Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GSMFABRICA Products
Old 06-05-2017, 14:16   #1 (permalink)
Electroboys's Avatar
Member: 6594
Sonork: 100.27285
Thanks Meter: 22,482
eMMC Pro - V1.09 New Features , More Powerful
eMMC Pro 1.09 Release Notes
[5 JUNE 2017]
We are trying to make more powerful eMMC software with every each update
There are alof of optimizations and progress based on customers requests and demands.
  1. # Detection Routines improved .
  2. # Samsung eMMC Firmware Update ( FFU Update )
  3. # Samsung eMMC Firmware Read
  4. # Qualcomm Disk with eMMC Booster interface selected
  5. # Samsung eMMC Boot Resize ( Partition )
  6. # Samsung eMMC RPBM Resize ( Partition )
  7. # eMMC BOOT CFG Setup
  8. # Samsung eMMC CID Writing / Patch
  9. # MTK Preloader.bin CID Parsing for the UI
  10. # UI - Selection of BOOT Size : 1MB to 8MB
  11. # UI - Selection of RPMB Size : 128KB to 1024KB
  12. # UI - Selection BOOT Configuration
  13. # UI - CID Write Module
  14. # UI - CID Load from preloader.bin
  15. # UI - Firmware list with Upgrade and Read options
  16. # New Firmware Released Version = 2017052915210004
When you first run eMMC Pro V1.09 sw will update your firmware .
With the new firmware we have implemented better detection and more features.
and makes it more stable and alot more powerful with more powerful features.
[Samsung eMMC Firmware Update]
Vendor CMDs and sequences implemented in order to update and repair Dead eMMCs
Solution for the known problems :
  • Brick boot
  • Boot Loop
  • SD Mounting Problems
  • E:failed to mount /data (No such file or directory)
  • ODIN Flashing failed on PIT known as PIT Failed.
  • Complete(Write) operation failed.
Firmware List :
KLM4G1FE3B-B001
KLM8G1WE4A-A001
KLM8G1WEMB-B011
KLM8G1WEMB-B031
KLM8G2FB3B-D001
KLM8G2FB3B-D001
KLM8G2FE3B-B001
KLM8G2YE4C-C001
KLMAG2GE2A-A001
KLMAG2GE4A-A001
KLMAG2GE4A-A002
KLMAG2GEAC-B001
KLMAG2GEAC-B002
KLMAG2WE4A-A002
KLMAG2WEMB-B031
KLMAG4FE4B-B002
KLMAG4FEAB-B002
KLMBG4GE4A-A001
KLMBG4GEAC-B001
KLMCG8GE4A-A001
KMJ5U000WA-B409
KMJ5U000WM-B409
KMJJS000WA-B409
KMJJS000WM-B409
KMK2U000VM-B604
KMK3U000VM-B410
KMK5U000VM-B309
KMK5W000VM-B312
KMK5X000VM-B314
KMK5X000YM-B314
KMK7U000VM-B309
KMK7X000VM-B314
KMK8U000VM-B410
KMKJS000VM-B309
KMKTS000VM-B604
KMKUS000VM-B410
KML5U000HM-B505
KMN5U000ZM-B203
KMN5W000ZM-B207
KMN5X000ZM-B209
KMN9W000RM-B203
KMNJS000ZM-B205
KMS5U000KM-B308
KMS5X000KM-B313
KMSJS000KA-B308
KMSJS000KM-B308
KMV2W000LM-B506
KMV3U000LM-B304
KMV3W000LM-B310
KMVIS000LM-B503
KMVTU000LM-B503
KMVUS000LA-B304
KMVUS000LM-B304
KMVWU000LM-B900
KMVYL000LM-B503
[Samsung eMMC Firmware Read:]
You can read Samsung eMMC Firmware's in case you have New Samsung eMMC in your hand which is not supported !
[Qualcomm Disk with eMMC Booster:]
When there is a Qualcomm disk is connected you can choose eMMC Booster on the interface and write proper dump for it.
eMMC Pro Software handle the procedures directly into Qualcomm Disk !
[Samsung eMMC Boot Resize ( Partition ) :]
Re-Configuring BOOT1 , BOOT2 , RPMB
Configuring Partition Sizes is important if you do not have matching eMMC for another device .
[Solution for :] MTK Devices or any Device for this matter should be able to match the original device (eMMC Configuration ) will let the device work properly .
[eMMC BOOT CFG Setup :]
BOOT Configuration Setup Device (eMMC) to boot in particular Area of the
  • Device
  • BOOT1
  • BOOT2
  • USER Area
  • No Boot
[Samsung eMMC CID Writing / Patch :]
Writing any CID into device will help you configure Samsung eMMCs into any eMMC !
For ex : Hynix CID into Samsung eMMC to act as Hynix eMMC
Solution for : Many MTK Mobile phones with unique CID determined !
[MTK Preloader.bin CID Parsing for the UI ]
Parse the preloader.bin and select in order to make it compatible eMMC CID .
[UI Definitions :]
[BOOT Size : ]
You can select the BOOT Size that you want to configure
1MB , 2MB , 4MB , 8MB
[RPMB Size: ]
You can select the RPMB Size that you want to configure
128KB , 256KB , 512KB , 1024KB
[BOOT Configuration : ]
User selects boot data that will be sent to device
  • Device not boot enabled (default)
  • Boot partition 1 enabled for boot
  • Boot partition 2 enabled for boot
  • User area enabled for boot
[CID Write Module: ]
CID Box acts as Combobox when selected a preloader.bin
Modify and write the require CID into Device .
[CID Load from preloader.bin: ]
Small Button with [+] Loads the preloader.bin and parse into Combobox you to select !
[Upgrade Firmware : ]
It will write selected firmware into eMMC
eMMC ID should match with the Firmware otherwise writing process will fail or will not work .
[ New Firmware : 2017052915210004 ]
  • Box Firmware with New Functions and CMDs implemented .
Thank you for all eMMC Pro Customers to keep sending us requests and suggestions .
There is a lot more to come
Best Regards
eMMC Pro Team
Advanced eMMC Repair
eMMC PRo - Universal Device Programmer
The Following 33 Users Say Thank You to Electroboys For This Useful Post:
Old 06-05-2017, 14:38   #2 (permalink)
dereje's Avatar
Member: 449991
Thanks Meter: 859
most awaited update thanks eMMC-Pro team keep up
Old 06-05-2017, 14:47   #3 (permalink)
Fusion Rock's Avatar
Member: 1930738
Sonork: 100.1638397
Thanks Meter: 80
please try to make a small small tutorials for new users. nice update thank you
The Following 2 Users Say Thank You to Fusion Rock For This Useful Post:
Old 06-05-2017, 16:22   #4 (permalink)
Member: 138809
Sonork: 100.99886
Thanks Meter: 77
Please make small tutorials for cid patch
And how to update firmware emmc
Sent from my iPhone using Tapatalk
The Following User Says Thank You to shahjee For This Useful Post:
Old 06-05-2017, 17:13   #5 (permalink)
Member: 706822
Thanks Meter: 456
very good update thanx emmc pro team
Old 06-05-2017, 21:04   #6 (permalink)
vickyjadhav6161's Avatar
Member: 2386560
Sonork: NOW I DON'T USE IT
Thanks Meter: 561
bro fat-on cool down, you dropped nuclear bomb,now i thik other box need to pack up,but bro 1 more missing moto dead cid repair...anyway bundles of thanks....
i am proud of me useing emmc pro..
Old 06-06-2017, 04:30   #7 (permalink)
Taguro-GSMLover's Avatar
Member: 2669319
Thanks Meter: 404
Great Job Team! You really care of what customers demand.
Old 06-06-2017, 05:02   #8 (permalink)
bench betita's Avatar
Member: 580233
Thanks Meter: 27
cool update,..how about download speed in any firmware in support? please make it faster..
tnx..
Old 06-06-2017, 09:08   #9 (permalink)
Member: 2547620
Thanks Meter: 3,429
Thanks to you guys !
We can only answer for what you need in demand !
So this is all the requests and Thanks for the patience ..
Tutorial
1- in short term we will release few videos for each function and benefits and how to use them .
2 - Making full user manual with detailed instructions , it might come out in 2 weeks .
Thanks bro ,
MOTO CID problem or repairing the device out of dead state is in the list .
Thats what we should do
tnx..
Web Server will get big kick update in few days !
Lots of changes , Get ready for that
The Following 3 Users Say Thank You to FAT-ON For This Useful Post:
Old 06-08-2017, 07:26   #10 (permalink)
arx
Member: 134843
Sonork: none
Thanks Meter: 81
nice update.... emmc pro is realy the best :-bd
Old 06-11-2017, 11:36   #11 (permalink)
Member: 2547620
Thanks Meter: 3,429
http://www.youtube.com/watch?v=MRIOvIKvyEw
Best Regards
F4T0N
The Following 4 Users Say Thank You to FAT-ON For This Useful Post:
Old 06-13-2017, 08:25   #12 (permalink)
Member: 920138
Thanks Meter: 85
how to manual update EMMC PRO box...my 1st open my box in v1.09 i did not recieve update pop-up firmware...
eMMC Pro - eMMC Programmer Version V1.09
FIRMWARE(0x4D41494E) version:2017052915210004
Old 06-13-2017, 10:16   #13 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 482
samsung g532g boot repear problem
The Following 2 Users Say Thank You to SAJONDUTTA For This Useful Post:
Old 06-13-2017, 14:31   #14 (permalink)
tasweb's Avatar
Member: 1996822
Thanks Meter: 83
thanks gpg Product....
Old 06-14-2017, 05:36   #15 (permalink)
Member: 25067
Thanks Meter: 76
dear sir, just suggest about emmc detect information, can you make it more easy to read just display basic information (emmc name, user size, boot size, rpmb size and boot condition) instead display all info and also rpmb size can you make it support resize to 4096kb and last why after write ext_csd my emmc setting not change??
btw thanks for update......
The Following 2 Users Say Thank You to johnny_liang For This Useful Post:
Page generated in 0.40167 seconds with 7 queries
