
  13. # UI - CID Parsing .
  14. # UI - CSD Parsing .
  15. # UI - Config Added .
  16. # UI - GP Area Partition Settings added .
  17. # New Firmware Released Version = 2016122615000000
When you first run eMMC Pro V1.08 sw will update your firmware .
With the new firmware we have implemented better detection and more features.
and makes it more stable and alot more powerful .
[Config Features Added]
We have added Format , Soft Erase , Deep Erase Function in the software
[Soft Erase]
Provides a host explicit erase function.
The erasable unit of the eMMC is the “Erase Group”;
Erase group is measured in write blocks which are the basic writable units of the Device.
Once the erase command completes successfully, the device address range that was erased shall behave-
as if it was overwritten with all ‘0’ or all ‘1’ depending on the different memory technology.
[Deep Erase]
In addition to the Soft Erase command there is also an optional Deep Erase command.
The Deep Erase command differs from the Soft Erase command in that it requires the device to -
execute the erase operation on the memory array when the command is issued and
requires the device and host to wait until the operation is complete.
This should be executed the Deep Erase command with caution to avoid unintentional data loss.
[Solution for :]
  1. # Wipe failed on MTK devices will be easily fixed with this option.
  2. # Corrupt Disk not functioning will be solved such as Disks
    "not write protected" but devices can not be written firmware.
[Partitioning :]
General Purpose Area Partition, RPMB Partitions can be configured
General Purpose Partitions can be programmed by the setting the corresponding-
values defined on eMMC Pro Software and written into the Extended CSD registers
only once in the device life-cycle.
[UI Improvements : ]
[Full Flash mode : ]
When the file is selected with Full Flash Mode .
You are able to write the complete file as one and whole !
[Partition mode : ]
Partitions of the Dump File Selected will be displayed on the eMMC Pro UI
By selecting each partition and selected partitions will be written into target device .
[Frequency Set : ]
12 Mhz as Default
[Area : ]
USER ( ROM1 )
BOOT1 ( ROM2 )
BOOT2 ( ROM3 )
In order to comply among the eMMC Boxes and for easy understanding for our users .
We have identified the on the software ROM1 , ROM2 and ROM3 for each Area
There is full access (R/W) and all the features are compatible with eMMC Pro.
[CID / CSD Parsing : ]
There is alot of information is provided with the CID and CSD Values
such as Manufacturer Details , Device Configuration , Write Protection ,
Serial Number , etc.. Complete device specifications of the eMMC
Complete identification of the eMMC will be displayed in eMMC Pro UI .
[eMMC Pro Support page : ]
We are sorry we had a down time during the new year season
but we recovered everything is perfect now .
Thanks for all the feedbacks.
Thank you for all eMMC Pro Customers to keep sending us requests and suggestions .
There is a lot more to come
Best Regards
eMMC Pro Team
Advanced eMMC Repair
eMMC PRo - Universal Device Programmer
It looks like my firmware is not automatically updated.. what to do?
eMMC PRO
eMMC Pro - eMMC Programmer Version V1.08
FIRMWARE(0x4D41494E) version:2014053015000001
SN:531F3B8D504EFB01
eMMC Pro is Ready ..
then the second time I run the program, the BOX is dead!!
eMMC PRO
and if I click on "Support Login' the browser opens asa shows "This serial number is expired"
Now, I disconnected the box and reconnected. Red led is blinking,
running the software shows:
www.emmc-pro.com
BOOTLOADER(0x424F4F54) version:2013101009310000
SN:531F3B8D504EFB01
an asks to update the firmware
firmware is upgraded.
is I close and start the rogram again back to
www.emmc-pro.com
and box DEAD
WHAT TO DO PLEASE?
UPDATED!!
had to restart the box few times and now:
www.emmc-pro.com
FIRMWARE(0x4D41494E) version:2016122615000000
SN:531F3B8D504EFB01
cheers
x4ce
Old 01-17-2017, 19:26   #22 (permalink)
vickyjadhav6161's Avatar
Member: 2386560
Sonork: NOW I DON'T USE IT
Thanks Meter: 561
sorry fat-on bro but i am not happy with your any update? i cant repair even 1 phone still now with emmc pro...every time emmc connect sucessfully but always failled to write repair files...i think you ppl uploading dump without testing it..
trust me, i am not writeing here any wrong about emmc pro...
The Following User Says Thank You to vickyjadhav6161 For This Useful Post:
Old 01-18-2017, 13:28   #23 (permalink)
Member: 2547620
Thanks Meter: 3,431
eMMC PRO
SN:531F3B8D504EFB01
eMMC PRO
eMMC PRO
SN:531F3B8D504EFB01
eMMC PRO
and box DEAD
WHAT TO DO PLEASE?
UPDATED!!
eMMC PRO
SN:531F3B8D504EFB01
cheers
x4ce
Seems like done .
Writing There is no problem unless there is a problem with the eMMC .
I will post some Videos with some models in office .
We can look into your phones and find out exactly problem.
PM me , what you have in your hand .
Best Regards
F4T0N
Old 01-19-2017, 11:14   #24 (permalink)
akhileshbaghel's Avatar
Member: 84807
Thanks Meter: 67
samsung p3100 emmc read properly but writing show error failed (13)
in smasung p3100 emmc protection ? if yes plz share process to remove protection & write file
here is log detail
CID:0x03C9BF52 0x4107D31C 0x41473247 0x1501004D
Manufacturer ID:0x15
Device/BGA:1 (removable:1 BGA:2 POP:3)
OEM/Application ID:0x00
Product name:0x4D4147324741 (MAG2GA)
Product revision:0x07
Product serial number:0xD31C03C9
Manufacturing date:0xBF
CRC7 checksum:0x52
CSD:0x8A406062 0xF6DBFFFF 0x0F5903FF 0xD0270132
CSD structure:0x3
System specification version:0x4
Data read access-time 1:0x27
Data read access-time 2:0x1
Max. bus clock frequency:0x32
Card command classes:0x0F5
Max. read data block length:0x9 (512)
Partial blocks for read allowed:0
Write block misalignment:0
Read block misalignment:0
DSR implemented:0
Device size:0xFFF
Min. read current @ VDD min:0x6
Max. read current @ VDD min:0x6
Min. write current @ VDD min:0x6
Max. write current @ VDD min:0x6
Device size multiplier:0x7
Erase group size:0x1F
Erase group size multiplier:0x1F
Write protect group size:0x1F
Write protect group enable:1
Manufacturer default ECC:0
Write speed factor:2
Max. write data block length:0x9
Partial blocks for write allowed:0
Content protection application:0
File format group(R/W):0
Copy flag (OTP)(R/W):1
Permanent write protection(R/W):1
Temporary write protection(R/W):0
File format(R/W):0
ECC code(R/W):0
CRC(R/W):0x31
Not used, always ’1’:0
RCA:0x00000000
EXT_CSD information parsing:
FFU features:0x00
BOOT_SIZE_MULTI[226]:0x10
HC_ERASE_GRP_SIZE[224]:0x01
ERASE_TIMEOUT_MULT[223]:0x01
SEC_COUNT(EXT_CSD[215:212]:0x01D5A000)
CARD_TYPE(EXT_CSD[196]):0x07
CSD_STRUCTURE(EXT_CSD[194]):0x02
EXT_CSD_REV(EXT_CSD[192]):0x05
PARTITION_CONFIG[179]:0x00
BOOT_CONFIG_PROT[178]:0x00
BOOT_BUS_CONDITIONS[177]:0x00
ERASE_GROUP_DEF[175]:0x00
BOOT_WP[173]:0x00
USER_WP[171]:0x00
FW_CONFIG[169]:0x00
RPMB_SIZE_MULT[168]:0x01
WR_REL_SET[167]:0x1F
WR_REL_PARAM[166]:0x05
SANITIZE_START[165]:0x00
BKOPS_START[164]:0x00
BKOPS_EN[163]:0x00
RST_n_FUNCTION[162]:0x00
HPI_MGMT[161]:0x00
PARTITIONING_SUPPORT[160]:0x03
MAX_ENH_SIZE_MULT[159:157]:0x0000BB
PARTITIONS_ATTRIBUTE[156]:0x00
PARTITION_SETTING_COMPLETED[155]:0x01
GP_SIZE_MULT[154:143]:0x000000000000000000000000
ENH_SIZE_MULT[142:140]:0x000000
ENH_START_ADDR[139:136]:0x00000000
SEC_BAD_BLK_MGMNT[134]:0x00
PRODUCTION_STATE_AWARENESS[133]:0x00
TCASE_SUPPORT[132]:0x00
PERIODIC_WAKEUP[131]:0x00
PROGRAM_CID_CSD_DDR_SUPPORT[130]:0x00
NATIVE_SECTOR_SIZE[63]:0x00
USE_NATIVE_SECTOR[62]:0x00
DATA_SECTOR_SIZE[61]:0x00
INI_TIMEOUT_EMU[60]:0x00
Class6_CTRL[59]:0x00
DYNCAP_NEEDED[58]:0x00
EXCEPTION_EVENTS_CTRL[57:56]:0x00
EXCEPTION_EVENTS_STATUS[55:54]:0x00
EXT_PARTITIONS_ATTRIBUTE[53:52]:0x00
CONTEXT_CONF[51:37]:0x000000000000000000000000000000
PACKED_COMMAND_STATUS[36]:0x00
PACKED_FAILURE_INDEX[35]:0x00
POWER_OFF_NOTIFICATION[34]:0x00
CACHE_CTRL[33]:0x00
FLUSH_CACHE[32]:0x00
MODE_CONFIG[30]:0x00
MODE_OPERATION_CODES[29]:0x00
FFU_STATUS[26]:0x00
PRE_LOADING_DATA_SIZE[25:22]:0x00000000
MAX_PRE_LOADING_DATA_SIZE[21:18]:0x00
PRODUCT_STATE_AWARENESS_ENABLEMENT[17]:0x00
SECURE_REMOVAL_TYPE[16]:0x00
Basic Information:
Extended CSD revision: Revision 1.5 (MMC v4.41)
User Data Area Size: 15028MB(0x3AB400000)
Boot Partition Size: 2048KB
RPMB Size: 128KB
General Purpose Partition 1 Size: 0KB
General Purpose Partition 2 Size: 0KB
General Purpose Partition 3 Size: 0KB
General Purpose Partition 4 Size: 0KB
Erase group size: 512KB
CRC7 checksum:0x52
CSD structure:0x3
DSR implemented:0
Device size:0xFFF
File format(R/W):0
ECC code(R/W):0
CRC(R/W):0x31
RCA:0x00000000
FFU features:0x00
BOOT_WP[173]:0x00
USER_WP[171]:0x00
FW_CONFIG[169]:0x00
BKOPS_EN[163]:0x00
HPI_MGMT[161]:0x00
CACHE_CTRL[33]:0x00
FFU_STATUS[26]:0x00
Basic Information:
RPMB Size: 128KB
Writing Started...
Write failed (13)
Writing Done !!
The Following User Says Thank You to akhileshbaghel For This Useful Post:
Old 01-21-2017, 09:49   #25 (permalink)
Member: 2547620
Thanks Meter: 3,431
hold this phone , we will have beta for this problem very soon .
Best regards
F4T0N
Old 02-17-2017, 18:14   #26 (permalink)
Member: 178450
Thanks Meter: 54
virus detected on latest sw 1.08
Old 02-18-2017, 12:32   #27 (permalink)
Member: 2547620
Thanks Meter: 3,431
Thats a compression method because virus programs cant unpack and claim as virus .
Best Regards
F4T0N
Page generated in 0.34784 seconds with 8 queries
