01-17-2017, 09:18 | #16 (permalink) | |||
No Life Poster Join Date: Mar 2016
Member: 2547620 Status: Offline Thanks Meter: 3,431 | Quote:
We will have some support area progress these days , hope we can add this too . Quote:
This looks like Write Failed , either write protected eMMC or dead one . Can you check the log we have information such as Permanent Write , Temporary Write Block or smiliar. Quote:
I am not sure about T and W dump compatibility because i have not seend the W yet in my hand . I can check for you if i can find this device. Best Regards F4T0N | |||
The Following User Says Thank You to FAT-ON For This Useful Post: |
01-17-2017, 10:24 | #17 (permalink) | |
Insane Poster Join Date: Aug 2008 Location: Indonesia Raya Age: 45
Member: 844866 Status: Offline Thanks Meter: 22 | err Quote:
.....Connect a Device and Click "Detect" Detect eMMC failed(3)). | |
01-17-2017, 11:08 | #18 (permalink) |
No Life Poster Join Date: Feb 2013
Member: 1886712 Status: Offline Thanks Meter: 53 | you still not understand my phone not detect emmc pro i try other box my phone detect fine its mean your pin outs fine but box detecting not good i try to check many phone but emmc pro show (error16) (error60) (cmd error) only 2 or 3 time phone detect fine but many time error if i check same pin outs same time other box phone detect good |
01-17-2017, 11:13 | #19 (permalink) | |
Maybe box have some problem ? You can contact me private (PM) to check your problem in remotely . Best Regards F4T0N | |
01-17-2017, 18:53 | #21 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: Italy, Bahrain, India Age: 53
Member: 125037 Status: Offline Sonork: 100.1649338 Thanks Meter: 254 | Quote:
eMMC PRO eMMC Pro - eMMC Programmer Version V1.08 FIRMWARE(0x4D41494E) version:2014053015000001 SN:531F3B8D504EFB01 eMMC Pro is Ready .. then the second time I run the program, the BOX is dead!! eMMC PRO eMMC Pro - eMMC Programmer Version V1.08 and if I click on "Support Login' the browser opens asa shows "This serial number is expired" Now, I disconnected the box and reconnected. Red led is blinking, running the software shows: www.emmc-pro.com eMMC Pro - eMMC Programmer Version V1.08 BOOTLOADER(0x424F4F54) version:2013101009310000 SN:531F3B8D504EFB01 an asks to update the firmware BOOTLOADER(0x424F4F54) version:2013101009310000 firmware is upgraded. is I close and start the rogram again back to www.emmc-pro.com eMMC Pro - eMMC Programmer Version V1.08 and box DEAD WHAT TO DO PLEASE? UPDATED!! had to restart the box few times and now: www.emmc-pro.com eMMC Pro - eMMC Programmer Version V1.08 FIRMWARE(0x4D41494E) version:2016122615000000 SN:531F3B8D504EFB01 eMMC Pro is Ready .. Connect a Device and Click "Detect" cheers x4ce Last edited by excessive; 01-17-2017 at 19:01. | |
01-17-2017, 19:26 | #22 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Left out from our gsm field Age: 29
Member: 2386560 Status: Offline Sonork: NOW I DON'T USE IT Thanks Meter: 561 | sorry fat-on bro but i am not happy with your any update? i cant repair even 1 phone still now with emmc pro...every time emmc connect sucessfully but always failled to write repair files...i think you ppl uploading dump without testing it.. trust me, i am not writeing here any wrong about emmc pro... |
The Following User Says Thank You to vickyjadhav6161 For This Useful Post: |
01-18-2017, 13:28 | #23 (permalink) | ||
I will post some Videos with some models in office . We can look into your phones and find out exactly problem. PM me , what you have in your hand . Best Regards F4T0N | ||
01-19-2017, 11:14 | #24 (permalink) |
No Life Poster Join Date: Oct 2004 Location: india
Member: 84807 Status: Offline Thanks Meter: 67 | samsung p3100 emmc read properly but writing show error failed (13) in smasung p3100 emmc protection ? if yes plz share process to remove protection & write file here is log detail eMMC Pro is Ready .. Connect a Device and Click "Detect" CID:0x03C9BF52 0x4107D31C 0x41473247 0x1501004D Manufacturer ID:0x15 Device/BGA:1 (removable:1 BGA:2 POP:3) OEM/Application ID:0x00 Product name:0x4D4147324741 (MAG2GA) Product revision:0x07 Product serial number:0xD31C03C9 Manufacturing date:0xBF CRC7 checksum:0x52 CSD:0x8A406062 0xF6DBFFFF 0x0F5903FF 0xD0270132 CSD structure:0x3 System specification version:0x4 Data read access-time 1:0x27 Data read access-time 2:0x1 Max. bus clock frequency:0x32 Card command classes:0x0F5 Max. read data block length:0x9 (512) Partial blocks for read allowed:0 Write block misalignment:0 Read block misalignment:0 DSR implemented:0 Device size:0xFFF Min. read current @ VDD min:0x6 Max. read current @ VDD min:0x6 Min. write current @ VDD min:0x6 Max. write current @ VDD min:0x6 Device size multiplier:0x7 Erase group size:0x1F Erase group size multiplier:0x1F Write protect group size:0x1F Write protect group enable:1 Manufacturer default ECC:0 Write speed factor:2 Max. write data block length:0x9 Partial blocks for write allowed:0 Content protection application:0 File format group(R/W):0 Copy flag (OTP)(R/W):1 Permanent write protection(R/W):1 Temporary write protection(R/W):0 File format(R/W):0 ECC code(R/W):0 CRC(R/W):0x31 Not used, always ’1’:0 RCA:0x00000000 EXT_CSD information parsing: FFU features:0x00 BOOT_SIZE_MULTI[226]:0x10 HC_ERASE_GRP_SIZE[224]:0x01 ERASE_TIMEOUT_MULT[223]:0x01 SEC_COUNT(EXT_CSD[215:212]:0x01D5A000) CARD_TYPE(EXT_CSD[196]):0x07 CSD_STRUCTURE(EXT_CSD[194]):0x02 EXT_CSD_REV(EXT_CSD[192]):0x05 PARTITION_CONFIG[179]:0x00 BOOT_CONFIG_PROT[178]:0x00 BOOT_BUS_CONDITIONS[177]:0x00 ERASE_GROUP_DEF[175]:0x00 BOOT_WP[173]:0x00 USER_WP[171]:0x00 FW_CONFIG[169]:0x00 RPMB_SIZE_MULT[168]:0x01 WR_REL_SET[167]:0x1F WR_REL_PARAM[166]:0x05 SANITIZE_START[165]:0x00 BKOPS_START[164]:0x00 BKOPS_EN[163]:0x00 RST_n_FUNCTION[162]:0x00 HPI_MGMT[161]:0x00 PARTITIONING_SUPPORT[160]:0x03 MAX_ENH_SIZE_MULT[159:157]:0x0000BB PARTITIONS_ATTRIBUTE[156]:0x00 PARTITION_SETTING_COMPLETED[155]:0x01 GP_SIZE_MULT[154:143]:0x000000000000000000000000 ENH_SIZE_MULT[142:140]:0x000000 ENH_START_ADDR[139:136]:0x00000000 SEC_BAD_BLK_MGMNT[134]:0x00 PRODUCTION_STATE_AWARENESS[133]:0x00 TCASE_SUPPORT[132]:0x00 PERIODIC_WAKEUP[131]:0x00 PROGRAM_CID_CSD_DDR_SUPPORT[130]:0x00 NATIVE_SECTOR_SIZE[63]:0x00 USE_NATIVE_SECTOR[62]:0x00 DATA_SECTOR_SIZE[61]:0x00 INI_TIMEOUT_EMU[60]:0x00 Class6_CTRL[59]:0x00 DYNCAP_NEEDED[58]:0x00 EXCEPTION_EVENTS_CTRL[57:56]:0x00 EXCEPTION_EVENTS_STATUS[55:54]:0x00 EXT_PARTITIONS_ATTRIBUTE[53:52]:0x00 CONTEXT_CONF[51:37]:0x000000000000000000000000000000 PACKED_COMMAND_STATUS[36]:0x00 PACKED_FAILURE_INDEX[35]:0x00 POWER_OFF_NOTIFICATION[34]:0x00 CACHE_CTRL[33]:0x00 FLUSH_CACHE[32]:0x00 MODE_CONFIG[30]:0x00 MODE_OPERATION_CODES[29]:0x00 FFU_STATUS[26]:0x00 PRE_LOADING_DATA_SIZE[25:22]:0x00000000 MAX_PRE_LOADING_DATA_SIZE[21:18]:0x00 PRODUCT_STATE_AWARENESS_ENABLEMENT[17]:0x00 SECURE_REMOVAL_TYPE[16]:0x00 Basic Information: Extended CSD revision: Revision 1.5 (MMC v4.41) User Data Area Size: 15028MB(0x3AB400000) Boot Partition Size: 2048KB RPMB Size: 128KB General Purpose Partition 1 Size: 0KB General Purpose Partition 2 Size: 0KB General Purpose Partition 3 Size: 0KB General Purpose Partition 4 Size: 0KB Erase group size: 512KB CID:0x03C9BF52 0x4107D31C 0x41473247 0x1501004D Manufacturer ID:0x15 Device/BGA:1 (removable:1 BGA:2 POP:3) OEM/Application ID:0x00 Product name:0x4D4147324741 (MAG2GA) Product revision:0x07 Product serial number:0xD31C03C9 Manufacturing date:0xBF CRC7 checksum:0x52 CSD:0x8A406062 0xF6DBFFFF 0x0F5903FF 0xD0270132 CSD structure:0x3 System specification version:0x4 Data read access-time 1:0x27 Data read access-time 2:0x1 Max. bus clock frequency:0x32 Card command classes:0x0F5 Max. read data block length:0x9 (512) Partial blocks for read allowed:0 Write block misalignment:0 Read block misalignment:0 DSR implemented:0 Device size:0xFFF Min. read current @ VDD min:0x6 Max. read current @ VDD min:0x6 Min. write current @ VDD min:0x6 Max. write current @ VDD min:0x6 Device size multiplier:0x7 Erase group size:0x1F Erase group size multiplier:0x1F Write protect group size:0x1F Write protect group enable:1 Manufacturer default ECC:0 Write speed factor:2 Max. write data block length:0x9 Partial blocks for write allowed:0 Content protection application:0 File format group(R/W):0 Copy flag (OTP)(R/W):1 Permanent write protection(R/W):1 Temporary write protection(R/W):0 File format(R/W):0 ECC code(R/W):0 CRC(R/W):0x31 Not used, always ’1’:0 RCA:0x00000000 EXT_CSD information parsing: FFU features:0x00 BOOT_SIZE_MULTI[226]:0x10 HC_ERASE_GRP_SIZE[224]:0x01 ERASE_TIMEOUT_MULT[223]:0x01 SEC_COUNT(EXT_CSD[215:212]:0x01D5A000) CARD_TYPE(EXT_CSD[196]):0x07 CSD_STRUCTURE(EXT_CSD[194]):0x02 EXT_CSD_REV(EXT_CSD[192]):0x05 PARTITION_CONFIG[179]:0x00 BOOT_CONFIG_PROT[178]:0x00 BOOT_BUS_CONDITIONS[177]:0x00 ERASE_GROUP_DEF[175]:0x00 BOOT_WP[173]:0x00 USER_WP[171]:0x00 FW_CONFIG[169]:0x00 RPMB_SIZE_MULT[168]:0x01 WR_REL_SET[167]:0x1F WR_REL_PARAM[166]:0x05 SANITIZE_START[165]:0x00 BKOPS_START[164]:0x00 BKOPS_EN[163]:0x00 RST_n_FUNCTION[162]:0x00 HPI_MGMT[161]:0x00 PARTITIONING_SUPPORT[160]:0x03 MAX_ENH_SIZE_MULT[159:157]:0x0000BB PARTITIONS_ATTRIBUTE[156]:0x00 PARTITION_SETTING_COMPLETED[155]:0x01 GP_SIZE_MULT[154:143]:0x000000000000000000000000 ENH_SIZE_MULT[142:140]:0x000000 ENH_START_ADDR[139:136]:0x00000000 SEC_BAD_BLK_MGMNT[134]:0x00 PRODUCTION_STATE_AWARENESS[133]:0x00 TCASE_SUPPORT[132]:0x00 PERIODIC_WAKEUP[131]:0x00 PROGRAM_CID_CSD_DDR_SUPPORT[130]:0x00 NATIVE_SECTOR_SIZE[63]:0x00 USE_NATIVE_SECTOR[62]:0x00 DATA_SECTOR_SIZE[61]:0x00 INI_TIMEOUT_EMU[60]:0x00 Class6_CTRL[59]:0x00 DYNCAP_NEEDED[58]:0x00 EXCEPTION_EVENTS_CTRL[57:56]:0x00 EXCEPTION_EVENTS_STATUS[55:54]:0x00 EXT_PARTITIONS_ATTRIBUTE[53:52]:0x00 CONTEXT_CONF[51:37]:0x000000000000000000000000000000 PACKED_COMMAND_STATUS[36]:0x00 PACKED_FAILURE_INDEX[35]:0x00 POWER_OFF_NOTIFICATION[34]:0x00 CACHE_CTRL[33]:0x00 FLUSH_CACHE[32]:0x00 MODE_CONFIG[30]:0x00 MODE_OPERATION_CODES[29]:0x00 FFU_STATUS[26]:0x00 PRE_LOADING_DATA_SIZE[25:22]:0x00000000 MAX_PRE_LOADING_DATA_SIZE[21:18]:0x00 PRODUCT_STATE_AWARENESS_ENABLEMENT[17]:0x00 SECURE_REMOVAL_TYPE[16]:0x00 Basic Information: Extended CSD revision: Revision 1.5 (MMC v4.41) User Data Area Size: 15028MB(0x3AB400000) Boot Partition Size: 2048KB RPMB Size: 128KB General Purpose Partition 1 Size: 0KB General Purpose Partition 2 Size: 0KB General Purpose Partition 3 Size: 0KB General Purpose Partition 4 Size: 0KB Erase group size: 512KB Writing Started... Write failed (13) Writing Done !! |
The Following User Says Thank You to akhileshbaghel For This Useful Post: |
