Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GSMFABRICA Products
Old 09-29-2018, 20:27   #1 (permalink)
bilm25's Avatar
Member: 78657
Thanks Meter: 71
G532F dead boot
hello.
the phone is dead and cant inter to download mode after repair boot.
is the configuration correct ?
www.emmc-pro.com
eMMC Pro - eMMC Programmer Version V1.13
FIRMWARE(0x4D41494E) version:FFFF201712241746
SN:000000000000000027B43B4B2D65xxxx
+CID:15010051 4E313642 4200B306 C4BC1480
  Manufacturer ID:0x15
  Device/BGA:1 (removable:1 BGA:2 POP:3)
  OEM/Application ID:0x00
  Product name:0x514E31364242 (QN16BB)
  Product revision:0x00
  Product serial number:0xB306C4BC
  Manufacturing date:0x14
  CRC7 checksum:0x80
+CSD:D0270132 0F5903FF F6DBFFEF 8E40400C
  CSD structure:0x3
  System specification version:0x4
  Data read access-time 1:0x27
  Data read access-time 2:0x1
  Max. bus clock frequency:0x32
  Card command classes:0x0F5
  Max. read data block length:0x9 (512)
  Partial blocks for read allowed:0
  Write block misalignment:0
  Read block misalignment:0
  DSR implemented:0
  Device size:0xFDB
  Min. read current @ VDD min:0x6
  Max. read current @ VDD min:0x6
  Min. write current @ VDD min:0x6
  Max. write current @ VDD min:0x6
  Device size multiplier:0x7
  Erase group size:0x1F
  Erase group size multiplier:0x1F
  Write protect group size:0xF
  Write protect group enable:1
  Manufacturer default ECC:0
  Write speed factor:3
  Max. write data block length:0x9
  Partial blocks for write allowed:0
  Content protection application:0
  File format group(R/W):0
  Copy flag (OTP)(R/W):1
  Permanent write protection(R/W):0
  Temporary write protection(R/W):0
  File format(R/W):0
  ECC code(R/W):0
  CRC(R/W):0x6
  Not used, always ’1’:0
+EXT_CSD information parsing:
FFU features:0x00
BOOT_SIZE_MULTI[226]:0x20
HC_ERASE_GRP_SIZE[224]:0x01
ERASE_TIMEOUT_MULT[223]:0x01
SEC_COUNT(EXT_CSD[215:212]:0x00E90000)
CARD_TYPE(EXT_CSD[196]):0x57
CSD_STRUCTURE(EXT_CSD[194]):0x02
EXT_CSD_REV(EXT_CSD[192]):0x07
PARTITION_CONFIG[179]:0x48
 Boot partition 1 enabled for boot
BOOT_CONFIG_PROT[178]:0x00
BOOT_BUS_CONDITIONS[177]:0x00
ERASE_GROUP_DEF[175]:0x00
BOOT_WP[173]:0x00
USER_WP[171]:0x00
FW_CONFIG[169]:0x00
RPMB_SIZE_MULT[168]:0x20
WR_REL_SET[167]:0x1F
WR_REL_PARAM[166]:0x14
SANITIZE_START[165]:0x00
BKOPS_START[164]:0x00
BKOPS_EN[163]:0x00
RST_n_FUNCTION[162]:0x01
HPI_MGMT[161]:0x00
PARTITIONING_SUPPORT[160]:0x07
MAX_ENH_SIZE_MULT[159:157]:0x0001D2
PARTITIONS_ATTRIBUTE[156]:0x00
PARTITION_SETTING_COMPLETED[155]:0x00
GP_SIZE_MULT[154:143]:0x000000000000000000000000
ENH_SIZE_MULT[142:140]:0x000000
ENH_START_ADDR[139:136]:0x00000000
SEC_BAD_BLK_MGMNT[134]:0x00
PRODUCTION_STATE_AWARENESS[133]:0x00
TCASE_SUPPORT[132]:0x00
PERIODIC_WAKEUP[131]:0x00
PROGRAM_CID_CSD_DDR_SUPPORT[130]:0x01
NATIVE_SECTOR_SIZE[63]:0x00
USE_NATIVE_SECTOR[62]:0x00
DATA_SECTOR_SIZE[61]:0x00
INI_TIMEOUT_EMU[60]:0x00
Class6_CTRL[59]:0x00
DYNCAP_NEEDED[58]:0x00
EXCEPTION_EVENTS_CTRL[57:56]:0x00
EXCEPTION_EVENTS_STATUS[55:54]:0x00
EXT_PARTITIONS_ATTRIBUTE[53:52]:0x00
CONTEXT_CONF[51:37]:0x000000000000000000000000000000
PACKED_COMMAND_STATUS[36]:0x00
PACKED_FAILURE_INDEX[35]:0x00
POWER_OFF_NOTIFICATION[34]:0x00
CACHE_CTRL[33]:0x00
FLUSH_CACHE[32]:0x00
MODE_CONFIG[30]:0x00
MODE_OPERATION_CODES[29]:0x00
FFU_STATUS[26]:0x00
PRE_LOADING_DATA_SIZE[25:22]:0x00000000
MAX_PRE_LOADING_DATA_SIZE[21:18]:0x00
PRODUCT_STATE_AWARENESS_ENABLEMENT[17]:0x00
SECURE_REMOVAL_TYPE[16]:0x39
Basic Information:
Extended CSD revision:
User Data Area Size: 7456MB(0x1D2000000)
Boot Partition Size: 4096KB
RPMB Size: 4096KB
General Purpose Partition 1 Size: 0KB
General Purpose Partition 2 Size: 0KB
General Purpose Partition 3 Size: 0KB
General Purpose Partition 4 Size: 0KB
Erase group size: 512KB
Writing Started...
Writing Done !!
  CRC7 checksum:0x80
  CSD structure:0x3
  DSR implemented:0
  Device size:0xFDB
  File format(R/W):0
  ECC code(R/W):0
  CRC(R/W):0x6
FFU features:0x00
BOOT_WP[173]:0x00
USER_WP[171]:0x00
FW_CONFIG[169]:0x00
BKOPS_EN[163]:0x00
HPI_MGMT[161]:0x00
CACHE_CTRL[33]:0x00
FFU_STATUS[26]:0x00
Basic Information:
RPMB Size: 4096KB
Writing Started...
Writing bp1.bin ...
Writing user.bin ...
Writing Done !
thank you
Old 10-06-2018, 09:59   #2 (permalink)
Member: 463114
Thanks Meter: 3
after that go to config set to boot 1 enable ack then click partition config
Page generated in 0.14982 seconds with 10 queries
